05-26-2008, 10:14 PM | #861 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
im running a hustler super with 2 mm's, 2 hitec 5995tg's {that hum bad} ,2 55t brushed motors, and a nomadio sensor rx. randomly my super will stop and the remote will say low receiver battery, it happens on a full charged lipo, i've tried running 2 lipos on to each mamba max,and it still does it, i dont know why, so as of now i'm rebuilding it , will a bec help any ? if so should i use 1 or 2 ? and i'm not sure exactly how to wire them, the nomadio has 4 channels , 2 for the esc's , and 2 for the servos , can i use a y harness to plug in the bec ? if so ,where should the other end of the y go to a servo or esc? will a servo with less torque help with my power issue? and is it better to solder the battery leads together and use 1 battery or keep the esc's seperate and use 2? sorry for all the questions , but i would appreciate any help you could give, thank you |
05-27-2008, 05:02 PM | #862 |
Quarry Creeper Join Date: Aug 2005 Location: Spokane
Well while I was waiting for the BEC to show up that I ordered from HH I decided to hook up my new Hitec 5955. I have been running a Hitec 645 and wanted to see the power of the digital titanium servo. Here is my setup, OG Revolver, Quark Pro Car 33, Maxamps Lipo 1290mah 3S3P 11.1V Pack, Futaba 3PM w/2.4 FASST. Can the new servo cook the Quark by pulling too much power? I just cooked both of mine and have no idea how.............. I thought maybe the first one just went bad or had some wires touching, so I inspected and didnt find anything. Then I tried my backup and it fried also. Please help! |
05-28-2008, 07:25 AM | #863 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
| BEC Programing question
I am just about to order a BEC from you and I'm going to have you do the programing but I don't know what voltage to to have it set to. I will be using a Hitec 645 servo, the spec's give torque a two different voltages, 4 & 6. I was thinking of having the BEC set for 6.2V for just a little more power to the servo but I don't want to fry it. (I am assuming the the servo Engineer used a safety factor in the design and that over-powering a little would not be too detremental) Thanks |
05-28-2008, 03:59 PM | #864 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
| Scorpion Motors
Is it at all possible to get Lucien Miller's E-mail @ Inov8tive Designs? I lost his addy in that computer crash I lost your e-mail with. Could you please send his e-mail to powerwagon440@comcast.net ? Thanks! He wanted me to give a review of the S-3032 with the extra bearing and I just have to let him know how well it is working. This things weighs a ton, probably close to 20- 25 lbs. Yet, I can not get the motor to stall or roll back. Startup is unbelievably smooth with the MMM and 4C a123 and the power is enough to make anyone laugh like a little school girl! WC |
05-28-2008, 04:34 PM | #865 | ||||||||||||||
MM settings: no punch control, normal timing, max power, forward/brake/reverse, brushed mode, 100% drag, 100% brake That should do it. Quote:
I don't think you want brushless unless you are strictly going for bashing. Quote:
Sure thing sir! | ||||||||||||||
05-28-2008, 05:15 PM | #866 |
Quarry Creeper Join Date: Oct 2007 Location: Guam
thanks for the reply sir. also thanks for the MM settings. |
05-28-2008, 06:29 PM | #867 |
thank you for the info ,,very helpfu,l once again
05-29-2008, 06:57 PM | #868 |
Quote: It could very well fry the internal BEC, especially on 3s lipo. Do you have an RX pack or BEC to see if the ESC can still boot up with external BEC power? The BEC and other parts showed up today. Sol per our conversation I hooked up the Castle BEC and one ESC is still alive........the other however is toast. Thanks for the help! |
05-29-2008, 09:06 PM | #869 |
Rock Stacker Join Date: Oct 2007 Location: Salt Lake City, Utah
John, Thanks for taking time to read my problem. I picked up a new crawlmaster today, got it installed etc (btw awesome tin that its in.) I got my ESC all setup its right I double checked it with a few people, however when I am full throttle and going forward there is about a second delay when I go into reverse. Its like a hiccup. I am using a Mamba Max, 7.4 2S Lipo. I have seen someone talking about their problem on here but I am not able to find it. Can you give me some things to work on. I know I wont be forward and reversing a ton however if I am going up something and start to get top heavy I will need to get on the reverse. Any advice or anyone elses advice would be super awesome. Thanks! |
05-30-2008, 09:35 AM | #870 |
Quarry Creeper Join Date: Aug 2006 Location: Monroe NC
Hey John I just placed an order on your site for a few things. I paid for the USPS Express shipping so it would be great if you could just maybe ship it today so I can have it tomorrow. I am trying to get my rig ready for a comp on Sunday and I don't have a chance without my Holmes power plant. I would say pretty please but then someone would call me gay..... Wait I just said it so pretty please. Paypal receipt # 2905-3813-3725-6495 |
05-30-2008, 11:13 AM | #871 | |||
05-30-2008, 11:29 AM | #872 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
I searched and didn't find anything. Do you know right offhand where I can find some good info on motor timing, specifically with the Integys. Trying to help someone out, but I don't know enough about that type of thing.
05-30-2008, 11:34 AM | #873 |
05-30-2008, 11:43 AM | #874 |
| I normally time at zero. ARe you looking for a how to, or just some info? If you want to advance your timing a bit you can put in about 7* advance for less brush wear and a bit more power without making reverse/brake eat the brushes big time.
05-30-2008, 11:50 AM | #875 |
| Just trying to tell someone over the web how to put theirs back at 0*, but I don't know for sure how the timing marks are on those motors, and haven't been able to find a good pic to show him. We've been over everything on his ESC and TX and everything else and the only thing I can think of is that somehow his timing is off.
05-30-2008, 11:53 AM | #876 |
The end point have been set and the esc is set to forward to brake to reverse. Basicly it happens every other time. If I'm going forward then reverse very quickly sometimes there is a delay. It kind of stutters and the goes into reverse. Thanks again for the help.
05-30-2008, 12:01 PM | #877 | ||
Thats about all I can guess. I think it may be your reverse throttle endpoint, you may try resetting the MM endpoints once more. If it is a bit off it can make the ESC studder. | ||
05-30-2008, 12:09 PM | #878 |
Thanks JRH, that tells me exactly what I need to know, I just couldn't remember how they are.
05-30-2008, 12:37 PM | #879 |
Ok thanks for trying to help. Do you think if I bump up to a 3s it would help the issue
05-30-2008, 12:43 PM | #880 |
Doubful, seems like a hardware issue.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
