08-07-2017, 09:45 PM | #41 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: Options to replace Micro Servo's?
The fullsize Savox waterproof ones, (I believe the 0231 "tall" version) would be a great option. But would you run it on 7.4v to get the 200oz. out of it? And are fitment issues going to arise without some hacking... Yes these are the same price as Traxxas' plastic gear, 6v max servos so its a no brainer.. I still like CODYBOY's application of the Hitec 5065's.. 3 pole, top ball bearing and quick as lightning. I'm also betting Hitec is being slightly conservative on their 30oz. torque rating on this little thing too. Hope to hear back on the results of it.. |
08-07-2017, 09:47 PM | #42 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Great idea! I'll use that for the front locker and buy a good Savox for steering as my stocker absolutely struggles cruising around creek beds and over rocks... it just cannot turn the wheels under load. Until a locker is produced i'll use a zip tie for the rear; I might even pull the rear locker servo this week so I have a spare servo for backup. I think I could use an SCX10 servo mount and screw it to a plate of aluminium and through the slider area sort of like stock... should be lots of room anyway. |
08-07-2017, 10:03 PM | #43 | |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
| Re: Options to replace Micro Servo's? Quote:
08-08-2017, 12:15 AM | #44 |
I was thinking that I might be able to mount a full sized one lying down on the slider/side cover but in the same horn location as the micro shift servo with the end of the cable in the same spot but rotated 90 degrees. I'd move the RX box further rearward and do something similar with the shift servo.
08-11-2017, 09:49 AM | #45 |
Well I figured out a way to shorten the linkage a bit. I had ordered a new front cable thinking it may be shorter but it was the same length, but it did come with a new end link which gave me an extra to play with. I figured out I could cut off a bit of the end link to essentialy shorten up the cable/linkage. For me it was an 1/8", but its gonna be a different for everyone I imagine. I drilled out the hole the cable threads into with a 1/16" bit all the way into the ball cup to maximize the thread grab. If your cable is too short you can un-thread the cable a bit Now the linkage has a throw thats centered on the servo. I've yet to reassemble things so I'll report back again. |
08-11-2017, 10:45 AM | #46 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie | |
08-11-2017, 07:20 PM | #47 |
Pebble Pounder Join Date: Feb 2010 Location: West Orange
Just thinking. If the servo is chattering like you say. I would inspect the wiring carefully. You might be getting a small short. I had a pin on the connector make a loose connection and man did that thing twitch.
08-11-2017, 09:40 PM | #48 |
So I have reassembled everything and its all working properly, I put a video together and combined it with the first one, skip to 3:17 if you've seen the first https://youtu.be/RX46sRzpXwo Keep in mind my front cable was long but maybe yours isn't so take a look and assess the length for your own rig. The threaded end on the cable is pretty long so if you cut too much and have to back it off a ways you still have a lot of grab. Now this is the ideal throw and adjustment but maybe it still needs metal gears in the end, time will tell. Last edited by HumboldtEF; 08-11-2017 at 09:54 PM. |
08-12-2017, 06:28 AM | #49 |
Pebble Pounder Join Date: Jun 2017 Location: Deep Woods
You're the man! Great add on the video . I hope that bluebird shows up today Sent from my iPhone using Tapatalk |
08-14-2017, 06:30 PM | #50 |
Newbie Join Date: Apr 2011 Location: St. Catharines
Here is a thought that I had. Use 1 servo to control both the front and the rear lockers. This servo set up would allow you to either lock or open both different at the same time. Us one of those dual arm servo arms and attach the cables to that. For me, I feel that this would be all I would need. I don't think that I need to have one diff locked while the other is open. Just both locked or bothe open. With this set up, you could open up to a variety of stronger, slightly larger servos. Plus there is less chance of something going wrong when you limit the electronics. Just a though. |
08-15-2017, 10:47 AM | #51 |
Newbie Join Date: Jan 2017 Location: St Peters MO
Anyone tried the bluebird? I got the savox 0257mg with an xtm3860 servo saver. I was able to mount it in place of one of the diff lockers, but the size is off just enough that I wasn't able to connect it up to the cable. Going to play with it more and see if I can get it working. Also going to try it on the transmission. If someone confirms the bluebird works I may try that!! Sent from my SM-T817V using Tapatalk |
08-15-2017, 05:21 PM | #52 |
Is that the 60oz Savox? The specs are great though I wasn't sure if it would fit. I'm not sure I'd connect two diffs to a single double horn as any difference in the throw to get a diff locker engaged might cause issues. The servo is very weak too so it might struggle too boot. There unfortunately doesn't seem to be much wiggle room inside the truck either...I'm pondering if I can move the RX so I have more room atm to use big servos. |
08-16-2017, 05:30 PM | #53 |
It's around 30oz of torque. It fits fine. I had to take the top off and push it through from the bottom since the wire comes out the side instead of the bottom. Once I got it in, I put the top back on and it worked out fine. But the servo saver I tried is too stiff for the job. The stock servo savers have a ton of play and barely put any pressure on the wire at all even when they over-rotate the servo. To get the one I was trying to use to work, things would have to be done to a much better tolerance than what it is with the stock setup.
08-21-2017, 06:26 PM | #54 | |
Newbie Join Date: Dec 2012 Location: los angeles
08-22-2017, 03:27 AM | #55 |
I just tried to rebuild one of the stock Traxxas micro servos simply as a test and I noticed that the sensor or switch in charge of stopping the servo internally is possibly another weak point. It will work in one direction but in the other direction the servo just keeps on trying to go. That's definitely gonna strip gears or burn it up. I put new gears in and while testing it ate the new set of gears (the same gear) because it wouldn't stop. I noticed the new servo I put in just did something similar, I think this is likely the source of the buzzing, the servo has crummy internal end points. Short video to come later. |
08-22-2017, 05:52 AM | #56 | |
08-22-2017, 08:05 AM | #57 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: Options to replace Micro Servo's? |
08-22-2017, 08:41 AM | #58 | |
Here's a quick video in how the sensor inside works or rather doesn't work. EDIT As CLM has pointed out below the pot has a home not end points. thanks to the advice I attempted a rebuild again and centered the servo first by plugging it into the steering channel. I haven't stripped the gears yet testing it, but I've yet to install it. I believe I had the pot offset to one side (when I did the first rebuild) which likely made the servo wind itself into the stop making it strip the new gears immediately. https://youtu.be/04lZ5OP_ksI Another thought popped into my head, I though I had read in a post that the stock ESC used a 1A BEC, maybe its low for the sake of these wimpy servos and regular ESC's might overload them? just a thought. I did this test using the stock ESC. Quote:
08-23-2017, 06:25 AM | #59 | |
08-23-2017, 06:53 AM | #60 |
As I posted on youtube, that servo position pot is working as it's supposed to. the channel it is on currently has the orientation off to one side so off to one side is where the off point of the potentiometer is as centered, as you twist it either direction from that point the motor will spin and attempt to, through the servo gearing, reposition the servo output back to the off point on the potentiometer. This is why the servo motor spins quickly in one direction when you twist it one way and then quickly in the other direction when you twist it that way. Easy way to see this is to plug that servo into the steering channel. power up the radio and then center the potentiometer so the motor stops, then on the radio turn the wheel back and forth, you will see the motor spin one way then the other in accordance with how you turn the wheel. |
Options to replace Micro Servo's? - Similar Threads | ||||
micro crawler options? | evil_monkey | Micro Scale Rigs | 6 | 10-12-2012 04:33 PM |
Motor options for Micro RC | harlequin | Losi Micro-Rock Crawler | 4 | 01-29-2012 09:27 AM |
battery options for micro rc crawlers? | shaybeer | Electronics | 0 | 01-12-2011 07:00 AM |
micro motor options ??? | fordwheeler | Losi Micro-Rock Crawler | 34 | 01-01-2010 09:46 AM |
