Thread: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS )
Old 11-19-2015, 09:36 AM   #221
Default Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS )
Originally Posted by sb4pro View Post
No says UP TO 100 we will save 40 on it cause it's priced between 400 and 499 . Basically we save 10%
January for sure ill get mine
HARDRIVE is offline   Reply With Quote
Old 11-19-2015, 01:41 PM   #222
I'm just gonna play it by ear if it comes in early in December I'll use the coupon and get it that way if not I'll wait til January after all what the hell its only money lmao
sb4pro is offline   Reply With Quote
Old 11-20-2015, 10:27 AM   #223
Hahahah true its only money spend it you cant take it with you
No funds for rc right now gotta wait till january
To many gifts sigh i hope someone will give me a nice rc for xmas hahahahha
Old 11-24-2015, 10:49 AM   #224
Anybody knows if the rtr tf2 has a built in lvc on it?
If not can someone reccomend a lvc for it?
Thanx
Old 11-24-2015, 11:31 AM   #225
Thanx
Esc is a brushed model called the Outcry
Old 11-24-2015, 12:55 PM   #226
Spec page for the TF2 Mojave 2 RTR:
RC4WD Trail Finder 2 RTR w/Mojave II Body Set
Spec page for the Outcry ESC included with the RTR:
Outcry Crawler Speed Controller ESC with TurboBEC
Instructions for the Outcry ESC:
http://www.killerkrawler.com/images/...structions.pdf
Accepts up to 4S Lipo, but you would need an external low voltage alarm or cutoff.
new2rocks is offline   Reply With Quote
Old 11-24-2015, 02:18 PM   #227
Im all confused with this
Bec and lvc
Arent they different?
Does the bec act like a lipo cut off?
Old 11-24-2015, 02:47 PM   #228
Something like this is what im talking about
Will this be good on this rig
Simple to use Lipoly low voltage alarm that is small and light for on board use, plug's into balance lead for detecting low voltage on individual cells. A loud alarm will sound and LED will change from Green to Red if any individual cell drops to 3.3v or below.
Spec.
Lipoly Range:*2s~4s*******************************
*38x25x11mm***
Weight:*7g
Voltage Accuracy:*0.03v
Low Voltage Alarm Threshold:*3.3v (per cell)
Old 11-24-2015, 05:39 PM   #229
CORRECTED: Lipo compatibility and BEC are totally different things. The waterproof Outcry (part # ) has a Lipo low-voltage cutoff, but the non-waterproof Outcry version listed in the TF2 RTR specs (part # Z-E0007) does not. If an ESC is not Lipo-compatible, you can use a Lipo if you add an external low-voltage cutoff and you make sure that your Lipo pack doesn't exceed the max voltage spec for the ESC. The low-voltage alarm that you posted a pic of will warn you but won't cut off power, so you'll need to make sure that you unplug the battery when the alarm goes off.
Old 11-24-2015, 06:44 PM   #230
Originally Posted by new2rocks View Post
Lipo compatibility and BEC are totally different things. ESCs that are Lipo-compatible, like the Outcry ESCs, have a built-in low voltage cutoff, so you don't need to add an external cutoff or alarm. If an ESC is not Lipo-compatible, you can use a Lipo if you add an external low-voltage cutoff and you make sure that your Lipo pack doesn't exceed the max voltage spec for the ESC.
Harddrive you will need a low voltage warning module as the outcry has NO lipo cutoff my rtr came with it and its clearly stated it is lipo capable but has no cutoff if you look at the rc4wd website every outcry they have states NO LIPO CUT OFF! The lv warning you have shown will work i believe its basically a decased venom copy
scalemadness is offline   Reply With Quote
Old 11-24-2015, 07:05 PM   #231
Ok so which one is it lolz
2rocks says it has a lipo cutoff on the rtr esc
Scalemad says it doesnt have lipo cut off
Lolz
Old 11-24-2015, 07:18 PM   #232
Look at the rc4wd website they clearly state no lipo cutoff i have no clue where he got his info but i have that esc sitting in my parts bin it definetely has no lipo cut off
Old 11-24-2015, 07:29 PM   #233
yup youre right i did check and double triple check
Ill order this lipo cut off i posted
Seems easy enough to use for a newbie like me
Or is there anything better than that one i posted?
Ill be using 2s lipo battery
Old 11-24-2015, 07:44 PM   #234
If you can find one with a display its nice to be able to visually see the voltage at times too. But that one will work as well just remember its not waterproof
Old 11-24-2015, 07:52 PM   #235
I stand corrected. The waterproof Outcry that comes on the D110 RTR has a lipo cutoff. The non-waterproof version does not. I've edited my prior post. Apologies for the confusion.
Old 11-24-2015, 08:47 PM   #236
Ok now I'm confused. Does this mean the rtr esc is LIPO ONLY or can I still use Nimh ?
Old 11-24-2015, 09:21 PM   #237
RTR ESC can use Nimh.
Old 11-24-2015, 10:13 PM   #238
Thanks rocks had me worried for a sec lol
I had a bad experience with LIPOS and swore them off . Even use a 7 cell in my Yeti TT . Run time sucks but I just run more than 1 pack . To me it's worth the hassle , just seems safer cause I'm old school and have always ran Nimhs . Hell I can even remember the nicad days lol . I'm gonna run a 6 cell 5000 mah in the tf2 so run time shouldn't be too bad .
Old 11-24-2015, 11:14 PM   #239
Wahahah just when i was about to jump in on lipos
I see this kind of post lol
Im really really worried about lipos also
Havent tried it yet
Cause of those fires dont over chageddont over discharged etc.
Storage charge heck
I think to much to remember for a battery lol
Ugh never mind ill stick it out with nihm also darnit lol
Old 11-25-2015, 12:29 AM   #240
Havent tried it yet
Storage charge heck
I can see using LIPOS for racing or high speed bashing but for us scaler guys who go slow I don't see much advantage other than run times . Even then I just bring 3-4 packs and I can run just as long . It's not that I dislike LIPOS like I said I know they have their advantages I just feel more comfortable with Nimhs cause it's what I grew thru the hobby with . My bad experience with a lipo was I charging one and had it flame up on me . After that I've been gun shy to use them again .
RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) - Similar Threads
RC4WD Mojave Body Set For Trail Finder 2 (Camo style) rustneversleeps RC4WD Trail Finder 2 5 09-04-2015 03:58 PM
RC4WD Complete Mojave Body Set for Trail Finder 2 in both Yellow and White. Rckcrwlr General Scale Talk 9 06-10-2012 09:08 PM
