07-13-2009, 07:25 AM | #1761 | ||||
07-13-2009, 12:09 PM | #1762 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Hey JRH,how will the programming with your esc work? Regardless make sure you let me know when you get them in hand so I can come pick one up from you.
07-13-2009, 05:26 PM | #1763 |
Quarry Creeper Join Date: Dec 2008 Location: ZETROC
thank you. will attempt to repair.
07-15-2009, 11:29 PM | #1764 |
Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
Hey jrh. I am looking for a new esc. I want to run one of your 25 or 23 torqmaster motors on a 3cell. Looking at the tekin r1. Do you know if it is anygood on the low throttle control? thanks chad |
07-16-2009, 06:27 PM | #1765 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
E-mail's sent.
07-16-2009, 07:48 PM | #1766 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
07-16-2009, 09:03 PM | #1767 |
| repair
jrh, i am sending the cobalt 10 turn to you, 2-3 day mail tomorrow, i attempted to repair/ re-seat the bearing, but was unsuccessful, i also noticed a vibration in the motor, I am not sure if i caused these damages, i forgot to inspect the motor before installing. I would be more than glad to pay for all repairs, parts etc. thanks for all of the great support / pr. |
07-16-2009, 10:03 PM | #1768 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Hi You said the 10t cobalt is the strongest in is class" what other class is there ? So If I want to stay with mambamax, Is the 10t cobalt motor the only option for my single motor 11lb. Super on 3s ? Do you have any 10cobalts left ?how much time to I have left to get one or will there other motors made ? will it be safe to use in a rc4wd 2 speed tranny ? Thanks From: John Robert Holmes |
07-16-2009, 10:07 PM | #1769 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
| Mini Motor
When are you expecting more? Thanks
07-16-2009, 10:14 PM | #1770 | |||||
I think the 10t will be your best bet for 3s lipo use. I have them in stock on the site, but only have a bit more than 100 cans left for building them and about 50 10t armatures left. Once they are gone that will be it. The R2 two speed is ok if you are careful. If they have an HD version you will want that, otherwise the weight of the super may destroy the tranny. It may be a few months on the mini motors, my original manufacturer has decided to stop answering my phone calls and emails. | |||||
07-21-2009, 05:06 PM | #1771 |
did it arrive? how much do i owe u? thanks.
07-21-2009, 06:39 PM | #1772 |
Seems to run fine to me. There is no play in the bearings other than the normal in/out play of the armature in the can. There is some vibration, but this is normal when using an ESC. Especially at half throttle. Not sure what problems you were having really.
07-22-2009, 06:02 AM | #1773 |
Quarry Creeper Join Date: Apr 2006 Location: GUAM
| crawl maste motor
hey john hope you could be some assist on a problem i seem to can not figure out. i currently just up graded from 2s lipo to 3s lipo(what a big diff.)well im running crawl master motors with a sidewinder and i had purchase a castle link to try and program the esc to eliminate this cogging issues im having,but i think i tried nearly a hundred times and still get cogging problems cant you give me some pointers on how to adjust my esc to eliminate this cogging problem? |
07-22-2009, 07:14 AM | #1774 |
Gear as low as possible. Non sensored setups will not be as smooth as a brushed or sensored motor. Be sure your startup power is at high, timing is at low, and that your throttle endpoints are properly programmed.
07-22-2009, 11:27 AM | #1775 |
RCC Addict Join Date: Nov 2008 Location: never been
JRH, will a mamba mac be okay to power a titan 775 10T motor in a single speed emaxx ? if not what motor in you store should i look at ? TIA
07-22-2009, 12:10 PM | #1776 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
MM should be fine for that use... 3S or above though a MM likes an external BEC which makes the MMM at $100 a more attractive option if you are buying an ESC from scratch. John is the HH Mini for the MRC ok on 3s? |
07-22-2009, 04:53 PM | #1777 | |
this the one ??? will this work for an e-maxx basher ? http://holmeshobbies.com/product.php...4&cat=2&page=1 Last edited by JOOTZ; 07-22-2009 at 04:55 PM. | |
07-23-2009, 06:14 AM | #1778 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
Quick question: Just got hold of a Puller 500. It's on a 5.9lb Axial based rig with and R2D, Mamba Max and 3s with a 9 tooth pinion. It seems to run a little hot...should I go to a 12 tooth pinion or will that make it run hotter? Running a tall tire also...Rovers. Really like the Puller 500 on my light rig! |
07-23-2009, 07:44 AM | #1779 |
Upping the pinion would make it run hotter. The 3s lipo is why it runs hot.
07-23-2009, 09:40 AM | #1780 |
John you may have missed this - is the HH Mini for the MRC ok on 3s? |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
