Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Dravpnir tries to build something small
Old 03-07-2014, 10:31 PM   #141
Default Re: Dravpnir tries to build something small
Are you buy chance selling any of these innovative products you are making?
steven a rockcrawler is offline   Reply With Quote
Old 03-08-2014, 04:24 PM   #142
Those plastic lockouts that allow bigger bearings looks real good, i'd buy a set for sure if you can ship to Canada and accept Paypal !
daver18qc is offline   Reply With Quote
Old 03-15-2014, 06:14 PM   #143
DravTech
Dravpnir's Avatar
As I do not have a vendor star some of my posts apparently can be seen as a feeler posts, so I have deleted them to not get in conflict with the forum rules.
Dravpnir is offline   Reply With Quote
Old 03-15-2014, 06:21 PM   #144
Damn you, rules ! /shakes fist in the air
I'm sure you'll have a vendor star soon, right ???
Old 03-15-2014, 08:50 PM   #145
Dam.. Half ur thread is gone!! ;)
Things are good when the time is right...
winnerone23 is offline   Reply With Quote
Old 03-17-2014, 04:40 PM   #146
DravTech
Dravpnir's Avatar
Well I was under the impression that the rules said one thing, but they didnīt
The star will turn up one day or the other I am sure, cannot say which day though...
But over to something more fun. Got something really cute from Tomi today. A little while ago I got to borrow his drawings for his trannys that use RC4WD gears. I redesign the narrow version slightly and this is the result
And while I was at it, I mounted a LRP Fusion 380 High Torque motor
In comparison with the original tranny (and the smaller LRP Fusion 370 motor) the NCD tranny is actually smaller...
I have to make a new skid plate for the new tranny but it will be no problem finding room for the tranny in the chassis
Old 03-17-2014, 06:21 PM   #147
Man that tranny looks nice I like it
lowridinjuggalo is offline   Reply With Quote
Old 03-18-2014, 01:14 AM   #148
DravTech
Dravpnir's Avatar
Yepp, it is a really nice one. If you would design a chassis around it you should be able to make a really narrow one. And I dare to believe that all the tranny problems that exist with the original tranny is all gone
Only downside is that I have to find a 32p pinion that accept a 2.3 mm motor shaft. Or if that not possible make a sleeve to use pinions for 1/8" shafts.
Reagarding gear reduction of the NCD tranny and the original one please see below
Original with 10T pinion and 66T Spur - 43.83
Original with 14T pinion and 60T Spur - 28.46
NCD with 6T poinio - 42
NCD with 9T poinio - 28
NCD with 12T poinio - 21
NCD with 16T poinio - 15.75
NCD with 18T poinio - 14
6T is the smallest 32p pinion I have found. I have to order one to check if it is possible to use it with the NCD tranny. It might be needed to grind a bit on the motor plate to get the motor close enough to use such small pinion.
Last edited by Dravpnir; 03-18-2014 at 05:41 AM. Reason: Added some gear ratio calculations
Old 04-07-2014, 10:18 AM   #149
Any updates on this bad boy?
RickM is offline   Reply With Quote
Old 04-08-2014, 02:58 PM   #150
DravTech
Dravpnir's Avatar
Well it has been very little work on this one for a while now. Me and the wife got our first child 2 weeks ago, so tinkering time has been very sparse
But I have received some awesome stuff regardless
Like Blib said in his MRC thread the original diff gear is, well more or less pathetic in its construction... 6 parts and 8 screws in this little guy...
I think this looks much better!
Exceed ring gear and a spool of stainless steel of my own design. Now it is time to start to work on my axle shafts so I can get my axles together with these bad boys.
Today I also got a nice package from Everetty, some 4.2" diameter 1.9" Gold Voodoos
Compared to my home made 4.2" diameter 1.9" red Rovers
Now I think I got everything I need at home, so time to start working on putting everything together!
Old 04-08-2014, 03:01 PM   #151
Looks amaizing mate!
BliB is offline   Reply With Quote
Old 04-08-2014, 03:48 PM   #152
Very nice hoping to see a vendor star in your near future.
Ghost is offline   Reply With Quote
Old 04-08-2014, 08:39 PM   #153
damn you now I'm jealous
thomass14 is offline   Reply With Quote
Old 04-14-2014, 03:45 PM   #154
DravTech
Dravpnir's Avatar
Thanks
There is a saying here in Sweden - "If you wait for something good, you can never wait to long"
Oh, sorry...
I realised a couple of days ago that the only original MRC part I will use in the end is the axle housings... why does this always happen when I build a crawler...
Today I spent an hour with the dremel and after enjoying the wonderful rubber fumes, atleast the tires for my MRC are done!
I left some thread on the inside of the front tires to get some help climbing ledges with the front tire.
Choices....
The 4.2" diameter 1.9" gold Voodoos
The 4.2" diameter red Rovers
Please ignore the wheels, they are only old prototypes and will get replaced with the same kind of wheels that are on the Voodoos.
Old 04-15-2014, 04:33 PM   #155
DravTech
Dravpnir's Avatar
Got a little masterpiece the other day. Bilb was so kind and made me one of his 12T UD gears. Awesome stuff! Big thanks
Together with my spool and the exceed ring gear it runs very smoothly
Tonight I got the time to grind some axle shaft and started to put the rear axle together.
Then I threw on some 0.6" wide wheels with the short Axial plastic hub and the width was 7.25"
Now I just have to find some orange aluminum button head screws and wait for my rear upper link mount to arrive then the rear axle is done!
Old 04-15-2014, 08:11 PM   #156
Ummmmmmmmmm, holy crap!
Sweet, salty, and delightful every single bite....four stars.
MRCrackhead is offline   Reply With Quote
Old 04-23-2014, 03:18 PM   #157
DravTech
Dravpnir's Avatar
Got time to work on this little guy tonight
I noticed in some sportsman thread using dlux modded wraith axles that they used a thinn hub from RC4WD. I ordered a set of them earlier and threaded the holes to M3 and mounted them to me wheels.
If I use these hubs on my rear axle I get a width slightly under 7".
Then I mounted me rear upper link mount that I recieved today and removed the axle housing screws and replaced them with longer screws and nuts.
I also got home the servo plate so I mounted it up on the front axle
Threw on some drag and tie rod to see the steering available and I am not disapointed
Mounted both the front and rear axle to the chassis
Now I have to do 2 major things (and a bunch small things) then it is more or less done. THe major things is to mill out a new skid plate for the NCD tranny and cut and grind the Axial Universals so they fit my locker and front axle.
But I could not help myself so I put on some wheels
It is a bit high I think, but get quite low at max compression atleast.
Not the biggest flex, but hopefully enough
I test mounted the battery behind the servo and it fits very nicely
Old 04-23-2014, 09:47 PM   #158
it will never work, just send it to me for proper disposal and ask no questions....
but really it looks great, hoping to see some of your innovations up for sale soon
lots of great things happening for the 1.9 class lately. we need to keep this class alive
Old 04-23-2014, 10:38 PM   #159
^ +1 to all of that! So much awesome in this thread
Liv3mind is offline   Reply With Quote
Old 04-24-2014, 04:13 AM   #160
You are a Freak ! from this is my little MRC far far away :-(
Great work !
der-Gep is offline   Reply With Quote
Dravpnir tries to build something small - Similar Threads
Dravpnir tries to build something even lighter Dravpnir EnRoute Berg 88 08-03-2014 02:58 PM
Dravpnir tries to build something light Dravpnir EnRoute Berg 125 04-23-2014 06:01 AM
small build irollgen4s Axial Wraith 1 12-05-2011 08:49 PM
Anyone build a small lathe? colonel Tools, and Procedures 16 01-17-2010 05:52 PM
