![]() | #81 | |
Quarry Creeper ![]() Join Date: Mar 2005 Location: The Dark Side
| ![]() Quote:
The idea for the BTA came after that discussion we all had at the last Papago comp. Your pop's 2.2 had a nice set-up there also. Metomwhou, The transmission plates are aftermarket Tamiya parts I got from E-bay. They're layed down and cut off, I think this can be done with the stock plates too. | |
![]() | #82 | |
| ![]() Quote:
The tranmission plates on Buster are Tamiya Hop-Up options. I got them off E-Bay for $30.00 from a vendor in Hong Kong a long time ago. Here's a vid of Buster. I try not to cheat off the wall, but it's there. ![]() | |
![]() | #83 |
looking really good man, that thing climbs like a pack mule.
![]() | #84 |
I havent even finished my 2.2 and I have mods to do! ![]() ![]() |
![]() | #85 |
Well Buster was in need of a complete o-haul after a rough year of crawling and comping. Then I got invited to the Nationals !!! Now it's a complete makeover. First off was finding something to do with my 3rd channel. PARC allows rear steer in the 2.2 class, it's a cheap and dependable alterative to dig/burn. I've been planning to build a USRCCA legal crawler for events outside PARC, now I have a deadline, Sept 9th. I've seen several driveshaft based dig/burn mechanisms, but I wanted something more transfer case-ish.... ![]() ![]() ![]() Grover and I had another post comp pow-wow several months and after alot of reseach and parts shopping, here she is !!! I wanted parts that are widely avalible and tryed not to machine too many parts. Most of the parts are from the venerable PEDE tranny, there's a RC10GT diff gear, a couple of modded TLT spur gear hubs, a 5mm ti shaft from a bicycle quick release, and the REVO shift puck. There are only two machined parts, a heavily modded RC10L rear axle and a REVO output shaft ( thanx wrmorrison ) both involved with the transfer case. ![]() ![]() ![]() The RC10L I got the axle from gave me several chassis ideas. I'm going to try and use the transmission as part of the chassis ala indy cars, the suspension will look alot like two pan car rear pods used front and back. MORE TO COME... |
![]() | #86 |
NICE WORK, can't wait to see more pics and a video of it working in the car. ![]() |
![]() | #87 |
This thing just keeps getting better and better.
![]() | #88 |
Quarry Creeper Join Date: Nov 2005 Location: Danville
that is incredible work! ![]() |
![]() | #89 | |
| ![]() Quote:
Thanks, it's alot of fun building a transmission ( alot easier the second time around ), ya all need to try it !!! I should have the chassis mocked up for pics late tonite....see ya than. | |
![]() | #90 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
thats pretty slick! Nice combo of parts in there. Easy to find stuff in case it breaks.
![]() | #91 |
Quarry Creeper Join Date: Jan 2006 Location: San Diego
thank's for the great write up on your incredible work. helps me get inspired.
![]() | #92 |
Now that I've got the transmission/tranfercase done, how to mount it to my TLT axles ??!!?? ![]() I traded Rover to Mitch for a couple of old RC10L pan cars and wanted to make try that pod style suspension. First I fabbed up chassis plates and T-Bars for the axles. I'm using the capture ball pivot from the 10Ls, one on each end and the laid down shock set-up. ![]() I mounted the chassis plates to either end of the transmission to intergrate the trans into the chassis. The axle and T-Bars ( look more like Y-Bars ) mount to the chassis via the ball pivot and are stablized by two pairs of tierods. ![]() ![]() The front pod ![]() The rear pod ![]() Bottom shot, I still need to make a skidplate. ![]() All I have left is the body mounts, skidplate, a brace for the front like on the back, and run some electronics. I hope to go test crawling with the other PARC crawlers this Sunday, I post up pics and vids than. |
![]() | #93 |
Pebble Pounder Join Date: Aug 2006 Location: High Point
all i can say is WOW, man you have some mad fabbing skillz. what ES do you run? i am on a budjet and noticed that you had 8 cells over the front axle
![]() | #94 |
Very nice way out side the box. How flexy is it! What material is the chassis!
![]() | #95 |
Newbie Join Date: May 2006 Location: Jacksonville
| ![]() Freaking sweet crawler! I'm looking to build a tlt based crawler. Just need to get the axles for a starting point! :-P again, awsome crawler. |
![]() | #96 | |
| ![]() Quote:
I got a chance to fab up a skid plate and body mounts last night and went out to do some test crawling today, VERY GOOD !!! The chassis and suspension flex and articulate perfect. ![]() ![]() ![]() Some body off shots with all the electronics installed. ![]() ![]() As for the dig, WOW !!! It'll take some practice but you can do some funky pivots and turn with it. I tried putting my weighted tires on the rear to help with the dig. This worked good in the dirt but was too much on the rocks, it also killed Buster's vertical climbing. After swapping them back I tried again with beeter success. The front-drive only option works great too, mostly on climbs where the rear tires are suck and they try to flip you. I still have some tuning to do and need LOTS of practice before Moab. | |
![]() | #97 |
I cant wait to see this rig in person. That chassis is top notch! I am not sure what the shocks do for the ride though. Do they flex a hair as the axles twist?
![]() | #98 | |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| ![]() Quote:
![]() ![]() -WRM | |
![]() | #99 |
RCC Addict Join Date: May 2006 Location: Roseville
Freaking amazing ride man. You should write an article on that tranny, its a piece of art.
![]() | #100 |
RCC Addict Join Date: Mar 2005 Location: MESA, AZ.
Mike when I saw the Trans you put together, all I could say was WOW! Now that I see the complete rig I'm speachless. You do awsume and very clean fab work. Rick |
