11-29-2013, 07:38 PM | #161 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
| Re: Szczerba's Tow Rig
Awesome job on the cab cuts The cutter I have is basically the same, just a few years older. Works great |
11-30-2013, 02:14 AM | #162 |
Rock Stacker Join Date: Apr 2012 Location: Whakatane
Awesome build mate! Love where this is going! And im impressed with your innovation and motorvation! Keep it up cant wait to see it run!
11-30-2013, 05:40 AM | #163 |
Pebble Pounder Join Date: Dec 2011 Location: On, canada
keep it going man, looks awesome. It's gonna be even better with that custom cab you're making. loving it
11-30-2013, 11:56 PM | #164 |
Newbie Join Date: Dec 2010 Location: Australia
Instead of going over the cut in the styrene so many times, try just doing 1 cut to score it, then just bend and snap. Saves a hell of a lot of time and effort, and since you're only doing 1 cut, less chance of a slip. End up with a neater edge too. Try it on a scrap piece, works a treat. |
12-01-2013, 06:26 AM | #165 |
| Szczerba's Tow Rig
Thanks guys. On cutting the styrene I only have to make about 9-10 firm passes and the piece is cut clean. I tried just scoring a couple times but one or two passes of scoring wasnt enough and I would end up have to score it more. I got in a rhythm after a few pieces and knocked em out quick. Got all the longer beef tubes installed. Also, drilled holes in the chassis for "shock" mounts. Ill have to grind some of the threads off the "shafts" so they ride smooth against the frame hole. The 6/32" shafts are 2" long screws with the heads cut off. Ride height can be adjusted by tightening down or loosing on 6/32" nut. Used an bigger bit for frame hole. One pair of Jeepindoug crawler cup springs per "shock" from Crawler Innovations helps with this setup too. ... Last edited by Szczerba; 12-01-2013 at 06:44 AM. |
12-01-2013, 09:34 AM | #166 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
NEEDS MORE COWBELL!!! And I need more photos of this cab creation that your building.... out with it man... |
12-01-2013, 10:09 AM | #167 | |
12-01-2013, 08:40 PM | #168 |
This is my first kinda "scratch" built styrene project. Go easy! Mocked it up to see how everything fits. Looks like this roof panels will need to be recut. Don't work out. Sittin Sittin Without fender pieces Start of fenders Money shot! ... |
12-01-2013, 08:45 PM | #169 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
Very nice. Good luck. That's going to look really good when done. Better you than me trying to glue it together. I would make such a mess trying to glue and clamp it all together. Sent from your moms house. |
12-01-2013, 09:20 PM | #170 | |
| Re: Szczerba's Tow Rig Quote:
using this thread for styrene gluing guidance ☆ The Chop Shop What Glue to Use For Body Work/Repairing Cracks in Plastic and Why ☆ | |
12-02-2013, 03:23 AM | #171 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
Turning out nice. I'm using some 1/4" angle in all my joints. I know how you screwed up the roof too I did the same thing on the hemtt. I just cut a piece as wide as the rise on that angle not thinking that it would need to be longer. Hardest part is planning how to work it all together where you have access to everything. I'm making the roof on mine removable. Again, rigs coming along great.
12-02-2013, 07:19 AM | #172 |
Looking great so far!
12-02-2013, 08:46 AM | #173 | |
Thanks. I was hoping to move faster on this build but this cab is going to take some time. I will need to make upperlink mounts for the axles and get the trans mount in place. | |
12-03-2013, 08:17 PM | #174 |
Creeping along with styrene fab. Redid the upper roof section. Cut the back window out. And made door armor. Also made a new windshield piece with a longer skirt. Grill material purchased. ... |
12-03-2013, 08:36 PM | #175 |
Newbie Join Date: Nov 2013 Location: Arkansas
The doors look good and the mesh is going to look great.
12-03-2013, 08:44 PM | #176 |
| Re: Szczerba's Tow Rig Thanks. I just made two copies of the "doors" to lay over the door area to give it some definition. Thinking about making a similar piece for the extended cab area. I am ready to start gluing this thing together and make some progress. |
12-03-2013, 09:12 PM | #177 |
Extended cab panel. ... |
12-04-2013, 05:01 AM | #178 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Pretty awesome Shane!
12-04-2013, 07:45 AM | #179 |
| Re: Szczerba's Tow Rig Thanks, this cab is turning out to be a beast of a job. I think I am almost to the point of being able to start gluing it together. I still need to make rear axle upper links but the flexing motion is an upward arc due to the lower fixed arms. I am trying to figure out in my head how to control axle wrap and side to side motion. I thought about a simple panhard for the side to side and maybe a shock with a firm spring for the upper link? I don't think a traditional 3rd upper link will work but I need to mock it up and see. |
12-04-2013, 07:50 AM | #180 |
Adding the panels for the doors really made it look good. Gave it depth. Nice work.
Szczerba's Tow Rig - Similar Threads | ||||
f350 tow truck/ tow rig | bbnate804 | 1.9 Scale Rigs | 13 | 11-19-2012 07:15 PM |
Big Rig tow rig | codycodeman16 | General Crawlers | 1 | 02-05-2010 09:43 PM |
Tow rig # 2 | braceysdad | 1.9 Scale Rigs | 58 | 06-27-2007 01:08 PM |
Tow rig #1 | braceysdad | 1.9 Scale Rigs | 46 | 06-11-2007 11:06 AM |
New Tow Rig | Will | Chit Chat | 10 | 07-22-2005 12:02 PM |
