01-11-2010, 10:03 AM | #201 |
Quarry Creeper Join Date: May 2006 Location: Taylorsville
notice the packs are 2s2p............wow, can you guys not read?? 2s2p= 2s/each...and each pack is made of 2s in parallel. so if you split the pack you WILL get half the MAH but all of the voltage. Not very hard to understand here. if you have this pack, seperated it, and are only seeing 3.7v, you screwed up somewhere with either buying the WRONG pack or your charger is junk. |
01-11-2010, 02:16 PM | #202 |
RCC Addict Join Date: Jun 2009 Location: California
This whole thread makes me want to run the Losi as a shafty again Great thread. |
01-11-2010, 03:24 PM | #203 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
thanks! I've been spending plenty of hours on the rocks the last few weeks gearing up for 2010... I'll be hitting Socalrcrc comp #3 next weekend at the dreaded Stoddard Wells compsite. updates coming soon |
01-11-2010, 04:05 PM | #204 |
| pics of the shocks upside down por favor I tried mounting mine that way but didnt like how they felt but it could be my installation. I believe I know what you trimmed off the axle mounts, was it the rounded area that rubbed on the shock flat spots? I used Traxxas ball ends for the shock but didnt like how loose they felt, it felt like they wobbled on them up and down to much and i didnt like the side to side play with them. Could I ask what you used? Thanks. |
01-11-2010, 04:36 PM | #205 | |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
01-12-2010, 04:21 PM | #206 |
You have inspired me to return to its roots... Good Bye MOA I will update soon... I'm even going to put my rovers & Leopards on hold and run the Claws. I have the rock claws and comp claws..They are both blue compound but it still seems like the original rock claws are a better compound....I would like to run the comp claws just because of the size difference...How do you fell about both tires and your thoughts on them? Much appreciated |
01-12-2010, 07:20 PM | #207 |
| Sorry, I forgot to post this up sooner You can see where I shaved down the shock mount on the axle. I used a random ball end (revo I believe) with o-rings on both sides to take up any slop. After the abuse the rig has seen in the last few weeks, I'm confident that the mounts will hold up just fine. I tried the same setup with on the rear shocks and I couldn't get them to work without any binding... so they're mounted back in the traditional position. I've also cut my shock limiters down to 15mm in the front and 12m in the rear. I liked the stability of the rig with 20mm limiters, but there were just some places that I need that little bit of extra travel to get through. I think that the current setup is a good compromise. Last edited by Del Monte; 01-12-2010 at 07:27 PM. |
01-12-2010, 07:26 PM | #208 |
| Awesome The shafty can win comps... you just have to believe As far as tires, I prefer the comp claws now. It took a little time for me to get used to the size, but its worth it. On my current set I tried something a little different. I cut out all the small center lugs with body scissors and it really helped with forward bite. The tire seems like it conforms better now too. |
01-13-2010, 12:38 AM | #209 |
no talent hack Join Date: Feb 2007 Location: Redwood City
| its amazing how much of a difference that makes huh? they sidehill better uncut though, i just keep an extra set with me now |
01-13-2010, 08:53 AM | #210 |
Quarry Creeper Join Date: Dec 2009 Location: Rocklin
What weight setup you plan on running in the socal comp?
01-13-2010, 11:36 AM | #211 | |
I'm actually running slightly lighter in my current set of tires. I'm running 7oz. added to each front wheel, and 3oz. added to each rear. I still have my heavy tires with 10oz. in each front and 3oz. in each rear set aside just incase I need them. So far, the rig climbs everything it did before but its a little more nimble with the lighter weights. | |
01-13-2010, 11:39 AM | #212 | |
Np, thanks. Ill have to play with some orings, was thinking this but didnt know if it would bind it up at all. | |
01-13-2010, 11:41 AM | #213 | |
I gotta try the cut out center lugs. I feel I'm severely lacking traction compared to some other tires on the rocks we just started running on. Round boulder types without any real grip, it's fun. | |
01-13-2010, 01:58 PM | #214 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Who cut the cheese? Here's my Comp Claw cut's. Little off the side's and trim the top please Mr. Barber. |
01-13-2010, 02:57 PM | #215 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
Could you post a pic as you've cut the claws Del Monte?
01-14-2010, 01:38 AM | #216 | ||
edit: did you just open up the sides of the open lugs? and trim some of the center lugs down? all the little tiny lugs that run down the center i marked them in red on jay's picture Last edited by Nabil; 01-14-2010 at 01:42 AM. | ||
01-14-2010, 07:47 AM | #217 |
Here's a better one, I highlighted the area's so you can see it through your cataract's. |
01-14-2010, 08:21 AM | #218 |
What weights and where are you running them on those tires?
01-14-2010, 08:23 AM | #219 | |
RCC Addict Join Date: Aug 2009 Location: Earth?
01-14-2010, 08:28 AM | #220 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
