03-31-2007, 10:35 PM | #61 |
04-03-2007, 12:53 PM | #62 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
Better pick up some spare MIPs as well, and some wheel bearings. and grade 8 bolts. and maybe a spare diff.:-P
04-03-2007, 01:35 PM | #63 | |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
Wheelbearings, I have not taken one of those out since I redid the rear axle with cut brakes. The grade 8 bolt problem is solved aswell. As for my diffs, like I said before, with 3mm ring gear bolts, I would LOVE to see carnage there. I have run 3 HP through them before with the jumbokongs with MASSIVE ABUSE. I have NEVER broken one since. They just have to be shimmed correctly. Supersteering is on version 3.0. I'm not f'in around anymore. Wait till you see this sh!t!! | |
04-03-2007, 09:46 PM | #64 |
I've seen plenty of MIPs killed by a friggin' Titan motor. and that 3025 will make base jumping easier. No more bouncing off the cliff, just air:-P :-P :-P Can't wait to see super steer v. 3. good thing you did'nt spend 100 plus bucks on a tg servo that is not as strong as it should be |
04-06-2007, 05:26 PM | #65 |
| Kick@$$.... Damnit!!! Kick@$$ its here!!! But it seen the WheelChair and that scared it to death! Not even 10 mins into trying to program it to crawl, it started making a noise, and it got loud QUICK! I don't know if it was damaged in shipping or if it was a defect. One of the magnets dislodged itself from the housing! Waiting to hear back from JRH now... |
04-06-2007, 05:30 PM | #66 |
RCC Addict Join Date: Apr 2006 Location: Brighton
04-06-2007, 05:59 PM | #67 | |
HAHAHA, I'll have to hide the 'Chair from the ladies I guess... Well since the motor is out of service, I'll just have to FINALLY get them monster ends done. I already cut the mounts off the front axle and have a gameplan on the new setup. Figured out the spacers, just need to get rid of this headache so I can get buildin!:neutral: Here is a sneak peek into SUPER STEER 3.0!!! The future is here! I'm talkin FOOT POUNDS!! Bye bye RPM knuckles!!! | |
04-06-2007, 06:10 PM | #68 |
04-06-2007, 08:23 PM | #69 |
Rock Crawler Join Date: Mar 2007 Location: Man Cave!
04-06-2007, 08:27 PM | #70 |
That sucks to hear WheelChair, I just ordered a 3013 and was really jived to get it, hope it works ok. |
04-07-2007, 03:21 AM | #71 | |
I'm sure your motor will be fine, I don't think my mailman likes me very much... These are top of the line motors from what I can see... This one I got was either like I said, bashed around by the men in blue, (even though it has a fragile sticker on it) or it was defective. I looked the thing over pretty good, I believe it is a great quality unit. Wish the bearings were a little larger, but I'm sure they be just fine. My luck has been the worst lately... Murphy's got my a$$ targeted Your motor will rock, you will like it! Test Bashing with the Titan this weekend | |
04-07-2007, 09:58 AM | #72 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I like the steering. How does it weight in comparison to a 1/4 scale servo though? Ft-lbs, .....that would be nice!!
04-07-2007, 11:59 AM | #73 | |
| weight Quote:
With the motor I used I would say the entire setup excluding the cables weighs about 2 ounces... its actually pretty light! The motor that came on the thing weighed a pound itself, Just don't need THAT much power. looked like a motor that would KICK @$$ in a LARGE powerboat! Lock to lock on this setup is about one second. | |
04-07-2007, 06:04 PM | #74 |
Nice, 2 oz's isn't bad at all. I figured it would way a lot more. I can't wait to see it in action again in person.
04-14-2007, 03:34 AM | #75 |
| Wheelchair V6.0!
Well, Here its almost finished. Version 6.0! *5 channel AM-FM *Front Winch *3025-08 - 102 to 1 Ratio *12 GP3300 cells 14.4v *Super Steer 3.0 (Foot Pounds) *Hand Made Aluminum Output Gear *60 degree e-brake *Cut Brakes Just a couple pics of the beasts new look. More pics to come as i get closer to being done! Need a "Powered By:" sticker above the JRH logo. Last edited by WheelChair; 04-14-2007 at 03:45 AM. |
04-17-2007, 06:07 PM | #76 |
Well, Hyperion has let me down twice now. So after talking with JRH for a bit, i believe we found a suitable replacement! Last edited by WheelChair; 04-17-2007 at 06:54 PM. |
04-17-2007, 06:09 PM | #77 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
how much more sack is that motor supposed to have over the 3025-8?
04-17-2007, 06:25 PM | #78 | |
The stator and magnets are 7mm longer. 5mm Shaft on this one.... 1200 watt max it says.... Last edited by WheelChair; 04-25-2007 at 11:39 PM. | |
04-24-2007, 07:15 PM | #79 | |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
I hope super steer 3.0 works out for you because I want to try it now | |
05-08-2007, 08:53 PM | #80 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
any updates? maybe a vid of how super steer v. 30. works? bad a$$ rig |
