03-07-2014, 08:02 PM | #261 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: Eyeball Engineering
I think the 6 spokes would look better - lining the spokes up on the bolt holes seem to be the ticket.
03-08-2014, 06:19 AM | #262 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
I don't know what I'm talking about , but here goes. For a better finish of the spokes, could you tilt your rotary table slightly and use a larger ball EM and rotate the wheel / rotary table, off center to get an even and better finish on the radius of the spokes? Does that make sence? |
03-08-2014, 08:34 AM | #263 | ||
| Re: Eyeball Engineering Quote:
03-08-2014, 08:47 AM | #264 |
| Re: Eyeball Engineering I was meaning the "wheel " would be off center to the end mill, so when you rotated the rotary table the EM would be cutting around the center. That way you might use a larger ball end EM to cut the radius on the spokes. |
03-08-2014, 09:19 AM | #265 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Increased surface speed by using the upper part of the ball... http://zero-divide.net/?page=FrontPa...rticle_id=4509 |
03-08-2014, 01:31 PM | #266 | |
Progress made. Almost time to cut spokes...though I may hog out the backsides first. Not sure yet. | |
03-08-2014, 02:00 PM | #267 |
Do you run finish passes? I know for manual it would basically mean doing everything twice, but it will smooth out your finish.
03-08-2014, 03:35 PM | #268 | |
The outer concaved radius on the wheel was done with a 1/2" ball endmill running 2500 rpm and is as smooth as it gets. The inner convexed radius was done with a 5/32" corner rounding bit running the same speed and is wonderfully smooth. Win some, lose some. | |
03-08-2014, 06:18 PM | #269 |
Three down, one to go. |
03-08-2014, 07:12 PM | #270 |
Sexy time!! I'll take 5 good sir.... |
03-08-2014, 09:08 PM | #271 |
| Re: Eyeball Engineering |
03-08-2014, 09:18 PM | #272 |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
boyd would be proud of ya |
03-08-2014, 09:20 PM | #273 |
Killer! |
03-08-2014, 09:25 PM | #274 |
03-10-2014, 07:09 AM | #275 | |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
as your cutting, put your finger around to sence for vibration, you can feel where any loss of rigidity is coming from... and great job mank, your doing semi advanced manual mill work ! ... hey how much for a set of 4 !! .... haha ..... Dr evil .... one million dollars .... Last edited by tom@vp; 03-10-2014 at 07:14 AM. | |
03-10-2014, 07:47 AM | #276 |
Pssstttt - I'm military, everyone knows we get paid like ballers!! No really - the spoke placement looks spot on. Good eye and nice work. |
03-10-2014, 12:36 PM | #277 | ||
I always try to mill with the head as low as possible, that was something I learned early on. Thanks for the heads up though, its always appreciated. Quote:
Thanks for the kind words. | ||
03-10-2014, 06:27 PM | #278 |
Got all the beadlock grooves cut last night, then made a real light pass over all of the vertical surfaces again...it looks much better. Once I get the others done I'll clean up the top of the spokes and dump them in the tumbler for a few days. |
03-10-2014, 07:15 PM | #279 |
Rings on, tire mounted. |
03-10-2014, 07:37 PM | #280 |
They look good.. for being eyeballed. |
Eyeball Engineering - Similar Threads | ||||
rocksmith engineering | D-Ride | Newbie General | 14 | 05-19-2012 11:40 PM |
Engineering Question | BJoe | Chit Chat | 14 | 03-04-2008 01:15 PM |
