12-22-2012, 09:30 PM | #161 |
| Re: Eyeball Engineering
Here's a vid of the aforementioned RF30-clone owner and a few of his mods. You can see his light assembly when he demonstrates the power lift. RF30 CVT and other modifications - YouTube His webpage appears to be gone though. |
01-03-2013, 07:46 PM | #162 |
Here's a couple random things I've made lately... This wasn't even a planned item...just squared up a chunk of aluminum and went to town with a 1/4" endmill and a vice stop. I think I might have actually measured something once or twice on this one. Don't know what it is or what it's for, but I stayed up until 2 a.m. a few nights ago doing it. I tried my hand at making a shock once before on the drill press, and it was crummy. Now that I have a mill, the latest attempt is a bit less so. This was all turned from a 1/2" aluminum rod I picked up at Home Depot. It's close to being a working item...I still need to come up with a shaft and piston. |
01-04-2013, 02:33 PM | #163 |
Quarry Creeper Join Date: Aug 2009 Location: BC, Canada
That shock is uber scale looking!
01-04-2013, 03:09 PM | #164 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
I don't know what your talking about. But I like it. Everything is so shiny and smooth and appeals to my ADD in a big way. Yaaaaay
01-04-2013, 11:40 PM | #165 |
| Re: Eyeball Engineering Its alright...could be better...and smaller. I'll see what it'll take to make this one functional, then I'll work on smaller. Right now its about 3.5" eye to eye fully extended. |
01-05-2013, 04:05 PM | #166 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
found this thread last night an read evey post in it. gonna keep following it. i'd also like to have a small mill and lathe to play with some time. getting lots of valueable info from this.
01-05-2013, 04:34 PM | #167 |
If you can swing the cost of the equipment, do it. Even spending a little bit of time learning how to do little procedures adds up quick. And you don't even have to run out and buy top shelf materials. Plastic (or even wood) is cheap and plentiful and is perfectly suitable for practice work. |
01-05-2013, 09:46 PM | #168 | ||
Pebble Pounder Join Date: Apr 2010 Location: Yarrambat, Australia
| Re: Eyeball Engineering Quote:
01-05-2013, 10:47 PM | #169 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
Duuuuuuuuuuuuuude that shock is freakin' awesome! I already see uses as is: Scale steering stabilizer and secondary shocks.
01-05-2013, 11:08 PM | #170 |
It needs to be way smaller before it does any of those things.
02-19-2013, 03:55 PM | #171 | |
I ended up with this... What a handy little tool that is! I wish I would have made one sooner... | |
02-19-2013, 09:28 PM | #172 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
| Told ya. One of the best tools you can make and have. Haven't looked back but if to haven't made any screw jacks yet, do it. It's another one of those super handy easy to make parts. Hell you can even make your own spring tool to make springs, both compression and extension style. Takes about 5 minutes to make one too
08-12-2013, 01:33 PM | #173 |
Time to update the EE thread! Picked up a 12" rotary table for cheap. Got it cleaned up, lubed, and even gave it a new coat of paint. Heavy bastard though...about 120lbs. First I cut some pretty circles in some plastic, then tried my hand at something more complex. I was both surprised and happy with the results. Then I tried a wheel. No plans involved, just eyeballing. It even has something resembling a hex. Today I made another that is an actual 2.2. |
08-13-2013, 07:56 AM | #174 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
That wheel looks cool, and the knuckle looks great too. I also dig the look of theat shock. Looks really scale and the rod ends at both sides equal no binding.
08-13-2013, 09:41 PM | #175 |
Tonight I decided to kick it up a notch. |
08-13-2013, 10:23 PM | #176 |
Now quit messing around and throw some aluminum up there.
08-13-2013, 10:28 PM | #177 |
| Re: Eyeball Engineering |
08-13-2013, 10:34 PM | #178 |
Look at it this way, every good plastic piece that comes out could have been aluminum and be one less part to make. I always just start with what the intended product will be made from, if you take your time, no worries. You seem to pick this stuff up quick, confidence, you got this.
08-13-2013, 10:42 PM | #179 |
Plastic is extremely cheap (free), quick to machine, and easy on tooling. This is all one-off practice stuff anyway. I need to make table clamps before I do anything serious. It's a PITA having one hand on the RT crank, one hand on the down feed crank, and another on the cross feed crank. Also, its one thing to make a single wheel, and an entirely different thing to remember what exactly you did so that you can make three more. |
08-14-2013, 07:07 AM | #180 | |
Keep it up and it will start becoming second nature to you hopefully. I've done many wheels and they are fun, only I do as much in the lathe as I can and leave mill work just for the indexed stuff. | |
Eyeball Engineering - Similar Threads | ||||
rocksmith engineering | D-Ride | Newbie General | 14 | 05-19-2012 11:40 PM |
Engineering Question | BJoe | Chit Chat | 14 | 03-04-2008 01:15 PM |
