Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: HH Cobalt Puller- Reborn page 35!
Old 11-04-2011, 07:35 AM   #661
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Originally Posted by JoeWorks View Post
I just acquired one of these cobalt motor from a friend with the stickers a bit beat up with the turns unreadable. Is there a way to determine the turns? Any other marking to look for? Wire Size?
Thanks in advance.
You can normally count the winds on the bottom of the armature, that is the easiest way.
Originally Posted by JaredVW View Post
I took a break from the crawling world, but I am getting amped to get back into this. Before backing my axial away I remember always searching for a cobalt puller used. Are these back on the market?!
I do have some new still. I also have a ton of brushes and armature blanks to keep old motors running for years to come.
JohnRobHolmes is offline   Reply With Quote
Old 11-04-2011, 12:49 PM   #662
[QUOTE=JohnRobHolmes;3363482]You can normally count the winds on the bottom of the armature, that is the easiest way.
Thanks You Sir..
I'll Try With My Old Eyes and Magnifying Glass.. HEHE
Aloha
JoeWorks is offline   Reply With Quote
Old 11-16-2011, 09:26 PM   #663
heinie_21's Avatar
is this a HH cobalt? or..? himark?
IMAG1000 by heinie_21, on Flickr
IMAG0999 by heinie_21, on Flickr
heinie_21 is offline   Reply With Quote
Old 11-17-2011, 07:18 AM   #664
Himax cobalt, with one of my adapters.
Old 11-22-2011, 12:22 AM   #665
Default puller combo????
Hey
I went to the site tonight to purchase a puller combo and noticed its not on the site any more and that the pullers are all out of stock.
Are you still selling the puller motors?
mrhobby100 is offline   Reply With Quote
Old 11-22-2011, 11:18 AM   #666
They are temporararily discontinued. I just completed a prototype Neo Puller (brushed) today, so we should be able to get a good replacement motor soon. I also have Puller Pros (brushless) in the works and we will get sensorless versions first and bring sensored versions to the table shortly thereafter.
Unfortunately the parts will not be compatible from the old Pullers to the new Pullers, but we will keep the product line going!
Old 11-22-2011, 01:52 PM   #667
Are these new Neo Pullers comparible in cost and in size to the old Pullers. How is the performance of these new ones compared to the old ones.
Do you have a ETA on these new pullers just finished up a rig for myself for christmas and would love a Brushed Puller motor and BRXL in it.
If you have any 10T pullers left laying around even if it is used shoot me a PM. Thanks.
Old 11-22-2011, 04:09 PM   #668
Size wise they will be the same. Cost wise they will be a bit more. We were running on 2002 manufacturing costs with the Cobalt Puller, and can't keep an artificially low price with new manufacturing.
I can't answer any of the other questions yet. The brushless versions will certainly be higher power.
Old 11-22-2011, 04:32 PM   #669
The wraith would need a bit of modifying to fit a puller. The stock ESC would take a 10t or 14t no problem. I would suggest a 540 unless you are willing to mod the chassis.
Is this correct? I thought the stock wraith ESC was limited to 17t?
strap624 is offline   Reply With Quote
Old 11-22-2011, 04:33 PM   #670
The puller isn't the same as a 540, it is 7 slot VS 3 slot so the winds don't work the same.
Old 11-22-2011, 04:35 PM   #671
Oh ok, so RPM wise, a 14t puller would be comparable to what wind on a standard 540?
Old 11-23-2011, 12:32 AM   #672
Hey there John, I picked up one of your 7t puller motors in a trade from a friend.I'm wondering why it is twice as fast in reverse then it is forward,and seems to get quite warm in 7.5lb. scaler 16/87 gearing?Could this be a timing issue? And i noticed there is no marks on the can as a reference.Any info would be appreciated,thanks.
J-FAB NOR-CAL is offline   Reply With Quote
Old 11-23-2011, 12:44 AM   #673
Ok,I just went back a couple pages and read that the 7t on 3s gets warm,especially with the 16/87 gearing.But still want to know why the big speed difference between forward and reverse?
Old 11-23-2011, 09:55 AM   #674
I think it is like a 45t, I don't remember exactly.
Sounds like a timing issue. Rotate the endbell a few mm in the opposite direction of the rotation of the commutator.
Old 11-27-2011, 10:59 AM   #675
How well do the perform after being in the elements with out a lot of attention? Like cleaning it every 2 or 3 times in the elements.
rockrocker1976 is offline   Reply With Quote
Old 12-13-2011, 11:49 PM   #676
Hey
just checking in to see if there is an ETA for that new NEO puller you have listed on the site. I got money burning a whole in my pocket waiting for one of your pullers.
Old 12-14-2011, 01:49 PM   #677
PapaGriz Yo
Grizzly4x4's Avatar
I've got 3 years of abuse in mud, dirt, water and rocks on both my 10T and 7T Pullers. The only maintenence I do is spray them with WD-40 after washing off the mud. I still have the original brushes in them.
I do run a foam filter on the can to keep most of the grit out of the motor. I think this has really help with their life.
Grizzly4x4 is offline   Reply With Quote
Old 12-15-2011, 10:27 PM   #678
Default Re: HH Cobalt Puller- Discontinued briefly
Is THIS the same motor, still discontinued or a new version?
HoupS is offline   Reply With Quote
Old 12-16-2011, 02:41 AM   #679
If you look at what you linked it is a 454 motor. The motors that everybody is talking about that is briefly discontinued is the 540 motor. a 540 is the standard size motor most scale rigs run on.
Old 12-16-2011, 10:11 PM   #680
When you think you might have some neos?
Jeepial is offline   Reply With Quote
HH Cobalt Puller- Reborn page 35! - Similar Threads
R1 + Cobalt Puller Highlucks G-Made Crawlers 3 05-31-2010 09:38 PM
You may edit your posts
