12-31-2007, 01:33 AM | #81 |
RCC Addict Join Date: Jun 2006 Location: Sin City
01-01-2008, 10:12 PM | #82 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
01-06-2008, 12:41 AM | #83 |
I received some parts today to make this thing a bit more comp friendly and went to work. I got two new link mounts from the awesome guys at RCP Crawlers, thanks again guys. While installing them I noticed that when the rear link mount let go it also cracked the housing. Then while switching it out, the little Y inside the diff had a broken pin. So JB weld came to the rescue and is now packed inside the diff & hopefully curing nicely. So the final list of broken or damaged parts from the last folsom comp goes as follows: 1. front long side axle shaft(old style from the OG rockbuster axles that were on Ralph) 2. rear link mount, plastic one from TLT kit 3. Cut in Losi Rock Claw 4. cracked housing where the link mount screws down(I modded the housing to use 4 screws instead of 2) 5. Y inside the differential carrier Do I get the most broke award or what? |
01-06-2008, 02:07 AM | #84 |
RCC Addict Join Date: Jun 2004 Location: ORegon
sounds pretty decent hahaha. p.s. i have that same crappy ruler except its orange.
01-09-2008, 11:32 PM | #85 |
Oh man you got the orange one, crap! To get ready for the Bean, I scored some countersunk screws and flush mounted my my axial rock rings with some 2-56 SS screws. Looks sick and is all flat and will slip right thru cracks without any holds ups. EDIT: also scored some straight axle adapters from MSD, so I'll be taking it back apart to cut the housing and install them. I may also take my stock outer shafts from the front and grind them down for better steering. Hopefully it'll help. I can't afford CVD's just yet, unless someone wants to give me a set and I'll glady sticker my rig hint hint sponsorship Last edited by rckjeep; 01-13-2008 at 02:13 AM. |
01-23-2008, 10:23 PM | #86 |
So after a couple comps I'm looking to make it more capable. What do you guys think would allow me to perform better at comps?
01-23-2008, 11:24 PM | #87 |
01-24-2008, 12:31 AM | #88 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Been while since I've seen this rig, how you liking it is it performing like you want?
01-24-2008, 08:43 AM | #89 |
the center clearence is slightly adjustable, but it sits pretty low around 2.5" i think. I'm running 4oz. on the axle and the wheels are wrapped if I remember right. I know CVD's would help with steering as well as dig but I don't think there's enough room in the chassis for dig. I'd also like to change my ESC but size is the limiting factor. I'm running the Novak XRS. I'm thinking I should grind the outer axle cups down for better steering, since the ones I took out were all worn in the cup. I don't get much torque twist so the suspension is pretty dialed. I'm running stock Losi foams, uncut. any thoughts? I think the main thing is my driving, honestly. Mugsy seemed to be a ballerina(sp) at the last comp. I think it's my lack of looking forward at the course instead of the gate I'm at. For the people who've watched me compete what do you think? Last edited by rckjeep; 01-24-2008 at 08:51 AM. |
01-24-2008, 10:36 AM | #90 | |
Those weights on the axle could be moved to the wheels, that will lower the cog slightly. Put a stiffer/shorter foams in the tires, helps with sidehilling. Suspension looks good, feels good too. Sorry I haven't been able to see you run much. Im usually staring at the paint Definitely get CVD's, it helps with the "oops the next gate is over there" and can save you a few reverses. | |
01-24-2008, 11:22 AM | #91 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
A good ESC helps a lot with over all smooth control. You should get a Mamba Max for the best performance. | |
01-24-2008, 10:30 PM | #92 |
is the Rooster Crawler any good. I know it has a great drag brake. I only ask because it's a bit cheaper. I'll have to see what my cost is on the Max.
01-24-2008, 11:26 PM | #93 |
RCC Addict Join Date: Apr 2004 Location: Santa Clara
Dave, I think your rig is fairly capable. Crawling with you that one day at the corner park, both yours and TINY performed similarly maybe yours even better thanks to ground clearance. I'd probably lean the most towards driving skills. I know you beat yourself saying you aren't a good driver, but when we were crawling for fun, you drove really well. So maybe just practice practice practice will be the best improvement for you at this time. Not only just driving, but driving with someone that can give good technical pointers. Dean, Dustin, and Brandon are really up on their skills and tricks and getting out with them and watching would be an awesome lesson. Learn your rig as it stands now and tweak it once you feel super comfortable with it as it stands. Then your modifications will make more sense. I agree with others that turning is a fundamental element in comps. I lose so many points each time I go out because of it. While you don't necessarily need dig, it can improve your score leaps and bounds when used appropriately. A sharp turning will help a lot, both in turning regularly, but also making the dig work more efficiently if you go that route. I personally would agree with getting a Mamba Max just because I have one and for the most part like it. The control gain thanks to the drag brake makes the difference here. -Sam |
01-25-2008, 09:09 PM | #94 |
I totally agree but was curious what some of the guys who score better thought could be improved. Anyone up for trip to the waterfalls in the future?
02-03-2008, 11:23 PM | #95 |
made the rig hydraulic assist. Should help out with the steering Also went out to the mini hammers today to play in between the rains Last edited by rckjeep; 02-03-2008 at 11:25 PM. |
02-04-2008, 12:21 AM | #96 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Nice, I almost made it out to the mini hammers but my friggin' back was killing me again. Stuck in bed or on the couch today. |
02-04-2008, 10:12 AM | #97 |
sorry to hear that Dean. It's changed a lot since I was last here. A ton of rock has fallen in.
02-05-2008, 11:57 AM | #98 |
Rock Stacker Join Date: Jan 2008 Location: Rocklin
02-14-2008, 12:16 AM | #99 |
So I'm thinking about picking up a CC Sidewinder to help with the crawlability on this rig. Any comments.
02-14-2008, 12:26 AM | #100 |
| I havent used one yet, everything I hear says its just as good as the mamba max but it cant handle the high powered brushless. If thats true you cant loose I would recommend the caslte bec to power the steering too.
