02-28-2018, 03:25 PM | #121 |
Pebble Pounder Join Date: Dec 2006 Location: australia
| Re: Options to replace Micro Servo's?
For all you running the stock radio gear, https://rover.ebay.com/rover/0/0/0?m...2F332539853837 The way i see it for the price of 3 of those you'd be looking at about the price of a hacked GT3B/C so why not just go that and gain some channels |
02-28-2018, 06:37 PM | #122 | |
| Re: Options to replace Micro Servo's? Quote:
https://www.freewebstore.org/heyok-p..._18344974.aspx | |
04-17-2018, 07:09 PM | #123 |
Newbie Join Date: Feb 2017 Location: On the road..
I recently bought one of the used traxxas servos on eBay that they pull off the summit. Had a very good experience for $16. Mine have been through some tough situations...
04-19-2018, 03:25 PM | #124 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
This servo: https://www.spektrumrc.com/Products/...odId=SPMSA4030 Is a good choice to replace stock servos? Is possible to waterproof it? |
04-20-2018, 10:26 AM | #125 |
| Re: Options to replace Micro Servo's? |
04-20-2018, 02:46 PM | #126 |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
Hmm.. Reading all the troubles with the mico servo’s, I’m eying one of my Flysky tank 6-channel tx and rx-es. Swap’m into the TRX. Hey presto! Precise endpoints, micro-adjustments of every channel, even the flip-switches and rotary’s. Have to get one of those centering handle/lever thingy’s though, because it’s a mode-1 TRX, and I’m not fond of the instant cruise control that comes with 1 channel without a center-return.. :P Truth be told,I’ve about 2 to 3 hours of running on my Bronco, and it hasn’t given me any trouble yet. And I played A LOT with the functions. Cannot help it :Ooh.. buttons and switches.. What do they dooo??? *clicketyclicketyclickety* Though, it was one of the latest batches. Me thinks Traxxas very well knèw of the issues, and has stepped-up QC, to make ab-so-lutely sure that the servo’s and linkages were adjusted correctly. |
05-11-2018, 01:28 PM | #127 |
Rock Stacker Join Date: Mar 2018 Location: Denver
Does anyone know if the Savox SW-0250MG will work for the locking differentials? It is 25 t spline.
05-12-2018, 03:44 AM | #128 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
these two should be real close to dropping in wit a slight shaving of the mounting ears. SH-0265MG SH-0262MG | |
05-13-2018, 06:03 AM | #129 |
found these on eBay JX Servo PDI-9180MG 12g 180 Degree MG Metal Gear Analog Servo 2.0kg 0.12sec $8.99 & free shipping Bangood has then too with High Ratings https://www.banggood.com/JX-Servo-PD...r_warehouse=CN ***can't find a spline count in descriptions, but blowing up some of the pics i count 25t on some of their other servos. Description: Brand:JX Servo Item:PDI-9180MG Servo Weight: 12g Size: 22mmx12mmx21mm Torque: 2.0kg.cm (6.0v) Speed: 0.12sec/60deg (4.8v) - 0.10 sec/60deg (6.0v) Voltage: 4.8-6.0v Type: Analog Micro Gear Train: Metal Ball Bearing: No Lead Length: 180mm Plug: JR/Futaba Features: JX metal gear analog mini servo with 180 degree to stop movement. 180 degree rotation is perfect for pan and tilt camera mounts or any other articulated application. This servo also offers good torque, speed, excellent centering at a great price and offer free shipping. The gear train is all metal. Last edited by ScoJac; 05-13-2018 at 06:35 AM. |
07-29-2018, 02:34 PM | #130 |
Pebble Pounder Join Date: Sep 2015 Location: Germany
I make a change on the cheap side. New Power XL-9 fits with a bit grinding drilling at the attachment points .I drill a 3,5-4mm hole in the old Servo Gearhead and push it up side down on the tiny XL-9 gearhead .Than i cut the head from the old servo ta da a bigger spline on the XL 9.I fill the XL 9 with Marine Grease an it works flawless as my shift the two speed servo. After i adjust the shift link there was no servo noise ,not in first not in second.The XL 9 servo ist always with ballbearing head dirty cheap. If you want to watch how my Mog work you can watch on F.B. RC Abenteuer Or on Y.T. Ka4172 |
09-16-2018, 12:13 PM | #131 |
Quarry Creeper Join Date: Aug 2018 Location: calgary
any more updates on a diff lock servo uprades?
11-15-2018, 12:58 AM | #132 |
Rock Stacker Join Date: Aug 2017 Location: UK
Not sure if this one’s been mentioned but I had a defective diff lock servo and was able to make a Savox SH0262MG fit without too much work. Ps. Will NOT work with the stock servo saver spring thingy so only any good for you if running a radio system with endpoint adjustment I guess. All I needed to do was open up the mountain ear holes a tiny bit and then cut a small notch in the base of the servos plastic cover to allow the cables to exit pointing downwards as opposed to coming out of the side. Then I used one of the plastic horns trimmed down that was included with the servo |
01-18-2019, 10:14 AM | #133 |
RCC Addict Join Date: Feb 2017 Location: Surprise
Was this servo talked about here? EcoPower 640T EcoPower 640T 13g Waterproof Metal Gear Digital Sub Micr https://g.co/kgs/XudHL9 |
01-18-2019, 08:55 PM | #134 |
Newbie Join Date: Jan 2019 Location: Detroit
I believe that is the one the Harley Designs guy featured in his weekly Scale News Update. Apparently they are drop in and metal geared but I have not heard any reviews.
01-18-2019, 09:44 PM | #135 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Why when there's this: https://hobbyking.com/en_us/bms-373m...___store=en_us and this for $8.00 (simply amazing): https://www.banggood.com/JX-Servo-PD...r_warehouse=CN would anyone spend $29.00 on the servo that amain sells? I've been running the BMS-373 (end points adjusted) for over a year with excellent results. They do require attention to detail upon installation, but after that, they are bullet proof. |
01-21-2019, 10:35 AM | #136 |
Newbie Join Date: Aug 2018 Location: Sakhalin
01-21-2019, 12:20 PM | #137 |
I'm not running the traxxas radio, I'm using a hacked flysky GT3c. Start by centering the trims to zero, bring end points down to 10'ish, and increase until movement is no longer noticed, or until you hear the servo straining then back off a click or two.
01-22-2019, 07:45 PM | #138 |
Anotha option ??? Sent from my LGMP450 using Tapatalk |
01-22-2019, 07:53 PM | #139 |
Ah that reminds me Amain just came out with a direct replacement sub micro servo, I dont need one but I like how they've filled this void https://www.amainhobbies.com/ecopowe...7#tab-feedback EDIT: ah crap I totally missed that Frank already posted this at the top of the page Last edited by HumboldtEF; 01-22-2019 at 08:00 PM. |
01-22-2019, 07:58 PM | #140 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Awesome. Nice to have a good quality replacement. Sent from my iPhone using Tapatalk |
Options to replace Micro Servo's? - Similar Threads | ||||
micro crawler options? | evil_monkey | Micro Scale Rigs | 6 | 10-12-2012 04:33 PM |
Motor options for Micro RC | harlequin | Losi Micro-Rock Crawler | 4 | 01-29-2012 09:27 AM |
battery options for micro rc crawlers? | shaybeer | Electronics | 0 | 01-12-2011 07:00 AM |
micro motor options ??? | fordwheeler | Losi Micro-Rock Crawler | 34 | 01-01-2010 09:46 AM |
