06-29-2012, 08:28 AM | #101 |
Pebble Pounder Join Date: Dec 2010 Location: Yakima,WA.
| Re: Vehicle class questions (legality for event) |
06-29-2012, 06:28 PM | #102 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
06-29-2012, 10:38 PM | #103 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
06-29-2012, 10:40 PM | #104 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Vehicle class questions (legality for event) Quote:
• Body/cage work must be at least 4.5" tall (including boat sides) and the inside of the front tires cannot extend outside of the width of the cab at the doors. Fender flares play no part in this dimension/ratio. Your rig looks perfectly fine the way it sits,but fender flairs would look cool on it | |
06-30-2012, 12:58 AM | #105 | ||
I just wanna make sure I do not go all the way to WA. and get turned around because my little truck is not scale enough, Thanks for the replies guys I hope this was a little more explanatory, let me know if I am a go or not! Thanks again! | ||
06-30-2012, 01:00 AM | #106 |
One more thing it might still be kinda of a work in progress if that is o.k. too!
06-30-2012, 09:12 AM | #107 | ||||
2012 SORCCA Scale Rules | ||||
07-25-2012, 07:37 PM | #108 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
I have ruling question - WarPig you touched on this - but IDK how you guys measure this stuff. So just to me sure.... - Class2 -The inside of the front tires cannot extend outside of the width of the cab at the doors." I read this straight forward - my cab is 5.5in - my trex60s with swamper 1.9s is 5.5 inside to inside tire. A little hex shaving and the weight of rig on the tires - tight fit but I am just right. Sound correct? |
07-25-2012, 08:13 PM | #109 | |
Rock Crawler Join Date: Dec 2008 Location: dallas
sounds like you read the rules to a "T" | |
07-25-2012, 09:31 PM | #110 |
I try - Hows them old limbs of yours?
07-31-2012, 01:28 PM | #111 |
I just want to clarify for me and maybe for the benefit of others. Is Guido considered a tuber? The rectangular frame rails run full length and the tube work is bolted to it. However there are no structural crossmembers bolted to the frame rails that are not welded to the tube work. Other than the skidplate. You could not remove the tube work and have a driveable vehicle. By the wording of the rules though, a tuber must be made entirely of tube. As a tuber I assume the following points: Tuber: -8 Rigid plastic body panels: -1 (the lexan panels are mounted individually to the tube work and are therefore rigid) Sliders: -3 Bumpers: metal -3 (rear) If Guido is not considered a tuber, does he get the following points? Tube bed: -3 Rigid plastic body panels: -1 (or does this only apply to tubers?) Interior cage: -3 Integrated tube shock mounts: -1 (front), -1 (rear) Sliders: -3 Bumpers: metal -3 (rear) |
07-31-2012, 05:31 PM | #112 | |
If Guido is not considered a tuber, does he get the following points? Tube bed: -3 Yes Rigid plastic body panels: -1 (or does this only apply to tubers?) No, must be rigid plastic or metal....no lexan. Interior cage: -3 Yes Integrated tube shock mounts: -1 (front), -1 (rear) Yes Sliders: -3 Yes Bumpers: metal -3 (rear) Yes, but I'd give you -3 points for a front bumper as well. I come up with -17 | |
07-31-2012, 05:54 PM | #113 | |
07-31-2012, 06:04 PM | #114 |
Shhh! You get more points if you don't point it as a tuber .
08-02-2012, 04:50 PM | #115 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
I've got a question for you and maybe it has been asked...Can I compete with the same Chassis in C1 and C2 and just change out the body, wheels and a few other little things or do I need a completely different rig? Reason I ask is I signed up for C1 since there were no C2 tickets left and was going to rebuild my C2 rig into a C1. Now that there are going to be few more C2 tickets available i'd be able to change it back in an hour or two if allowed. |
08-02-2012, 05:40 PM | #116 |
RCC Addict Join Date: Oct 2007 Location: Auburn
As long as the truck meets the specs for its repsective class then yes you can. Or unless you make Tim mad then no you couldn't. You won't be running C1 and 2 on the same days anyways so you would be good. |
08-02-2012, 07:08 PM | #117 |
That's what I figured, thanks!
08-02-2012, 07:22 PM | #118 |
Yes you can run a truck in multiple classes, As long as it fits the rules of the class
08-11-2012, 11:33 AM | #119 |
Just to make sure I measured the widest part of the cab at the doors and is 7 inches wide, the inside of the tires measures 6 3/8 inches wide. And it looks like this:
08-11-2012, 03:21 PM | #120 |
Yer good to go!
Vehicle class questions (legality for event) - Similar Threads | ||||
NIRC Trail Class Event 9.25.11 | sally1800 | Illinois | 73 | 09-27-2011 04:59 AM |
Palmer park Event June 26th / 2.2 s and Scaler Class | lwb Sami | Colorado | 34 | 06-27-2011 02:45 PM |
Partial sag vehicle questions | Big Rig Crawler | General Crawlers | 4 | 06-23-2010 02:48 PM |
