Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Tranny Guide
Old 02-19-2007, 10:57 PM   #61
Todd, you rule, I am ordering some, if my method of hacking the shafts onto the stock outputs fails, i am installing those....
Or if i get bored and need a project.
Rob92k1500 is offline   Reply With Quote
Old 02-21-2007, 02:38 PM   #62
How do you use a tranny that uses dog bones?
Anyone got pictures?
BrockGrimes is offline   Reply With Quote
Old 02-21-2007, 02:43 PM   #63
dezfan's Avatar
Pretty easy really.
Just use a Maxx or Revo yoke, drill it out to skip over the tranny output and use set screws to pin it.
dezfan is offline   Reply With Quote
Old 02-21-2007, 03:27 PM   #64
Originally Posted by dezfan
Pretty easy really.
DUH... never thought of that.
Thanks Buddy.
Freaking TLT's what am I getting into.............
Old 02-21-2007, 04:30 PM   #65
FrankyRizzo's Avatar
This works well for the Maxx shafts.
Stealth Tranny Tech. how to
FrankyRizzo is offline   Reply With Quote
Old 02-21-2007, 04:37 PM   #66
TLTCrawlin's Avatar
Or just put the pin through the slot on the outdrive, I did it. You try it!! It wont come out! Ive ran my torsion with it, and the shafts get smacked and scraped alot with torsions! and plus I cant pull them off. You guys should try it!
TLTCrawlin is offline   Reply With Quote
Old 02-21-2007, 04:44 PM   #67
Post up a pic.
Old 03-02-2007, 05:57 PM   #68
if i got a sw2 chassis for a tlt rig what would i need to do to an r2 v2 tranny to use it in that rig? what driveshafts would i need to use, and would i need to cut down one of the shafts on the r2 tranny like i have read about? what exactly do i need to do to use it. by the way, this will be my first crawler.
theTman is offline   Reply With Quote
Old 03-03-2007, 10:58 PM   #69
Gettin’ back on the horse
yeah or you can slide a male shaft over it (drill out the teeth) too and slide a pin in. same difference.
TURTLE is offline   Reply With Quote
Old 03-06-2007, 02:30 PM   #70
I'm going to build my first TLT scaler and have a newbie question:
Does anyone use a e-maxx tranny?
I cannot find anybody using it but it looks to me like it would fit right...
Nick Furia is offline   Reply With Quote
Old 03-06-2007, 02:48 PM   #71
Or maybe an e-savage tranny...
Old 03-06-2007, 11:16 PM   #72
What about the hpi nirto mt tranny.
shipwrek is offline   Reply With Quote
Old 03-06-2007, 11:37 PM   #73
dezfan's Avatar
What about it?
Old 03-07-2007, 07:02 AM   #74
Is it worth the time to use in makeing a rock crawler out of the drive train? Can it be geared low enough? As far as i can tell it is a spur gear to a bell gear and a slipper clutch.
Yes i did a search and the only thread on the this set up i could find, the owner abandend the project.
Old 03-08-2007, 12:54 AM   #75
I like the pede tranny cause it is simple and parts are easy to come by. The stealth provides a lower c.g. than pede, but not much. Hope that helps.
5150bronco is offline   Reply With Quote
Old 03-08-2007, 11:25 AM   #76
I think I'll finally use a pede tranny if I get one not too expensive (living outside the US or GB does not help). I think this will be the easyest way for my first TLT build.
Old 03-09-2007, 11:16 PM   #77
I think the pede is a good choice for your first. If you have any questions ask...I used the alum idler gear too with my first pede
Old 03-10-2007, 02:56 PM   #78
Thanks for the help.
Old 03-11-2007, 05:28 PM   #79
No problem, pm me if you have any question at all.
Old 03-12-2007, 08:25 PM   #80
the crawler store provides a list of parts to build a stampede tranny, but what would i need to build a stampede xl-5 tranny because it's better.
