05-19-2019, 07:03 PM | #281 | |
Pebble Pounder Join Date: Jun 2018 Location: SD, CA
| Re: ECX Barrage upgrades Quote:
How difficult is it to cut with a Dremel? I'm used to cutting bolts, screws, and Allen wrenches down to size, is that experience similar? Do I just use the measurements off the stock shafts? Sorry for all the questions, I only ordered one pair. | |
05-19-2019, 08:20 PM | #282 |
Just clamp it in a vise and cut it off. Smooth cut the first time and deburring is simple, too.
05-19-2019, 08:37 PM | #283 |
Here's the most recent test of my setup so far. It crawls really good with the 9t pinion and servo board esc. Waiting on steel drive shafts, then maybe it will rollover less. https://youtu.be/C6BBTDKvTSI Last edited by Xrayray; 05-19-2019 at 08:40 PM. |
05-24-2019, 08:04 PM | #284 |
Rock Stacker Join Date: Feb 2018 Location: Alaska
Does anyone know the teeth count of the axles gears? I blew the rear on one of mine. I am gonna scab in a scx10 axles setup maybe. I am likely gonna end up ordering a complete set of the one the Chinese alloy ones. Have any new people done that swap? I would just use what I have but the front axle housing doesn’t have a way for the servo to mount. Not sure it would work any other way on this rig.
05-25-2019, 10:29 AM | #285 |
My wpl axles are out for delivery today!
05-25-2019, 10:32 AM | #286 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Sent from my LGMP450 using Tapatalk | |
05-25-2019, 07:27 PM | #287 |
Hey guys, just a quick review of the steel WPL driveshafts: 1. they took a while to cut, because of the material 2. one U-joint pin fell out from the vibrations of the Dremel (pushed back in with pliers) 3. another U-joint pin worked itself halfway out after an hour run in the backyard. 4. fits great 5. overall not too happy; I don't think it will last two packs on the trail until a pin falls out on its own. Any thoughts or fixes for those U-joint pins? Can they be replaced with anything else? |
05-25-2019, 09:07 PM | #288 | |
Weird. I haven't had any issues with the pins on mine. Being that they are steel. You may be able to heat them and wick some solder in there. | |
05-25-2019, 09:34 PM | #289 | |
As far as the ESC, it's a little late but the RGT ESC/RX alone is $15 on AsiaTees Sent from my LGMP450 using Tapatalk | |
05-25-2019, 09:42 PM | #290 |
For the pin popping. Roll pins. Not sure on the size needed. But here’s a 1.5mm example. https://rover.ebay.com/rover/0/0/0?m...2F172250950757 |
05-25-2019, 10:21 PM | #291 |
Hmm roll pins... great idea! Ive had problems wicking solder into things so i might try this. I was thinking of using a 1/10 traxxas body clip cut real short. Last edited by Xrayray; 05-25-2019 at 10:26 PM. |
05-27-2019, 02:32 PM | #292 | |
05-29-2019, 07:54 AM | #293 |
Newbie Join Date: Aug 2007 Location: Rochester
Simple solution is to find the right size heat shrink tubing and put a small piece around the collar to hold the pin in place. Material is pretty durable and can easily be replaced and removed when needed.
07-11-2019, 11:40 AM | #294 |
Rock Stacker Join Date: Jun 2019 Location: Fishers, In.
I have a Barrage and, against my better judgement, I'm about to do some mods to it. Wheels and tires ordered. With those on the way, I have been thinking about motor/ECS upgrades. Seeing how this is new to me, would anyone have input as to whether this motor might fit? https://www.amainhobbies.com/hobbywi...Uylxvm1LpFdIuQ Thanks in advance. |
07-11-2019, 01:12 PM | #295 | |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
07-22-2019, 06:34 PM | #296 |
Rock Stacker Join Date: Nov 2005 Location: Orange County
| Re: ECX Barrage upgrades |
07-22-2019, 08:01 PM | #297 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
07-23-2019, 09:45 AM | #298 |
What's the current hotness for shocks for these little trucks?
07-23-2019, 10:40 AM | #299 | |
Check mine out. Bigworm’s SCX24 Build https://www.hobbyrecreationproducts....lled-shock-set | |
07-23-2019, 11:28 AM | #300 |
Thanks!
ECX Barrage upgrades - Similar Threads | ||||
Best First Upgrades - ECX Barrage | Mancub | Newbie General | 89 | 05-16-2018 06:44 AM |
Ecx barrage trail armor upgrades | nerby149 | General Scale Talk | 3 | 01-23-2017 12:46 PM |
ECX barrage | Cpyonker | General Crawlers | 7 | 12-21-2016 09:18 PM |
