07-03-2007, 03:14 PM | #41 |
Pebble Pounder Join Date: Feb 2007 Location: Sawyer
07-03-2007, 03:17 PM | #42 | |
Quarry Creeper Join Date: Nov 2006 Location: Reno
| Quote: Here is a link to a servo mount that will allow a pack on the axle clod style. It may raise the servo too high to fit under your chassis though. http://rcpcrawlers.com/tlt.html | |
07-03-2007, 03:27 PM | #43 |
Pebble Pounder Join Date: May 2007 Location: Oregon
| Yes I will be getting a pack that JIA recommended in post #10 from CheapBatteryPacks, because they are not to far from me, and I can drive and pick it up or what do you guys think? The only batteries I have now a 6 GP 3300's, I had 3 on each axle Last edited by slowcrawlin; 07-03-2007 at 03:35 PM. |
07-03-2007, 03:30 PM | #44 | |
07-03-2007, 03:33 PM | #45 |
07-03-2007, 03:54 PM | #46 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I was going to suggest the Fat-Rock/RCP mount as well. Other options: TLT battery mount? I've seen one of the locals with several 2/3A cells made into packs that fit over the steering servo. Up one side, across the top, then down the other side. What's your track width right now? |
07-03-2007, 04:40 PM | #47 | |
07-03-2007, 05:12 PM | #48 |
Rock Crawler Join Date: Jan 2007 Location: Midway
Slow, How much do you need to trim the pede tranny to be able to get the side panel on. Just the outer screw hole or more. |
07-03-2007, 05:18 PM | #49 |
07-03-2007, 07:04 PM | #50 |
07-03-2007, 08:26 PM | #51 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Build is looking really good man! Nice job on the tranny trimming ;) |
07-03-2007, 08:48 PM | #52 |
07-03-2007, 08:54 PM | #53 |
07-03-2007, 09:04 PM | #54 |
07-03-2007, 09:13 PM | #55 |
07-03-2007, 09:17 PM | #56 |
BTW, here's some shots of how the pede tranny fits in the frame First two shots are laydown, last two are vertical. The only trimming required is to take the outer screw boss off the housing, remove the two bosses for the pede hingpins, and trim the lip off the bottom of the housing so the tranny sits flat. If you plan to run a laydown tranny I'd suggest running your upper suspension link in one of the four holes closest to the frame rails (see side shots and upper rear link placement). Using holes that are farther in may cause clearance issues with brushed motors. Last edited by JasonInAugusta; 07-03-2007 at 09:20 PM. |
07-03-2007, 09:22 PM | #57 | |
07-03-2007, 10:38 PM | #58 |
Maybe this will help with your batt situation... 2/3A packs mounted over and around the servo. |
07-03-2007, 10:44 PM | #59 |
I see room for 2 more!!
07-03-2007, 10:48 PM | #60 |
Yeah... Too bad I don't remember how many cells fit like that. Slowcrawlin, that is in no way drawn to scale. Hopefully someone can chime in and let you know how many will fit like that. Last edited by JasonInAugusta; 07-03-2007 at 10:56 PM. |
