12-09-2009, 08:48 PM | #161 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
ooooppppssss i knew that just typeo
12-09-2009, 09:13 PM | #162 |
Pebble Pounder Join Date: Oct 2009 Location: Chattanooga
12-10-2009, 09:28 AM | #163 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
12-10-2009, 10:08 AM | #164 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Hey Mac, Jake, Donny, Steve or whatever your name is :-P.... Your new set-up ROCKS! Don't forget to mention about the pre-load on the shock springs when running lighter springs. |
12-10-2009, 12:18 PM | #165 | |
I forgot the all important pre-load.. My front shocks have roughly 12mm of threads showing above the collar, and my rear shocks have 10mm above the collar. | |
12-10-2009, 06:22 PM | #166 |
thanks jake ill give it a try im sure it rocks
12-11-2009, 01:37 PM | #167 |
jake please tell rich thanks an he is the man . i got my parts in like 3 days. thanks losi cant ask any better than that |
12-11-2009, 02:15 PM | #168 |
12-12-2009, 06:14 AM | #169 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Looking at your set up, 20mm (a little over 3/4") of external limiters is a ton! That is more than double of what many people run. Do you ever run less to get more articulation on any courses? Just seems like it would limit travel too much.
12-12-2009, 06:42 AM | #170 |
Pebble Pounder Join Date: Apr 2008 Location: spring hill
awesome thread,been following for a while now and its great,good to see a comp losi thats still a shafty kicking azz,thanksi was thinking about changing mine and after seeing your success i will be keeping it shafty
12-12-2009, 10:47 AM | #171 | |
Right now I can put a tire on top of 3 mounted comp claws stacked on their sides without lifting a tire. | |
12-12-2009, 12:06 PM | #172 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
Soft springs with 5/8-3/4" of limiters is working really good on my LCC. Running golds up front with grays in the rear. Climbing and crawling better than it has with other setups. Still experimenting, but me likes so far! |
12-12-2009, 12:28 PM | #173 | |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
12-12-2009, 01:12 PM | #174 | |
Yep, in fact that's how I stumbled on running the bigger limiters. I threw a 20mm limiter on the driver front shock to keep the link out of the driveshaft. I liked how the rig drove... so I put them on all 4 shocks | |
12-12-2009, 01:28 PM | #175 |
Laid back shock needs longer limiter to keep the link off the driveshaft. I was looking at mine and I have Axial's shock limiters on each shock shaft. They're labeled as 3x7x8 mm. I have my front shock in #2 and the one side just barely touches. Rear shock in #3 and it clears. Maybe I'll add a sliver to the fronts. The amount of articulation I'm getting now seems to be helpful on the piles around me. |
12-13-2009, 10:02 AM | #176 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Jake, I know you posted the amount of preload you run but that has me a little confused. Ride height means more as springs will sag out when they are old. Another way to to do it is figure out the lenght of the shock at it's resting weight from center of mounting hole to center of mounting hole. This works assuming you are using the same shock locations and tower location.
12-15-2009, 10:11 PM | #177 |
The new setup works pretty good SinCityRCRC... Saturday, Dec 13th, Valley of fire, NV Jess and I invaded Sincityrcrc's season finals held in Valley of Fire state park just out side of Las Vegas. The weather was perfect despite some very discouraging weather reports...and the competiton was fierce! A lot of guys were throwing down perfect scores and I had my hands full keeping up. I started off with back to back perfect runs, and got incredibly lucky missing some difficult downhill gates on course #2. The rig definitely descends better then it did before, all I had to do was point it in the right direction and hang on. I had to battle through course #3 and I took a costly rollover penalty. The scores were really tight heading into the final run and I didn't have any room for error. Course #4 was epic and had a tough bonus line. I had to be flawless to keep the top spot. Despite some close calls, I squeaked out a -10 and picked up my first win against the Sincity Crawlers. With the red rocks of Valley of Fire in my rear view mirror, I'm already gearing up for the next comp. We'll be heading to an Axial West Coast Championship qualifier in Janurary, at one of my favorite spots ever...Corona Del Mar Bring it on Have a happy holidays and look for Team Losi to come out of fire in 2010!! -Jake Last edited by Del Monte; 12-15-2009 at 10:16 PM. |
12-15-2009, 10:56 PM | #178 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
Congrats on the win, Mr. Fruit. If ya don't mind me asking, what donor tires were those? I'm just curious because I might try my hand at some AKA Racing truggy tires.
12-16-2009, 09:47 AM | #179 |
| They're red compound Losi eclipse treads on comp claw sidewalls... and they're pretty amazing on red rocks |
12-16-2009, 08:26 PM | #180 |
Rock Crawler Join Date: Sep 2008 Location: Utah
Awesome job on the win yet again Jake! I cant wait to compete with you two again in March. Im excited to try the Losi on the red rock |
