02-17-2011, 05:56 PM | #2521 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
hi john, i recently got the mini torque master and have been getting issues. sometimes, the mini will stop running, or wont go even if im holding it full throttle. |
02-19-2011, 09:03 PM | #2522 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
Hi John, I am looking at getting a new motor and ESC and I hear alot of good things about your product. I am currently running a Rooster crawler with a 55T motor in a SCX10. I would like to get more speed but not lose any torque or low speed control. I am thinking about going with your BR-XL and a 30T or 35T motor. Will the brake on the BR-XL hold better than the Rooster crawler? and will the 30T or 35T give me both more wheel speed and torque? I see that you have a crawl master and a torque master, what is the difference in the two? can you give me your recomendation on which set up would work the best? I will be running the truck on trails and in local rock crawling competions. Thank you for your help and advise.
02-19-2011, 09:37 PM | #2523 |
The TorqueMaster ESC can be set up with stronger hold or drag brake as compared to the Rooster. When set up strongest in Hold mode it will basically hold a motor at stall until the ESC starts backing off. It sounds like you are using a machine wound or can motor. Going to a finer construction of motor can give you better low speed resolution, control, power, torque, and higher speed. I would suggest a 35t on 3s for a pretty nasty kick. Alternatively you could swap a handwound armature into your existing motor and get a good bump too. The Crawlmaster motor crawls slower and has superb control, but makes less power. The TorqueMaster has a higher power to weight ratio and acceleration snap. Both can work "best" depending on what you want. |
02-20-2011, 01:42 PM | #2524 |
is a handwound armature to install in my motor something that I can get from you and is it something that I can install my self or do you need special tools? I still want to get one of your motors and ESC, but I have 2 Roosters and 3 trucks so if I could swap out the armature on mine maybe I would be happy with it until I could get some extra money to purchase a second unit from you. Thank you for all your help.
02-20-2011, 03:29 PM | #2525 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Whats the deal with the two different pullers on your site. Pretty big price difference.
02-21-2011, 06:17 AM | #2526 | ||
Pretty big size and power difference too | ||
02-22-2011, 07:38 AM | #2527 |
RCC Addict Join Date: Jun 2006 Location: Maryland
| Large scale motor options
Building a large scale truck that will weigh in at the 15-20 pound range. Already have my mamba max pro, and it will be running a very large 4s lipo thru a fully beefed axial trans. I'm 99% sure I want a brushless sensored inrunner, but dont know which one. Still waiting on the release of the puller pro 550, but I saw a tekin T8 in a truggy at motorama this weekend, and was thinking I might be able to shoehorn it into my AX trans. and then there is this tekin roc412 I've read a little about, and now I'm just more confused on which way to go... Recomendations? Thanks for any help -Brian |
02-22-2011, 07:59 AM | #2528 |
Right now the T8 from tekin will be the fastest route. I have sent a few to team drivers and they really like them. It is basically a 1515 framed motor if I recall correctly. The roc412 is taking a long time to get to market. Jim said he would let me know when they get them done, I will certainly be carrying them in the store. Maybe I should get some t8 motors in too? |
02-22-2011, 08:59 AM | #2529 |
Thanks for the fast response. Im assuming that your failure to even mention the puller pro, a release date is nowhere in sight? Guess I'd want to run the lowest KV available in the T8? I want the PP cause its HH, and its anod'd black... |
02-22-2011, 09:00 AM | #2530 |
Yeah, I don't have a firm release date on it. I ran into some unanticipated issues with getting them made like I wanted.
02-22-2011, 07:49 PM | #2531 |
Well since I can't buy the puller pro, I'd like to buy the 1350kv T8 from you if possible. Should be #tt2364 Pottersmachine@gmail.com for an invoice please. |
02-23-2011, 01:52 AM | #2532 |
Newbie Join Date: May 2010 Location: Finland
Hello John Send you message on your companys e-mail. Did you get it? |
02-24-2011, 08:56 AM | #2533 | |
Probably, did you get my response? | |
02-25-2011, 10:10 AM | #2534 |
I asked a question within an order I just sent but then I found the answer in the fine print on the product description. The product description text is tiny on your site |
02-25-2011, 12:08 PM | #2535 |
Press Control +, it will increase the text size.
02-25-2011, 12:12 PM | #2536 |
| got it. Hey though I realized that I could use another pair of those springs so if you can, I'd like a pair of those jokers. Let me know the cost and paypal address or I can email you on the site whichever you prefer |
02-25-2011, 12:17 PM | #2537 |
It would be better to place another order, and I can combine them and credit you the shipping.
02-25-2011, 12:27 PM | #2538 |
02-26-2011, 12:39 AM | #2539 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
| TorqueMaster Sport combo TorqueMaster Sport combo When will you be getting more in. |
02-26-2011, 08:47 AM | #2540 |
About 4 to 6 weeks. I had to switch factories, and they will be coming back with better quality.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
