11-12-2017, 10:41 PM | #81 |
I joined the Band! Join Date: Mar 2009 Location: Right Here
| Re: Options to replace Micro Servo's?
My locker servos failed day 1 so I got some cheap Tower pro servos and the fit with some mods. I used the arms that came with the servos cuz the closest hole had the correct throw since the radio has no epa adjustments Sent from my iPhone using Tapatalk |
12-05-2017, 02:34 AM | #82 |
Newbie Join Date: Nov 2017 Location: Seattle
Cool, just nicely installed the new replacement 2065 gears. Very carefully held the spring to tighten the saver, and then very gingerly stripped the new gears. Unbelievable.
12-05-2017, 10:54 AM | #83 |
Well, I ended up getting some Savox 0250mg servos. I thought they would fit, but they are too big. However, they do fit the servo saver, so I'm going to end up making a solution in CAD for a mount for the diff servos as well as the transmission servo. It'll take me a while, but I think it's the right way to do it. These dinky little things just aren't going to work no matter what.
12-06-2017, 03:46 PM | #84 |
Newbie Join Date: Nov 2017 Location: Tonawanda
I didn't even get a full pack through mine before my front diff lock servo started buzzing and went inoperable. I've been in the hobby many years and this is a first. lol. Luckily my LHS is amazing and my buddy just had me pull the servo at home and bring it in to exchange for a new one. Getting the horn/saver in just the right spot so that the servo isn't buzzing on either the pull or throw cycle is a bitch and a half!! But....i got it and had the truck out for two hours the other day, used the servo numerous times with no failures. I'm almost thinking it was improperly adjusted out of the box and I didn't hear it laboring before it failed. I made sure to check the others , everything is properly adjusted and working ( for now)
12-06-2017, 04:48 PM | #85 | |
| Re: Options to replace Micro Servo's? Quote:
The spring is on the other end of things so the speak, to hold onto this properly you need to use needle nose pliers to grab the tiny inner most portion of the servo saver, this part is directly attached to the spline. It is pretty amazing how easily they strip though Last edited by HumboldtEF; 12-06-2017 at 04:51 PM. | |
12-31-2017, 06:16 PM | #86 |
RCC Addict Join Date: Feb 2012 Location: UK
When I had a Summit I was told by a Traxxas rep to loosen the screws mounting the servo a little so there was just enough play to take any possible strain off the servo. I never had another fail,after that till I sold it. Maybe it’s worth doing on the trx? Touch wood mine have been ok so far.
01-01-2018, 06:50 AM | #87 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
If and when I have trouble with my shift servos I will be eliminating one servo and going with only one. Here is my idea, pick up a full size servo and some servo mounts like what you'd find in a buggy setup and get a round or star servo horn. you could mount the servo upright or lay it down (would have to move the rx box a bit though. making some measurements find the rate of cable pull from locked to unlocked positions and now hook up the servo to channel 4 on the rx. Run the servo and make measurements on it to find the amount of pull you would have to have on the diff cables. You can also loosen the cable clamps and move cable forward or backwards to add or subtract a small amount of pull length. Now that channel 5 is open on the rx I could hook up some rock lights to that.....flip the switch forward - locks both diffs, flip the switch forward one more position and I have rock lights for a night crawl ! I'm sure there would be a little trial and error but this seems like a simple mod. another idea this time using a carburetor spring linkage off a nitro car, this way if the end points are not real close this would operate in the same fashion as the factory sprung servo savers ! You would only use the rod with the spring from the servo to the first horn, then use another solid rod to connect the two shift horns. Anywho, bored... just sitting playing on the iPad thinking 'bout stuff. Who knows...I keep them lock at all times anyways, so it could be I'll just either JBweld them or get some machined steel spools from Leading Edge Machining Last edited by ScoJac; 01-01-2018 at 07:33 AM. |
01-02-2018, 09:29 AM | #88 |
Some great ideas! I need to keep the diff locking functionality. It’s why I bought the truck. So much fun seeing how far I can get like a real Land Rover before locking a diff or two.
01-10-2018, 07:51 PM | #89 |
Newbie Join Date: Oct 2005 Location: Parker, Co
Any New info on this? I have barely touched my TRX-4 since my locker servo's failed, I am waiting for someone to figure out a good long term solution that I won't have to keep screwing with.
01-10-2018, 08:01 PM | #90 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
I'm using the bluebird option from the original first page of this thread with absolutely outstanding results. I did have to trim the ears a touch for a perfect fit, but that's okay with me. |
01-30-2018, 06:35 AM | #91 |
Newbie Join Date: Nov 2017 Location: In a house
| Re: Options to replace Micro Servo's? |
01-30-2018, 08:01 AM | #92 |
Rock Stacker Join Date: Jan 2018 Location: Madison
02-03-2018, 10:38 PM | #93 |
I ordered 2 of the bluebirds, I think both are DOA. no response when hooked up to the RX, I can't even turn either of them by hand.
02-04-2018, 04:57 AM | #94 | |
RCC Addict Join Date: Jun 2016 Location: Germany
maybe mount a servo horn and turn them. also maybe they demanding too much Amps for the build in bec of the stock esc (only 1A for a truck with 4 servos ). if u have another rig on hand try them in this one or try different kind of servo in the ports to find the issue Last edited by magic_yeti; 02-04-2018 at 05:11 AM. | |
02-04-2018, 10:08 AM | #95 | |
I hooked the trans servo up to channels 4 and 5 and it works on either. | |
02-11-2018, 04:20 AM | #96 |
Newbie Join Date: Jan 2018 Location: The Netherlands
Ordered a couple of those bluebird servo's from the first page. Let's see how they perform |
02-11-2018, 05:30 AM | #97 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Just be careful the stock radio does not has end points adjustment. You could easily overlords your micro servos.
02-11-2018, 08:44 AM | #98 | |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Any more detailed info would be greatly appreciated. I've got a couple Bluebird 373mg servos that I'd like to drop in without watching them get ruined. Thank you, if anyone could elaborate in regards to getting these servos to work successfully. | |
02-11-2018, 10:48 AM | #99 | |
HeyOk made up a dual channel winch controller, and he had asked if it would be handy to be able to set end points, so there may be a solution coming. it will have its own separate little controller though. Wireless Winch and Diff Locker Controller EDIT: the last post in that thread shows the first epa version, and it looks like its now open for order. Last edited by HumboldtEF; 02-11-2018 at 10:54 AM. | |
02-13-2018, 09:48 AM | #100 |
Ok, so like I said above, I ordered this one from the first page of this topic: https://hobbyking.com/nl_nl/bms-373m...sec-11-4g.html I installed it with the servo saver and it stopped working after one minute. I think the throw might be the issue. As far as I can see the original servo's have a throw of around 90 degrees. This one has 120 degrees. I have a second one that I'll install tonight, but I expect it to fail also. |
Options to replace Micro Servo's? - Similar Threads | ||||
micro crawler options? | evil_monkey | Micro Scale Rigs | 6 | 10-12-2012 04:33 PM |
Motor options for Micro RC | harlequin | Losi Micro-Rock Crawler | 4 | 01-29-2012 09:27 AM |
battery options for micro rc crawlers? | shaybeer | Electronics | 0 | 01-12-2011 07:00 AM |
micro motor options ??? | fordwheeler | Losi Micro-Rock Crawler | 34 | 01-01-2010 09:46 AM |
