Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Josh's Bully 2
Old 08-21-2014, 07:12 PM   #141
Default Re: Josh's Bully 2
Not ideal.
It is 4mm.
I am going to try to get the pin dead center of the king pin.
Then cut the flats and silver solder the sides to keep it centered.
Hopefully this will not get it hot enough to make them brittle.
josh6575 is offline   Reply With Quote
Old 08-21-2014, 07:41 PM   #142
Originally Posted by josh6575 View Post
Not ideal.
It is 4mm.
Why did you go with these over the thicker Kyosho shafts?
Calderwood is offline   Reply With Quote
Old 08-22-2014, 07:22 AM   #143
Which Kyosho shafts do you recommend? A friend had these laying around.
Old 08-22-2014, 04:29 PM   #144
Found something neat!
Old 08-22-2014, 04:35 PM   #145
Good find! Make it happen!
ROWDY RACING is offline   Reply With Quote
Old 08-22-2014, 04:39 PM   #146
Looks like an awesome idea. 50 degrees and 5mm shaft. I hate to spend 100 on axles that I have no idea of their longevity. Any body know anything about these.
Old 08-22-2014, 06:06 PM   #147
Be a pioneer.
Old 08-22-2014, 06:55 PM   #148
Ifw162b are the truggy shafts and are longer than a wraith long side. They aren't quite 5mm but they are closer to 5 than 4. I can't remember off the top of my head and my calipers have gone missing in the move I just made. I'm working on having chromoly 5mm inner shafts (and possibly complete chromoly universals) made for a few different vehicles but we are still working out the details.
Old 08-23-2014, 07:25 AM   #149
Originally Posted by ROWDY RACING View Post
Be a pioneer.
My Paypal is $90 lighter.
Looking at the pics it looks like they are not going to fit in the C.
Here comes a bunch of thinking.
Old 08-25-2014, 02:41 PM   #150
I purchased another set of 0 degree knuckles from RC4WD to have a back up set up for worlds.
The bushings are way too short.
The ear on the knuckle is 5mm.
The boss on the bushing is only 4.75mm.
Interference.
They responded quickly to my email and asked for some pics.
I hope they go measure their stock.
I know of one other set purchased and the bushings were the same.
Old 08-29-2014, 05:41 PM   #151
So the bushing weirdness is being taken care of by RC4WD.
Their is not any front replacement CVD's in stock so I had to come up with something else quick.
My friend Bob come up with a great idea to move the outer bearing out to make room inside for the truggy axles.
Cut down some knuckles to bolt to another set. Drilled out the C's and removed the bearings behind them.
Also I plunge milled the inside of the knuckle down 1.1 mm for the bearing to move in. Made a bushing to use the smaller outside bearing on the inside. 16 od 12 id 2.4 thick. This got the u joint pins lined up with the king pin.
Old 08-30-2014, 11:00 AM   #152
Clever!
Old 08-30-2014, 05:47 PM   #153
Got the hubs figured out.
Used bully 1 hexes and Vanquish .725 hubs.
I don't like the Orings that retain the pins.
Clipped Tmaxx springs to make a snap ring.
5mm cap screws to hold the wheels on like the bully 1 V6 axles.
Old 08-31-2014, 02:11 PM   #154
The steering is a little stronger now even though the new axles took care of the stalling. Added some arm extensions that Rowdy sent me. Thanks Chris.
Old 09-12-2014, 05:42 PM   #155
Get em yet?
Old 09-12-2014, 06:18 PM   #156
I have not heard anything from them yet. I'll give it another 10 days before I start bugging them. I am anxious to get ahold of the axles. They are just damn neat! Hope they show without a hassle.
Old 09-12-2014, 06:29 PM   #157
The ultra compact driveshaft " Real Constant Velocity "
Old 09-12-2014, 06:50 PM   #158
I saw those too. You can find them on ebay for the tourning cars. The ones I found didn't look beefy enough to take the torture of crawling.
Old 09-12-2014, 06:53 PM   #159
I think they are called Double Cardan Joints.
Old 09-24-2014, 06:08 AM   #160
Get em yet?
One month later and no axles.
Opened a pay pal dispute.
Seller replied "I do not have any of your information, would you like us to send you a set or a refund.
I'll take the refund.
Josh's Bully 2 - Similar Threads
Josh's villain landon4 Axial AX-10 Scorpion 6 04-21-2014 08:24 AM
Josh's μCrawler Mike Rawler Losi Micro-Rock Crawler 6 10-13-2013 11:52 PM
Josh's tj ttc upoveryou 2.2 Scale Rigs 3 03-16-2011 02:35 PM
josh's scx-10 (first scaler) josh97 Axial SCX-10 6 04-22-2009 09:19 AM
