01-13-2012, 04:10 PM | #1 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Vehicle class questions (legality for event)
I thought I would start a thread that would allow people who plan on atendending the event a place to ask questions about there rigs. Please allow the event organizers/event planners to answer the questions as they pertain to the event. General rig questions not attending can be asked in the SORCCA forum and threads. |
01-13-2012, 04:13 PM | #2 |
| Re: Vehicle class questions (legality for event) |
01-13-2012, 04:14 PM | #3 | |
| Re: Vehicle class questions (legality for event) Quote:
01-13-2012, 04:16 PM | #4 | ||
01-13-2012, 06:00 PM | #5 |
RCC Addict Join Date: Sep 2009 Location: sacramento
thank you sir
01-13-2012, 06:12 PM | #6 |
No problem, I figured you are not the only one with questions and it is all in the same place it would save folks from hunting and searching. It will most likely answer questions about other rigs with out having to repeat the questions if people can see and read it all in one place.
01-13-2012, 06:17 PM | #7 | ||
01-13-2012, 06:56 PM | #8 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Hey...looks like Devlin had some extra time this afternoon. Dan, do you have a picture of the "boatsides" that I can see. Also, does it have a "c" channel frame? |
01-13-2012, 07:38 PM | #9 |
01-13-2012, 08:07 PM | #10 |
01-13-2012, 08:08 PM | #11 |
01-13-2012, 08:30 PM | #12 |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
Humm I've seen a few other pictures from the old socrra page and dan's rig has me confused about the 3" deal. i don't see 3 inches over the frame length. But before I go and build another rig these two run 1.9's. The ftoy could get away with 2.2's but would prefer to drive my bug. Bug rear tires are over by 1 1/8 front about 3/8 over. 11 3/4 wheel base Ftoy rear tires are 5/8 over front 5/8 12 3/4 total wheel base So it needs to be 3" less than frame length to qualify for c2 I think I have the same rig covered for c1 and c2 Lances jk which he said he ran in both classes. |
01-13-2012, 09:41 PM | #13 |
I wanna be Dave Join Date: May 2006 Location: akron
is that bug body wide enough? it looks its not from the pics but they are not really at a good angle..
01-14-2012, 09:57 AM | #14 |
RCC Addict Join Date: Oct 2007 Location: Auburn
3" less than overall body length Like Sloppy said you look like your close to being too narrow at the doors |
01-14-2012, 10:54 AM | #15 |
Just to be clear I'm not trying to build a "cheater" rig. This is my favorite rig I've owned and if it fits I'm going to run it instead of having to build another rig for c3 My buddy built a rig for what he thought was c2 but after seeing everything there it was almost a c1 So is this what this rule means? I just put a ruler to the inside of the tire and it's inside the fender. Sorry for these questions but we're not use to these rules • Body/cage work must be at least 4.5" tall (including boat sides) and the inside of the front tires cannot extend outside of the width of the cab at the doors. Sorry, don't know why I can't get it to rotate Then this measurement really doesn't matter ? Again I wouldn't have brought either of these rigs up but seeing a few truggy like rigs in the old q&a thread that may fit into c2 I have to ask to make sure I don't have to leave these two rigs at home. |
01-14-2012, 11:01 AM | #16 |
It looks like you are just fine for the body muesurment at the doors in relation to the front tires. The muesurment at the A pillars doesnt matter. Is this rig full on tube, or is there a frame rail in there somewhere ? The body, including bumpers needs to be 3" longer than your wheelbase. Stingers,d-rings,etc.. do not count in this requirment. Build thread ? ( I couldnt find one) or naked shots would help. Side note : I love the bug..... doing my best to get my VW thing ready for this one Last edited by hotwheels000; 01-14-2012 at 11:19 AM. |
01-14-2012, 12:24 PM | #17 |
RCC Addict Join Date: Oct 2009 Location: west coast..
What are the requirements for a class 3 frame? If its basically a tuber with a lexan blazer body is that legal or do I need some type of straight frame rails in there somewhere? Keep in mind the tube frame work is just as wide as the body but it does not have frame rails per say??
01-14-2012, 12:30 PM | #18 |
Im part of team slow azz builders so no build threads for me right now im 1.5" over so it would throw everything way off to work right shortening it by 4". Thanks for clearing this up, I would have loved to bring this on a road trip like this. Have more interest in this event with some more guys locally so will probably be talking to them more about it tomorrow @ our 1st challenge. Sent from my new phone using tapatalk. |
01-14-2012, 12:45 PM | #19 | |
Class-3 “Modified” Details: • 146mm / 5.75" max tire size with a 2.2 max rim size (including spare). • A bumper is not required, but to be counted for points it must be mounted to the vehicle's chassis and wider than the the chassis rails (chassis cross rails do not count as bumpers). • Gates will be a minimum of 13" wide. • All bodies (including tubers) must measure a minimum of five inches wide from front to rear of door, measure a minimum of 4.5 inches tall as measured from the skid to the tallest point on the body (including light bars), and must be at least as long as the vehicle's wheelbase. • Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum size rules. Highlghted in GREEN, no ladder frame rail requirments for C3 The "tuber" or body does need to be as long as your wheelbase ... Last edited by hotwheels000; 01-14-2012 at 12:57 PM. | |
01-14-2012, 12:53 PM | #20 | |
Still wondering if you have frame rails, if not, it would be a c3 rig as tubers are not allowed in C2. Although truggies are,and truggy does not necesarily mean it is a truck,it is more on the build style and design rather than physical appearance of the body. Sure would love to see you run this rig no matter what class, even if you had to make a few mods it would be cool to see out on the trails. | |
Vehicle class questions (legality for event) - Similar Threads | ||||
NIRC Trail Class Event 9.25.11 | sally1800 | Illinois | 73 | 09-27-2011 04:59 AM |
Palmer park Event June 26th / 2.2 s and Scaler Class | lwb Sami | Colorado | 34 | 06-27-2011 02:45 PM |
Partial sag vehicle questions | Big Rig Crawler | General Crawlers | 4 | 06-23-2010 02:48 PM |
