Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Options to replace Micro Servo's?
Old 02-28-2018, 03:25 PM   #121
Default Re: Options to replace Micro Servo's?
For all you running the stock radio gear,
https://rover.ebay.com/rover/0/0/0?m...2F332539853837
The way i see it for the price of 3 of those you'd be looking at about the price of a hacked GT3B/C so why not just go that and gain some channels
joely is offline   Reply With Quote
Old 02-28-2018, 06:37 PM   #122
Also dont forget the vendors that support RCCrawler, HeyOk has a similar end point controller, its a bit more which I don't mind seeing as HeyOk does some cool innovative things for the crawler community.
https://www.freewebstore.org/heyok-p..._18344974.aspx
HumboldtEF is offline   Reply With Quote
Old 04-17-2018, 07:09 PM   #123
I recently bought one of the used traxxas servos on eBay that they pull off the summit. Had a very good experience for $16. Mine have been through some tough situations...
hutchinstuff is offline   Reply With Quote
Old 04-19-2018, 03:25 PM   #124
This servo:
https://www.spektrumrc.com/Products/...odId=SPMSA4030
Is a good choice to replace stock servos?
Is possible to waterproof it?
Taper is offline   Reply With Quote
Old 04-20-2018, 10:26 AM   #125
Originally Posted by Natedog View Post
Don't bother, way too weak for a crawler. I'd look for at least 150oz/in torque, but prefer more than that.
You can waterproof any of them yourself.
I’m refer for diff lock
Old 04-20-2018, 02:46 PM   #126
Hmm.. Reading all the troubles with the mico servo’s, I’m eying one of my Flysky tank 6-channel tx and rx-es. Swap’m into the TRX. Hey presto! Precise endpoints, micro-adjustments of every channel, even the flip-switches and rotary’s. Have to get one of those centering handle/lever thingy’s though, because it’s a mode-1 TRX, and I’m not fond of the instant cruise control that comes with 1 channel without a center-return.. :P
Truth be told,I’ve about 2 to 3 hours of running on my Bronco, and it hasn’t given me any trouble yet. And I played A LOT with the functions. Cannot help it :Ooh.. buttons and switches.. What do they dooo??? *clicketyclicketyclickety*
Though, it was one of the latest batches. Me thinks Traxxas very well knèw of the issues, and has stepped-up QC, to make ab-so-lutely sure that the servo’s and linkages were adjusted correctly.
Jay-Em is offline   Reply With Quote
Old 05-11-2018, 01:28 PM   #127
Does anyone know if the Savox SW-0250MG will work for the locking differentials? It is 25 t spline.
HTFU Defender is offline   Reply With Quote
Old 05-12-2018, 03:44 AM   #128
not without modification, that servo is 29.mm long and the traxxas 2065 is 22.6mm long. since the linkage is a cable the position of the servo is not critical, you could gat some plastic sheet (abs 1/8") and make a mounting plate to hold the servos then remount the plate with some standoffs to the original bracket mounting holes. If fabricating is not your thing then I'd go back through this thread and find one that is close to the original size. savox does have some but they are not waterproof...but can waterproof on your own, just look in the brushed section on their site.
these two should be real close to dropping in wit a slight shaving of the mounting ears.
SH-0265MG
SH-0262MG
ScoJac is offline   Reply With Quote
Old 05-13-2018, 06:03 AM   #129
found these on eBay
JX Servo PDI-9180MG 12g 180 Degree MG Metal Gear Analog Servo 2.0kg 0.12sec
$8.99 & free shipping
Bangood has then too with High Ratings
https://www.banggood.com/JX-Servo-PD...r_warehouse=CN
***can't find a spline count in descriptions, but blowing up some of the pics i count 25t on some of their other servos.
Description:
Brand:JX Servo
Item:PDI-9180MG Servo
Weight: 12g
Torque: 2.0kg.cm (6.0v)
Speed: 0.12sec/60deg (4.8v) - 0.10 sec/60deg (6.0v)
Voltage: 4.8-6.0v
Type: Analog Micro
Gear Train: Metal
Ball Bearing: No
Lead Length: 180mm
Plug: JR/Futaba
Features:
JX metal gear analog mini servo with 180 degree to stop movement.
180 degree rotation is perfect for pan and tilt camera mounts or any other articulated application.
This servo also offers good torque, speed, excellent centering at a great price and offer free shipping.
The gear train is all metal.
Old 07-29-2018, 02:34 PM   #130
I make a change on the cheap side.
New Power XL-9 fits with a bit grinding drilling at the attachment points .I drill a 3,5-4mm hole in the old Servo Gearhead and push it up side down on the tiny XL-9 gearhead .Than i cut the head from the old servo ta da a bigger spline on the XL 9.I fill the XL 9 with Marine Grease an it works flawless as my shift the two speed servo. After i adjust the shift link there was no servo noise ,not in first not in second.The XL 9 servo ist always with ballbearing head dirty cheap. If you want to watch how my Mog work you can watch on F.B. RC Abenteuer
Or on Y.T. Ka4172
Traildriver is offline   Reply With Quote
Old 09-16-2018, 12:13 PM   #131
any more updates on a diff lock servo uprades?
83trekker83 is offline   Reply With Quote
Old 11-15-2018, 12:58 AM   #132
Not sure if this one’s been mentioned but I had a defective diff lock servo and was able to make a Savox SH0262MG fit without too much work.
Ps. Will NOT work with the stock servo saver spring thingy so only any good for you if running a radio system with endpoint adjustment I guess.
All I needed to do was open up the mountain ear holes a tiny bit and then cut a small notch in the base of the servos plastic cover to allow the cables to exit pointing downwards as opposed to coming out of the side.
Then I used one of the plastic horns trimmed down that was included with the servo
55ovalcharlie is offline   Reply With Quote
Old 01-18-2019, 10:14 AM   #133
Was this servo talked about here?
EcoPower 640T EcoPower 640T 13g Waterproof Metal Gear Digital Sub Micr https://g.co/kgs/XudHL9
Frank211 is offline   Reply With Quote
Old 01-18-2019, 08:55 PM   #134
I believe that is the one the Harley Designs guy featured in his weekly Scale News Update. Apparently they are drop in and metal geared but I have not heard any reviews.
Axle Danzer is offline   Reply With Quote
Old 01-18-2019, 09:44 PM   #135
Why when there's this: https://hobbyking.com/en_us/bms-373m...___store=en_us
and this for $8.00 (simply amazing): https://www.banggood.com/JX-Servo-PD...r_warehouse=CN
would anyone spend $29.00 on the servo that amain sells?
I've been running the BMS-373 (end points adjusted) for over a year with excellent results. They do require attention to detail upon installation, but after that, they are bullet proof.
rockhugger is offline   Reply With Quote
Old 01-21-2019, 10:35 AM   #136
How do you set up endpoints?
qs110 is offline   Reply With Quote
Old 01-21-2019, 12:20 PM   #137
I'm not running the traxxas radio, I'm using a hacked flysky GT3c. Start by centering the trims to zero, bring end points down to 10'ish, and increase until movement is no longer noticed, or until you hear the servo straining then back off a click or two.
Old 01-22-2019, 07:45 PM   #138
Anotha option ???
Sent from my LGMP450 using Tapatalk
Old 01-22-2019, 07:53 PM   #139
Ah that reminds me Amain just came out with a direct replacement sub micro servo, I dont need one but I like how they've filled this void
https://www.amainhobbies.com/ecopowe...7#tab-feedback
EDIT: ah crap I totally missed that Frank already posted this at the top of the page
Old 01-22-2019, 07:58 PM   #140
Awesome. Nice to have a good quality replacement.
Tmaxxed is offline   Reply With Quote
Options to replace Micro Servo's? - Similar Threads
micro crawler options? evil_monkey Micro Scale Rigs 6 10-12-2012 04:33 PM
Motor options for Micro RC harlequin Losi Micro-Rock Crawler 4 01-29-2012 09:27 AM
battery options for micro rc crawlers? shaybeer Electronics 0 01-12-2011 07:00 AM
micro motor options ??? fordwheeler Losi Micro-Rock Crawler 34 01-01-2010 09:46 AM
