05-16-2008, 01:52 PM | #841 |
Quarry Creeper Join Date: Aug 2006 Location: CO burbs
I have a question on a new x-caliber LiPo. I charged it the first time using my E-flite balancing charger - 2-3 cells w/ .65A output. It went like normal, no errors.... I ran it for about an hour and a half. Teken Rebel 2, 55T motor. I blew out a servo and was out for the day. I hooked it up to my ICE using a pigtail I made for the charge circuit and obviously it gave me a low voltage error first thing. So, I try it this morning on the E-flite and it's giving me errors too. The voltage when I pulled it from the car was 3.3v and 3.4v testing each batt. Is there a chance that I screwed something up or maybe a bad cell and the other is giving a false reading????? Or, do I need to say screw it to LiPos and stick with something I can't mess up?????? |
05-16-2008, 02:11 PM | #842 |
Those voltages are not very close, so it could be the pack. Is your voltmeter accurate to more decimal places? I am weary of you plugging it into your ice with a pigtail though, what exactly did you do?
05-16-2008, 02:19 PM | #843 |
Rock Crawler Join Date: Apr 2006 Location: I hope you SHUT UP!!!
is it possible to use a black revolver with a 2cell lipo? which pinion would you recommend? axial trans |
05-16-2008, 03:04 PM | #844 | |
I just remembered something. When I was driving my crawler, it started to loose power for a split second, then came back. When it slowed down I figured the power was getting to the cutoff and stopped it. But, that was well after the servo was about dead. I had busted my good servo and put an old one on the car. | |
05-16-2008, 03:33 PM | #845 | ||
05-16-2008, 04:42 PM | #846 |
I don't have a camera right now, but will get a pic. Basically, it charged OK the first time and now won't take a charge. The ICE wouldn't start the charge, it gave me the voltage too low error. That's when I checked the voltage again and it was still at the 3.3 and 3.4. Step by step. 1) When I was driving it slowed for a second then went back to normal - basically it was a sudden voltage drop then returned to normal. 2) It slowed down again in a few feet, so I turned it off and unplugged the battery. When I took it up to my truck and checked the voltage I got the 3.3 and 3.4. I assumed the Teken R2 had a cutoff, but I don't think so. I thought I drew the batteries down too much, but it looks like the 3.3v area is still OK. OR is it too low? I figure I probably screwed the pack up somehow. First time running LiPo, so there has to be one casualty.... I just want to figure out what I did wrong. I'm getting another balanced charge unit to go with the ICE. The little one is too slow at .65A. Thanks Greg |
05-17-2008, 10:22 AM | #847 |
Newbie Join Date: May 2008 Location: tallahassee
i just built my ax-10 kit and need a motor and esc. i have always used brushless in other applications and would like to stick to that theme. i really don't know what to choose yet, but based on the info on this site i would go for a quark 33, a crawlmaster 1000kv, and (2) thunder power 3s 13c 1320mah packs run in parallel .this is my first crawler and would like to get the power package right the first time! i will be using the tcs battery plates in the front. will the crawlmaster have to much power and break things often? also will the crawlmaster be a direct bolt on using the axial out-runner mount? thanks in advance!
05-18-2008, 01:11 AM | #848 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
hi john just checking to see if you got my payment for 2 castle sidewinders and castle bullet connectors shipped priority mail to Australia, paid paypal from psthomas1(at)optusnet.com.au on the 10th may for $152 .89 i also sent an email from...but i know you are busy with school and thought i'd just check in here, for my own peice of mind thanks Last edited by some_guy; 05-24-2009 at 01:55 AM. |
05-18-2008, 09:41 AM | #849 |
Pebble Pounder Join Date: Apr 2008 Location: Las Cruces
I tried emailing you through your website with no response and noticed you are on here more, so I will ask here. Have you shipped my battery pack yet? Payment was completed on May 9th. The reason I am concerned is I had placed an order with you on May 4th and received the item on the 8th. Thanks Andrew vltchkr_33@yahoo.com |
05-18-2008, 09:03 PM | #850 |
John my 5 turn on 3s gets pretty warm. I want to get a heat sink for it but since its not 540 size I'm not sure what to get. What do I need to be looking for.
05-19-2008, 05:49 PM | #851 |
Hey John received my confirmation today THANKS!!!! Andrew |
05-19-2008, 06:07 PM | #852 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
05-20-2008, 12:01 AM | #853 |
got your email, thanks john
05-23-2008, 10:21 PM | #854 |
Quarry Creeper Join Date: Oct 2007 Location: Guam
| status on my order
not sure if you got my email. would like an update on my order, #1754. payment has been cleared since 5/20/08. also could we just ship items when motor is available. one more question. i have a mamba max esc. what do you recommend for the settings. motor: 55t battery: 8 cell 2/3a 1500 servo: 5955 TG axial trans: 87/14 vf dig w/ 225MG ccbec at 6v radio: dx3r thanks Last edited by hardheaded; 05-24-2008 at 06:44 AM. |
05-24-2008, 09:00 AM | #855 |
RCC Addict Join Date: Feb 2006 Location: ccxc
Looking into a motor for a semi-basher. Looking to jump it etc. It is an Axial Ax-10 rtr far from stock except electrics. Question is can I drop in your 7t cobalt puller? Do i need a better esc than the ax-1 immediately? And will it run on ordinary nicad and 2/3a cell packs?.........or should I go brushless?
05-24-2008, 11:27 AM | #856 |
RCC Addict Join Date: Nov 2007 Location: BV
how long would a mamba max hold up to two 10t cobalt pullers on 14.4 volts in a 20 pound truck? Is that a terrible idea? I'd like my 1:6 scaler to have some serious balls.
05-24-2008, 01:46 PM | #857 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
John, I tried to e-mail you, but the forum would not let me. I bought a mamba max 4600 kv combo and hyperion 3025-8 from you a long time ago. I use the CC 4600kv motor in my stampede, and the hyperion in my Twin Force. When I puchased the combo, it worked perfectly in my stampede. Every time I have used the mamba max/hyperion combo in my Twin Force, it works good, except it stutters at WOT, almost as if it is cogging. I use a regulator, so I do not think that is the problem. I recently decided to move the controller back to the stampede. The truck cogs horribly, with or without a receiver pack, no matter which battery pack I use. The radio is a Fubuta 3PM, if that matters. Do you have any suggestions? I talked with you about this a long time ago, but we never found a solution.
05-25-2008, 11:33 PM | #858 | |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
thanks for the help. | |
05-26-2008, 07:07 PM | #859 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
John I bought a hyperion EOS0606I AC/DC charger from you on 12/9/07 and have been charging every battery I have successfully on it from the day I got it. I have charged nicd, nimh, lopo and lead acid several times but today when I got home from the weekend and tried to charge my 5000mah 3 cell lipo all I got was OUTPUT CIRCUT PROBLEM so I tried every other battery I have with no luck. I even tried it on my car battery with no luck. The warranty says my selling dealer is my first piont of contact for warranty issues. So what should I do???
05-26-2008, 08:33 PM | #860 |
Whats the latest on the 7t Cobalts? I ordered one last week. Just wondering
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
