11-19-2009, 09:46 PM | #141 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
Hey Jake, Could you tell us more about your foam setups in your comp claws? thanks |
11-23-2009, 11:35 PM | #142 | |
Rock Stacker Join Date: Nov 2009 Location: seattle
11-24-2009, 12:34 AM | #143 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
My front tires/rim/foam combo weighs in at 15oz... or around 9oz. added to the stock rims. My rears are around 10oz. or around 3-4oz added to each rim. Now, if you're running somewhere slippery (Seattle sounds slippery ) I would start with 5-6oz added in the front and 2-3oz. added in the rear. The extra weight can start to work against you on slick stuff. Last edited by Del Monte; 11-24-2009 at 12:36 AM. | |
12-07-2009, 04:53 PM | #144 |
Here's a new setup for you guys to try. Its been working pretty well out here for the last few weeks... I switched to a lighter oil and gold springs front and rear. Then I moved the upper links down in the rear to help plant the front end a little bit better on climbs. Currently, the rig can slow crawl up faces that I would have had to power up before. The front end tracks a lot better in off-camber stuff too. I added a bigger external limiter to each of my shocks to prevent too much body roll, and it helped. Front Suspension: Upper Links: Top hole Shock Arm: Center hole (B) Shock Mount: Bottom hole (1) Shock Oil: Losi 45wt. Piston: Orange #55 http://www.horizonhobby.com/Products...rodID=LOSA5047 Internal Limiters: none External Limiters: 20mm Springs: Losi Gold http://www.horizonhobby.com/Products...rodID=LOSA5144 Rear Suspension Upper Links: Bottom hole Shock Arm: Center hole (B) Shock Mount: Middle hole (3) Shock Oil: Losi 40wt. http://www.horizonhobby.com/Products...rodID=LOSA5226 Piston: Red #56 http://www.horizonhobby.com/Products...rodID=LOSA5046 Internal Limiters: none External Limiters: 20mm Springs: Losi Gold http://www.horizonhobby.com/Products...rodID=LOSA5144 |
12-07-2009, 05:05 PM | #145 |
You may have noticed a few new things in the last post. I've been on a mission to shed as much weight from the chassis in this rig as possible. So far I've... Moved the ESC back to the rear links Switched out all the chassis hardware with 4-40 Ti stuff Switched to Aluminum mini-nuts http://www.horizonhobby.com/Products...rodID=LOSA6306 Graphite shock arms http://www.horizonhobby.com/Products...rodID=LOSA1114 Every bit of weight saved up high helps... and the rig is a lot more planted on sidehills then it was before. That's a 1.9 beadlock under the tire |
12-07-2009, 05:55 PM | #146 |
RCC Addict Join Date: Jul 2006 Location: barstow
its great to have all this info thanks alot jake for taking the time and updating this thread |
12-07-2009, 07:01 PM | #147 |
RCC Addict Join Date: Apr 2004 Location: 5280
Jake, how are liking the gold's up front versus the grays? Looked at trying gold front, gray rear and it felt almost too soft to me. Right now I have gray front, 56 piston, #3 hole and 50wt oil, and the rear is white, #56 piston, #4 hole, and 50wt and it seems really well planted. Can you float a tire if needed with your set-up at all or does it slinky along following the terrain? From the pic it looks really stable for sure. Thanks! |
12-08-2009, 09:51 AM | #148 |
Rock Stacker Join Date: Jun 2007 Location: Aurora
are you still running the 16 tooth pinion?
12-08-2009, 10:03 AM | #149 |
12-08-2009, 03:05 PM | #150 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
hey jack what kinda belly clearence u running with this setup
12-08-2009, 03:09 PM | #151 |
wow thats some side hill!
12-08-2009, 05:27 PM | #152 |
12-09-2009, 05:07 PM | #153 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
Looking for some help in regards to climbing .... My rig wants to pull itself up ond over, the front end will not settle and grip on extreme angles. Will moving the rear upper link to the top, or bottom hole help this? Thanks in advance!! |
12-09-2009, 06:08 PM | #154 | |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
So, I would think moving the rear uppers to the lower hole would help plant the front end more. | |
12-09-2009, 06:16 PM | #155 | |
12-09-2009, 06:27 PM | #156 | |
My old set-up had whites all around, 60wt all around, and rears in the lower hole and that set-up had issues with letting the front end settle on the steeps. With a gray front, white rear, and light oil all around moving both the front and rear links up one hole has really helped it out. | |
12-09-2009, 08:01 PM | #157 | |
One thing to consider is that I went from a year-old set of white springs down to a set of Golds, so it probably wasn't a big jump in spring rate. My whites had been around the world and seen a few hundred battery packs worth of runtime...so they were probably a little worn out | |
12-09-2009, 08:16 PM | #158 |
12-09-2009, 08:39 PM | #159 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
12-09-2009, 08:48 PM | #160 |
Pebble Pounder Join Date: Oct 2009 Location: Chattanooga
