04-08-2011, 09:06 PM | #161 |
so some shots of it all together and some things I havent had to carry for quite some time now I kicked the rear axle up a bit to help with the prop shaft clearance and the bent links no touchy here and a little battery tray |
04-08-2011, 09:14 PM | #162 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Looks like alot of hard work is starting to payoff, cant wait to hear your thoughts after some tuning and wheel time |
04-08-2011, 09:17 PM | #163 |
some clearance shots ......... at ride height dropped out complete and ready to roll ........ dont have a protractor but got a little bit more then just the standard 20* now and now some new weights .......... Rear = 589g Front = 735g Overall = 1337g So for the front I shaved 60grams ......... for the rear I shaved 7grams and overall I took off 46grams ............. I took the truck out Thursday night for its virgin run and was very pleased with its first run. Ive got some tuning to do and some tweaks to try but so far Im feeling confident for our opening day. Ill post up some more with what I do and setup after Sunday ............. Wanna say Thanks though to Rob_b/CDW for the parts, they were definitely worth the wait. |
04-08-2011, 09:25 PM | #164 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
SS links, now I understand the icing of the hands. I made that mistake once. How many coils did you cut off the springs? 20deg of castor? Looking good. Last edited by rob_b; 04-08-2011 at 09:28 PM. |
04-09-2011, 05:32 AM | #165 | ||
I believe I cut 4 coils but will snap some comparison pics tonight. With the shake up at Losi Im wondering if they're still gonna come out with those springs Jake was running. The golds with the short shock feel stiff/springier. | ||
04-09-2011, 07:46 AM | #166 |
Sweet dude. That Castle BEC is stupid large... |
04-09-2011, 08:15 AM | #167 |
04-09-2011, 08:49 AM | #168 |
| When you cut down a spring the rate increases. I think I only cut 1.5 coils out on mine. rate=(wireDiameter^4 * 1470000)/(meanDiameter^3 * activeCoils) Stock Losi Gold. .620 mean diameter .040 wire diameter 11.5 active coils RATE=1.37 Losi Gold with 4 active coils removed. .620 mean diameter .040 wire diameter 7.5 active coils RATE=2.11 Losi Gold with 1.5 active coils removed. .620 mean diameter .040 wire diameter 10 active coils RATE=1.58 Tech, its a beautiful thing |
04-09-2011, 09:49 AM | #169 |
| my head just exploded makes sense though ......... Ill chop 1.5 off another set after work. |
04-09-2011, 10:57 AM | #170 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
hey i was thinking since you're trying to save weight, it looks like you could've cut out the "V" section of the cahssis(the part above "losi") to shed a little extra weight, and since its not attached to anything structurally it wouldnt hurt. anyways it was just a thought |
04-09-2011, 11:16 AM | #171 | |
When I cut the V out of my old chassis I noticed the flex increased until I put the top two braces back in. Seeing theres really no support above the V point with this chassis I wanted to leave them there for strength. Also like Rob said, possibly attaching them to the CF there will take the little flex out that remains. In my opinion the weight I would save by cutting them wouldnt even be something you would notice making a difference. That 2 or 3 grams isnt gonna keep me from rolling over lol. Now the flex or possibly snapping the 3mm CF from a fall ...... that you would Good idea though | |
04-09-2011, 11:28 AM | #172 |
Rock Stacker Join Date: Jan 2011 Location: Santee CA
looking good there for sure. i had been meaning to ask why stainless for the links... for the added weight or strength or ?
04-09-2011, 11:39 AM | #173 |
Every gram counts. But if you twist on the chassis you can see the "V's" pull away from the CF. So if they were connected it would be a little stiffer. Would it be a noticeable improvement in terms of drive ability? I don't know but again every little bit counts. If you are thinking of using the "V" to tune the amount of chassis flex like a TC you know your truck way too well. |
04-09-2011, 12:13 PM | #174 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
Looking good Rob. Considering you normally come in as good or better than the moa's at the comps, the lighter weight, lower cog, and bent links might put this thing up to a certain "traccer killer" status, lol. You still running same weight per wheel, or did you loose a little with the reduced weight of the chassis? Good job. -bryan |
04-09-2011, 12:39 PM | #175 | ||
04-11-2011, 07:30 AM | #176 |
Well had the trucks first official comp yesterday and the competition didnt make it easy. After 3 courses, 8 drivers, 5 MOA's and 3 shafties I hung on to pull out a 3rd spot. I had 2 gates that were pure driver stoopidness but besides that I was very happy with my day. The second and third courses where a bit MOA friendly, if I had the old rig I would have been nervous about a few of the climbs we had. I felt the benefit of the chassis forward and longer bent rear links, still some belly hangers a few times but manageable. The rear end is my tricky part right now. It doesnt feel as stuck as the old setup did, it tends to slide a bit when trying to front burn and some off cambers. Forward bite is there but they kind of feel lite at times. The front really pulls when needed but gets a slight push feel to it when trying to drive around slow. This week is gonna spring 'shock therapy' . I ran the springs I cut 4 coils from. I compared an uncut Losi gold to my cut ones and the uncut seemed to rebound quicker. With the shorter ones it felt stiffer to compress but the rebound was slower ...... the full set was smooth compressing but rebounded much quicker. Gonna dig around my LHS and see what I can find for lite springs, some mini's or samller buggy fronts. Overall ........ will update with changes and results. |
04-11-2011, 06:11 PM | #177 | |
RCC Addict Join Date: Jun 2005 Location: St. Albans
My wife only gets really pissed when my pit gear and RCs take up her "extra" suitcase space when packing the car for a trip. She doesnt seem to understand that crawlers need to see some different scenery too... Truck looks good. Can't wait for my batch of goodies to be ready. | |
04-11-2011, 07:14 PM | #178 |
Rob another shock option. Scx shocks with rear mini T springs. I bet you find the right spring for your rig, plus the axial shocks are light weight and small diameter. |
04-11-2011, 07:21 PM | #179 |
Pebble Pounder Join Date: Mar 2010 Location: Danbury
Just read through the thread, really great to see someone with an LCC in the CT with so much effort put into it. I look forward to meeting you some day at a ECRCC gathering. By the way is the BEC really a difference maker? (I have a Castle BEC, not PRO. and have never installed it with a Losi ESC. I did not buy the castle link and just put off installing it.) Thanks, Ryan |
04-12-2011, 06:25 AM | #180 | |||
Mine let me take the rig on our anniversary day last year . We went for a hike and shes got pictures of me with the rig strapped to my back pack lol. Quote:
Right now Ive got some Assoc 1.02 shafts in the rear Traxxas bodies. I started my limiters so the shaft compresses just to the bladder inside. Quote:
