View Poll Results: Which is better: Yeti or Rock Rey | |||
Axial Yeti | 21 | 28.77% | |
Losi Rock Rey | 45 | 61.64% | |
Equal Rock Racers | 7 | 9.59% | |
Voters: 73. You may not vote on this poll |
03-15-2017, 06:49 PM | #101 | |
RCC Addict Join Date: May 2009 Location: Weston
| Re: Yeti vs Rock Rey Quote:
Fair enough but I am only referring to the Rock Rey and Yeti as the thread suggests. | |
03-15-2017, 08:55 PM | #102 |
Pebble Pounder Join Date: Aug 2015 Location: Red Hill, PA
| Re: Yeti vs Rock Rey I'm finishing up my sensored brushless install this week hopefully (waiting on waterproofing materials). Once the fresh snow melts I hope to have my rock rey out on the trail and climbing too. If I remember I will mount a go pro to my controller and take some video.
03-20-2017, 12:59 AM | #103 | ||||
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
- I have not seen this done to date, but I may have missed it. However, I have seen many convert their wraiths or bombers to IFS (and the odd slash to solid rear axle). - I would also ask if this ifs/irs crawler that you propose could be built for a reasonable cost (ie the cost of a rtr yeti, its 2-speed upgrade, and a cheap set of tires)? - Will this new crawler of yours maintain any of its SCT goodness when complete? What I find appealing about the yeti is that it can crawl decently on the rocks, yet still do a stable 30+ on the dirt and gravel. Quote:
03-20-2017, 06:50 AM | #104 | |
It has been a belief they live axle is better but people are proving otherwise for U4 or even light crawling/trail running. The DMG with his B2B and UCFAB with the FIS PRT. I hope to retain most of the SCT goodness. While it will run a little higher it will also have more static droop to help keep CG down. I thing running 30mph would be slow but it depends on how I'm going to power it. Probably 1/8 scale 1800-2200 on 4s. I AM going to try it. I just have to decide if I want to tear apart old faithful to do it. I have an old SCT410 and a .3. I might just find another original roller for cheap and go with that. I have a lot of good races with my 410, it's like an old baseball glove. | |
03-20-2017, 04:13 PM | #105 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Dan Wilson of VP had been posting pics of a Tekno SCT set up for U4. It had a cage on it and looked pretty cool. I have a barely used SCT sitting here and I'm trying to figure out what to do with it. Might just try to get the Losi SCBE cage/body to fit on it. |
03-21-2017, 05:43 AM | #106 |
Rock Stacker Join Date: Aug 2007 Location: Ann Arbor
| Re: Yeti vs Rock Rey |
03-23-2017, 09:55 PM | #107 | |||
03-24-2017, 04:39 AM | #108 |
My opinion is that a good brushless system will provide everything you would ever need without a 2-speed. No more additional moving parts that could potentially fail. I decided to get started. |
03-24-2017, 06:13 AM | #109 |
I had recently put in a Castle Mamba Monster X and Brood Racing 550 2600KV sensored motor. I also installed a 10 tooth pinion (compared to a 12 stock). Slow speed control is excellent, still had decent speed on 2S, but 3S it should rip. Guess my 2 speed will be my battery voltage. Crawling/Trailing I will run 2S, go fast stuff will be 3S. I agree with John, 2 speed means more moving parts to maintain and more things to go wrong. 2 speed are a pain in the butt IMO. |
03-24-2017, 07:07 AM | #110 |
RCC Addict Join Date: Jun 2016 Location: Germany
Never had issues with my 2 speed in my Yeti. Important is to set endpoints correct and use a fast servo. Mine shifts like butter even under throttle. So i can switch between Trail/crawl and go fast on the fly. And it minimizes the disadvantage of my sensorless CC 1410 if i Trail/crawl. sent by magic_yeti |
03-24-2017, 08:01 AM | #111 |
That makes sense because you are not using a high quality sensored system. Still doesn't take away the fact you have added more moving parts that could potentially fail.
03-24-2017, 08:10 AM | #112 |
I love my two speed, works well with a quality sensored system. In low it will go through anything, in high it goes over most things. I like the extra wheelspeed..... a bit of a gimmick, but gives a little extra Hang up and Drive |
03-24-2017, 08:33 AM | #113 | |
sent by magic_yeti | |
03-24-2017, 12:21 PM | #114 | |||
In real life, I am a control systems designer/programmer/integrator, so a little added complexity in my RC cars fine by me. And, I'm still running the RTR bevel gears in the front of my truck and I like how quiet the plastic spur gear is. But, I'll watch to see if you guys can come up with alternate solutions to the question of versatility. | |||
04-16-2017, 05:38 AM | #115 | |
Quarry Creeper Join Date: Feb 2015 Location: Douglasville
04-16-2017, 06:43 AM | #116 |
04-16-2017, 08:27 AM | #117 |
Newbie Join Date: Mar 2017 Location: ELKHORN
Jec is the way to go brother on four rigs I use his components Sent from my XT1650 using Tapatalk |
04-17-2017, 04:57 AM | #118 |
04-17-2017, 07:30 AM | #119 |
Told you love them Sent from my XT1650 using Tapatalk |
04-17-2017, 08:05 AM | #120 | |
I never said it was a weak link. Anytime you add additional moving parts you are increasing the risk of failure. Doesn't matter what you are talking about, that's just the way it is. I still run the plastic spur in my Bombers and Yeti without a problem. | |
Yeti vs Rock Rey - Similar Threads | ||||
Losi Rock Rey 4WD Rock Racer Open for Pre-Order | RPP Hobby | RPP Hobby | 1 | 01-04-2017 06:18 PM |
Added section for Baja/Rock Rey | Wes S. | Comments, Suggestions, and Help | 2 | 01-04-2017 09:28 AM |
Losi baja rey | snowman13 | Vaterra Twin Hammers | 3 | 05-12-2016 07:01 PM |
Renegade Rock Runners @ Marina Del Rey, CA + 4 Wheel Steer YETI!!! | 4x4Jay | Videos! | 2 | 02-13-2015 04:53 PM |
Renegade Rock Runners @ Marina Del Rey, CA! January 31st | 4x4Jay | California | 21 | 02-13-2015 03:51 PM |
