01-14-2012, 01:14 PM | #21 |
RCC Addict Join Date: Oct 2009 Location: west coast..
| Re: Vehicle class questions (legality for event)
Thanks for the info I am wider and taller than I need to be... Will match wheel base to body once it arrives..
01-14-2012, 01:28 PM | #22 | |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
| Re: Vehicle class questions (legality for event) Quote:
01-14-2012, 01:48 PM | #23 | |
RCC Addict Join Date: Sep 2009 Location: sacramento
01-14-2012, 05:36 PM | #24 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
What is the total length of the body/frame/bumpers less the stinger ? What is the wheelbase ? Give me those two and I will not be confused anympre | |
01-14-2012, 06:31 PM | #25 | |
Oh my, I thought I was the only one confused here MY BAD after about the 50th time of reading i think I was misunderstanding the 3" rule. "longer" than wheelbase. WB is 11 3/4 the Chassis is 15 1/4 because my bumper is not wider than frame. And I also forgot we did cut the frame down. So is that no longer considered a "full rail chassis"? Body is 13 1/8 maybe 1/4 Pictures help not the typical class rig but ones are just over minimum allowed. | |
01-14-2012, 09:04 PM | #26 | |
So far, it seems your width is fine as it the length.... Naked pics would clear up the chassis questions for sure. | |
01-14-2012, 11:13 PM | #27 | |
BTW I have a feeling this kind of stuff wasn't clear last year when my buddy thought he was building a c2 and after getting there found out is was more like c1 compared to all the stuff in c2. He let off some steam in the old thread last week Body is 13 1/4 | |
01-14-2012, 11:39 PM | #28 |
Frame looks fine. The only other item I see that is needed to be legal for C2 is a front bumper. That should be easy to add,just bolt it on the the frame rails and no welding or disassembly would be required. Remember, the bumper only needs to be wider than the frame so it doesnt have to interfere with the looks of your rig if you choose to go minimalistic with it. One other item that may come into play is min scale points, those have not been announced yet, so I cant speak to those. Dont forget to abide by the other requirements of the class like tire size Hope that answers all the questions Last edited by hotwheels000; 01-14-2012 at 11:41 PM. |
01-16-2012, 11:10 AM | #29 |
Rock Crawler Join Date: Apr 2008 Location: Albany
Thanks for spending time helping others get ready for the event. Very cool. You must be a hell of a nice guy. LOL I look forward to meet you at Lucia. Evan |
01-16-2012, 01:34 PM | #30 |
| Re: Vehicle class questions (legality for event) X2! Yes thank you very much. If Dan hadn't had posted his jeep I would have never considered bringing my bug. Yes with a few tweeks and accessories we should be good. After our 1st comp last night we went to dinner with about 11 people and spent a little time going over my bug being in C2. Same as I thought, none of them understood the rules like I didn't. I guess since we don't follow any of the rules for traditional comps (spec) it will probably take us extra time to understand some of them. Glad you set up this thread. Hopefully we will be able to get in |
01-16-2012, 02:44 PM | #31 | ||
Looking forward to meeting new people at this event and re-visiting with old friends. Last edited by hotwheels000; 01-16-2012 at 02:56 PM. | ||
01-19-2012, 01:18 AM | #32 |
| Re: Vehicle class questions (legality for event) |
01-19-2012, 11:35 PM | #33 |
Rock Crawler Join Date: Dec 2008 Location: dallas
I can tell you that it will need some front inner fenders to cover up the wiring
01-20-2012, 12:05 AM | #34 |
01-20-2012, 12:21 AM | #35 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
As far as I can tell, it looks legal. Difficult to tell in some of the pictures. If it meets these specs, then it should be legal: Class-2 Trail Details: Body/cage work must be at least 4.5" tall (including boat sides) and the inside of the front tires cannot extend outside of the width of the cab at the doors. A front bumper is required and must be mounted to the vehicle's rail chassis and must be wider than the outside of the chassis rails (chassis cross rails do not count as bumpers). You must run a full rail chassis, and the chassis (including bumpers) must be 3" longer than the wheelbase (this includes a chassis with a truggy rear frame). Truggies are allowed, but you must replace the ladder frame behind the cab with tube, and the truggy rails must extend past the rear axle pumpkin to be legal. The bed must have a roll bar hoop and integrated shock mounts. It also must be a structural part of the rear of the vehicle. (If your bed does not meet ALL of the preceding criteria, it does not count as a truggy bed). Flatbeds that run the full length of the rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed. 2 of the 3 following modifications are allowed: - Dovetailing the rear (a truggy/tube bed that is narrower than the cab counts as a dovetail). - Boat sides (no more than 1" measured vertically). - Pinching the front (2/3 the width of the widest part of the cab). Sectioning or narrowing of the body is not allowed. 120mm / 4.75" max tire size with a 2.2 max rim size including spare. Gates will be a minimum of 12" wide (so mind your width). |
01-20-2012, 12:41 AM | #36 |
thanks tim
01-20-2012, 03:22 PM | #37 |
I just printed out the rules.... Is the tire list updated???? I am gonna assume that ripsaws are banned in class3?
01-20-2012, 04:31 PM | #38 |
01-20-2012, 04:36 PM | #39 |
Cool deal just got to get the tekin esc and motor coming and im good to start a build thread..
02-06-2012, 05:22 PM | #40 |
I thought I posted this today but I guess not. I have this sitting here and might not be able to build a C3 early bronco. What are the rules for inner fenders on a ftoy tuber? I have two servos which will be visible. |
Vehicle class questions (legality for event) - Similar Threads | ||||
NIRC Trail Class Event 9.25.11 | sally1800 | Illinois | 73 | 09-27-2011 04:59 AM |
Palmer park Event June 26th / 2.2 s and Scaler Class | lwb Sami | Colorado | 34 | 06-27-2011 02:45 PM |
Partial sag vehicle questions | Big Rig Crawler | General Crawlers | 4 | 06-23-2010 02:48 PM |
