10-02-2012, 04:10 PM | #61 |
Newbie Join Date: Feb 2012 Location: Surrey
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho
My LHS rep suggested to just bolt up my old stock servo and it will hold in place and save my from spending more $ till later on a new radio and so on. Sounds like a great idea to me!
10-02-2012, 09:33 PM | #62 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
Just a FYI , if you are going to use a micro servo, you can install it under the servo rail (with a little grinding off the raised hump) and have a lot more room for wiring and such, plus no interior contact. Last edited by Jeepfixer1; 10-02-2012 at 09:44 PM. |
10-02-2012, 09:56 PM | #63 |
Pebble Pounder Join Date: Apr 2007 Location: va beach
Very nice! I had this very idea acouple days ago, should help with COG to!
10-08-2012, 08:46 PM | #64 | |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Quote:
has anyone had any problems with the shift rod spinning in the transmission? happens to me every once it a while and i have to keep on adjusting it back so i can shift into first again. | |
10-08-2012, 09:51 PM | #65 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
I use a hitec HS65MG with a servo saver. U can get away without grinding the bump off if u use a couple of spacers Came up with the same idea about month ago. Posted it up on "rckcrwlr's Wraith 2 Banger" thread in the vendors section under rc4wd. As for the shift rail spinning use a little blue loctite on it to stop it from spinning Last edited by Rockridge; 10-08-2012 at 10:05 PM. |
10-16-2012, 08:08 AM | #66 |
RCC Addict Join Date: Apr 2008 Location: Singapore
This tranny completes 2JSC Poison Ivy Monster. Woo hoo! |
10-18-2012, 10:01 PM | #67 | |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
10-21-2012, 09:56 AM | #68 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
how are these holding up to big hp?? |
10-21-2012, 11:20 AM | #69 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
Yeah, I am curious. I plan on using one in my ulrta4 ttc brushless build. Hopefully it can take some serious abuse.
10-22-2012, 07:04 PM | #70 |
anyone try switching up the spur gear?? what brand r u using/ which ones r compatible??
10-22-2012, 08:04 PM | #71 |
11-06-2012, 02:00 PM | #72 |
Newbie Join Date: Sep 2012 Location: Cambridge, East London, South Africa
Hi Guys I have installed the 2 speed transmission and a Novak Balistik brushless combo (wraith edition) in my Wraith. I now have a whole new experiance, actually the difference is day and night. I chose to make the 2 speed a manual change, I created a slide selection wilh a locking pin to ensure no gear change during an accident. I want low gear for crawling and hi gear for racing around like a lunitic the rest of the time. year what fun! Unfortunately I cannot join most of you in a 4x4 challange as I live in South Africs, but not to worry I do have buddies here that think this is better that a full size 4x4, if not better it is much cheeper. |
11-14-2012, 01:14 PM | #73 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
I swapped out the stock spur for a Robinson Racing 48 pitch unit since my trans came without a setscrew for the included 32 pitch pinion. Seems to bolt up just fine |
11-14-2012, 06:41 PM | #74 |
Pebble Pounder Join Date: Sep 2010 Location: houston
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho |
11-18-2012, 05:34 AM | #75 |
Newbie Join Date: Dec 2010 Location: In my tow truck..
I'm running a very heavy (9lbs+) tube/scx10/2.2. It is using the"stock" rc4wd pinion/spur combo. I'm running a Novak 13.5 ballistic s.c. Motor and matched esc. I've been practically drag racing this thing for weeks. I haven't had any issue with the shifting, or operation of the Tranny itself. I bound up my front right tire in a first gear run (half throttle) the output shaft broke at the snap ring collar behind the case. Take it for what you want, but thus far, I still would rate it at a solid "A.." for ease of instillation, cost and overall quality/durability.. Why have a civilization anymore, if we are no longer interested in being civilized?? |
11-18-2012, 05:37 AM | #76 |
| Why have a civilization anymore, if we are no longer interested in being civilized?? Last edited by eric113; 11-18-2012 at 08:12 AM. |
11-18-2012, 06:16 AM | #77 | |
11-18-2012, 09:18 AM | #78 |
11-18-2012, 05:13 PM | #79 |
I had a chance today to test mine out in an SCX10 trail rig with a 35T/3S. Shifts butter-smooth and 1st gear is really nice for steep downhilling, no drag brake needed. Loads of torque for super slow inching your way up and over the rough stuff. 2nd gear has a decent amount of getup and go also. I'd have to say it's probably one of the best upgrades for an SCX10, and it sure is nice to have the option to drop 'er in low when you need to .
11-18-2012, 06:28 PM | #80 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
After seeing Traildawgs 2 speed working today I have to say....... I Want one! |
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho - Similar Threads | ||||
Axial Wraith & Honcho | Trailing in the Forest | burtonkidd | Videos! | 1 | 01-15-2012 03:47 PM |
2 speed transmission for honcho | Dfrog | Newbie General | 18 | 03-28-2011 07:52 AM |
