03-09-2011, 01:39 PM | #2581 | |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
03-10-2011, 01:38 AM | #2582 |
Rock Stacker Join Date: Mar 2011 Location: THizzatello aka (Pocatello)
| Moa rockslide rs10 11t 454's
Hi John I a recently put 2 11t 454's in my rs10 I am running 8t pinion in back n 10t in frOnt super rooster rev. Esc and 10cell 3800 mah battery I have barely ran it since I put it together I couple days ago but my battery dies after 3-5 min........? Do u have any suggestions for longer runtime? Less voltage on batter I'm runnin maybe ur 16t would suit me better now that they are available I'm stumped on how short my runtime is thanks for any help I can get
03-10-2011, 08:36 AM | #2583 | |||
03-10-2011, 09:42 AM | #2584 |
Greenforce cells it's a pack off eBay that ships from hong kong that's prolly the mistake I made right there buying a battery like this one....
03-10-2011, 09:53 AM | #2585 |
I can't find em on ebay. Probably just low discharge rate cells.
03-10-2011, 10:42 AM | #2586 |
Here is a direct link to the page on eBay, I am almost certain it's just a junk battery pack wit low discharge cells I found a guy who is sending me some 14t arms to throw in my cans this should accommodate me even better for crawling the cobalts are bad ass I really hope it all works good for my truck in the end....... Thanks John here is the link if u have time to look........... http://cgi.ebay.com/1-pcs-12V-3800mA...#ht_2851wt_860 |
03-10-2011, 10:52 AM | #2587 |
Yeah, just cheap cells that are giving out fast. May be a bad cell in the pack too.
03-11-2011, 09:37 PM | #2588 |
| Battery: what should I buy?
Ok so I talked wit u the other day about my battery dying so quickly, I am running the rs10 wit super rooster and 11t cobalts.... I wanna run 10 cell what would be a good 10 cell choice with a good runtime wit the cobalts I know they draw a lot of amps so I think I need something wit a decent mah even though I will take breaks during driving due to motor heat. Thanks John any recommendations u sell or anyone else sells will be greatly appreciated!
03-14-2011, 04:59 PM | #2589 |
Pebble Pounder Join Date: Dec 2010 Location: Veneta
I had a couple of questions regarding your bushed esc. Do you recommend running an external bec, and if you do how would you wire it in? It would be going in an scx10. Thanks
03-14-2011, 09:05 PM | #2590 |
Pebble Pounder Join Date: Aug 2006 Location: Raleigh NC
| 35t Torquemaster
Hey John, I just bought a BRXL from you, packaged arrived today. I got everything soldered up and I am having some trouble with it. It seems like my motor has a "dead"spot in it. It will run fine, but if I stop, it won't move again. If i rotate the wheels by hand, I can usually get going again. Here is what I'm running: BRXL 35t Torquemaster JR 133 Rx and JR XR3 Tx. I'm not running a BEC to my steering servo(7995TG) or to my dig servo(645MG). Any ideas? EDIT: I've got the drag brake set at 25% and no hold brake. Zack Last edited by YJJPWrangler; 03-14-2011 at 09:53 PM. |
03-15-2011, 12:05 AM | #2591 |
Never mind John goin lipo.......
03-15-2011, 07:01 AM | #2592 | ||
Go 3s! | ||
03-15-2011, 07:46 AM | #2593 |
It is not a new motor. I purchased it here, but was told that it didn't have a lot of hours on it. Is there anything I can do to fix it, or send it in to you? BTW, the BRXL is really nice .
03-15-2011, 08:30 AM | #2594 |
The first thing is to inspect it. Most likely a comm cut and brush change will solve the issue. You can send it in to me for a $10 total service ($5 for return shipping) if you don't have the resources. http://holmeshobbies.com/product.php...&cat=23&page=1 |
03-15-2011, 01:36 PM | #2595 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
Just thought I'd comment & say thanks. I got a 33turn torquemaster for my mrc last week. My mrc has a lot of mods, but still has the stock(modded) chassis and stock electronics. I'm very happy because the motor works great, haven't changed the gearing, and the stock esc still runs my 5955 servo just fine! And I have a pretty good drag brake now, I guess cuzz of the strong magnets in the motor? So now I might as well keep the stock electronics for now- they work just fine for me
03-16-2011, 06:54 AM | #2596 |
John, I took the motor apart and cleaned it, The comm looked like it had some grooves in it. I put it back together and didn't have any issues with it wanting to find that "dead" spot. I slow crawled it and it was fine, couldn't do it before. After running it for a bit, it started acting up, I could see electric flashes from the endbell of the motor and the motor would twitch in forward and reverse, sometimes violently. I quit driving it and will most likely send it in to you. Have any ideas on what it is doing? Could I have advanced the timing on it causing this problem? |
03-16-2011, 07:36 AM | #2597 |
Tim- The stronger magnets do give better drag. Glad you like it! YJJP- If you advanced the timing too far it could have caused some damage to the comm gap. Sounds like you need a good comm cut at least, but the damage may have been done. |
03-16-2011, 09:40 AM | #2598 |
John, if I want to send this back to you, do I need to drop it in the mail and then pay for it on your website? Or do I need to wait until you take a look at it and let me know whats going on with it? Thanks, Zack |
03-16-2011, 11:18 AM | #2599 |
Either way you want to do. Paying in advance puts you in line, whereas waiting to pay will get your order in line at time of payment.
03-16-2011, 11:37 PM | #2600 |
Quarry Creeper Join Date: Jan 2010 Location: GV
Hey John, thanks for the easy acess to you and your products. I got a question, I got one of your motors (torque master pro) here on RCC on a bulk motor lot buy. The motor was in good shape and after turning the comm and cleaning and lube job it is running great with lots of torque. So I decided to put it in the front of my xr10 and put a tekin machine in the rear, and now the tekin wants to turn much faster and earlier than your motor, I attribute this to the difference in hand winding, heavier springs, lay down brushes, and 4 magnets. So i decided I need a new matching one for the rear, and I only see 2 magnet motors int the order forum. Is there a way to get a matching motor for this one? It's a 45t, 4magnet can, 10mm comm lay down brushed with soldered brushes and black springs... It's got your sticker on it, the big sticker, not just a round one, it has your end bell and is VERY nicely and tightly wound by the way. Thanks for your help... |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
