04-20-2008, 04:18 PM | #761 |
Rock Stacker Join Date: Sep 2007 Location: !!!
hi johnrobholmes is they any chanca you could shed some light on this problem for me as i will be buying the compoents to fix this from your web site heres a link to my post on the problem im having help needed please thanx jase |
04-21-2008, 08:51 AM | #762 |
Hi JRH, just checking if you had an invoice for the rest of the stuff i needed, lmk.
04-21-2008, 04:21 PM | #763 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
JohnRobert, would you trade me my 5t for a 10t cobalt?
04-22-2008, 01:13 AM | #764 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Just curious what these battery packs are intended for.... http://www.holmeshobbies.com/product...&cat=10&page=1 Are they suitable for a super class shaft driven single motor rig or should they be used just for smaller scale trucks. Thanks in advance, Rob |
04-22-2008, 07:36 AM | #765 | |||||||
1.5 amps most of the time, .2 amps every 10th charge and the first few to break it in. Quote:
04-22-2008, 07:49 AM | #766 |
I just wanted to make sure i have everything on 1 shipment, i am really wanting to go with a 3 cell pack and the balancer you recomend, i wouldn't mind even getting a used 3 cell pack you might want to sell, if not maybe lmk what the 2 cell 2100mah and balancer go for.
04-22-2008, 07:53 AM | #767 |
Alright, I will look around and see what I can find. I will get you set up before the motor goes out, no worries.
04-22-2008, 07:53 AM | #768 |
Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
| ccbec
Ive been told that you can use a higher voltage batt than your speedo will take along with the cc bec. Is this true? My speedo is rated for 6 cells, adding the cc bec, will I be able to use a higher voltage battery? Cheers Matt |
04-22-2008, 08:27 AM | #769 |
04-22-2008, 09:45 AM | #770 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
04-23-2008, 08:19 AM | #771 |
I wanna be Dave Join Date: Nov 2005 Location: Here
John, Here is my situation: SW3 TLT axles CM 850 3S LiPo R2D 8T Pinion I need more wheel speed. Would it be better to gear up or go with the CM 1000 or a combo of both? Let me know your thoughts. John |
04-23-2008, 10:08 AM | #772 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
ok, here's mine, sidewinder set to auto lipo, ccbec at 6.1v 2s = 2 beeps and arming 3s = 3 beeps and arming 4s = no beeps and smoke coming out of the lipos the 4s is two of the 2s in series, both of the 2s work just fine, and when I put them together they are fine, so my conector is good. but when I plug the 4s set into the truck, I hear a boiling noise and smoke starts coming out of both lipo packs. the lipo's still work, but I am a little leary now that some of the magic smoke has escaped. am I better off ditching them before they become a problem, or assume they will be fine as long as I don't smoke them any more? |
04-23-2008, 10:33 AM | #773 |
| littleskull99 empty your pm inbox its full
04-24-2008, 02:31 AM | #774 |
jr holmes am i doing something wrong ive got a shoping basket full of stuff but it wont let me pay you it tells me to email you instead so i have emailed you via the contact us part on your web page but you havnt repled so the questions are. is this normal and how can i buy these items of you ?? |
04-24-2008, 06:43 AM | #775 |
Follow the instructions here http://holmeshobbies.com/error_messa...or_no_shipping I am a bit behind on email right now. |
04-24-2008, 06:46 AM | #776 | ||
It depends on the ESC. If yours is rated for 6 cells only it probably won't last long on anything more than 6 cells. | ||
04-24-2008, 06:53 AM | #777 | |
Due to space restrictions I need to stay with the 3S. I will order a CM 1000 unless you have something with the same foot print that would be better. Thanks | |
04-24-2008, 07:09 AM | #778 |
I think the fast CM may be the best way for you considering the situation. I will have Crawlmasters within a few days now, shipment is on the way. JRH |
04-24-2008, 07:21 AM | #779 |
04-24-2008, 11:32 AM | #780 |
The "toasted" lipos still have a charge on them. how do I get rid of these things. short of hooking it to a 12v car charger and leaving it on asphalt a safe distance away? would I hook a light or motor to it and let it run all the way down to neutralize it? or would it still be potentially dagerous? |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
