06-12-2020, 07:46 PM | #741 |
RCC Addict Join Date: Sep 2015 Location: Australia
| Re: Yeti.Stealths Ascenders
All my old 2S and 3S batts are dying, still got some good 1800 3S, they even fit in the stock battery tray doubled up and in the other Ascender modified tray with 550 motor. Busted diff replaced and the boys are keen to hit the trails today! |
06-18-2020, 07:09 PM | #742 |
Just a couple of pics from our last time out. |
06-19-2020, 04:03 AM | #743 |
| Re: Yeti.Stealths Ascenders |
06-21-2020, 02:24 AM | #744 |
4 hour trail run with the guys, rain shower and cool temps. Good times! |
06-21-2020, 02:31 AM | #745 |
06-21-2020, 04:53 AM | #746 |
RCC Addict Join Date: Nov 2010 Location: England
Looks like a good time. Weather got bad here last week, so never got out. Having a few days off work in July so hope to do some driving then. Getting stir carzy now.
06-22-2020, 01:12 AM | #747 |
I see they hold Recon G6 events over there in England, you ever get to one of those M1tch? A few years ago the G6 people put out some feelers to gauge response to a possible G6 in Australia.....that would be fun! |
06-22-2020, 04:53 AM | #748 |
I haven't gone to any events as usually the are 200 to 300miles away. I don't know of anyone else around here with a scale crawler either. I might give one a try next year as hoping to retire at the begining of April.
06-22-2020, 10:38 AM | #749 |
Pebble Pounder Join Date: Nov 2012 Location: Canaan
Nice crawling spot you got there!
07-22-2020, 12:36 AM | #750 |
Finally have had enough of the stock drive shafts, worn or busted pins and sloppy drivetrain. Installed vanquish diff outputs, and incision driveshafts (scx10/scx10 II size ) and drilled the stock gearbox output shaft to accept the thru pins. Drive train is nice and tight now and maintenance friendly. Parts already ordered to do the other Ascender too! |
07-22-2020, 10:35 AM | #751 |
Looks like you've got your money's worth out of those tires, and diff housings, and frame rails, and... the whole truck!
07-22-2020, 12:53 PM | #752 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
Reasonable upgrade. My truck has a ton of slop in the drivetrain.
07-23-2020, 01:41 AM | #753 |
Yes it’s had plenty of use, done many miles and local comps. This is the 3rd body for that chassis now. I finally have it how I have always wanted it. I’m a bit slow getting it there and now they are discontinued lol. 550 21T motor, HW1080 ESC, Codyboy weighted axles, battery tray mod to clear 550 motor, rear sway bar, Savox 1210, castle BEC, assorted china bead locks and tyres, interior and driver figure, servo winch. Only thing I don’t have is lights and some protek 3S shorty batts. Running an old dx4c radio, wishing I had one of those cool rugged radios..... I can recommend the driveshaft upgrade, only tricky bit was drilling the gearbox shafts for the thru pins, I used and old stock driveshaft end and clamped it onto the shaft where I wanted the hole with 1 grub screw and used the other grub screw hole as a drill guide for a 2.5mm drill bit to drill most of the way thru, take it off then finish drilling. Was easy. |
07-24-2020, 03:51 PM | #754 | |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
| Re: Yeti.Stealths Ascenders Quote:
here it is https://www.horizonhobby.com/product...VTR332012.html Ben Last edited by Itali83; 07-24-2020 at 03:55 PM. | |
07-25-2020, 04:51 AM | #755 |
Those new design shafts were gunna be my plan B if drilling the old ones was a disaster
07-27-2020, 03:41 PM | #756 | ||
Replaced shafts on my K10 Ascender with the VP axle output adapters and the SCX10 Incision shafts, love it! Super scale, smaller OD, easier maintenance! Great job clamping and drilling old style tranny output shaft, yes the Suburban came with the shaft with holes, still be available separately in Bens' link below. Quote:
08-21-2020, 06:50 AM | #757 |
The 66 Chevy pickup has a 550 can 21T motor now, battery tray chopped and moved forward and bolted to the chassis. Got it as far forward as I could and still fit batteries, ground away the ribs underneath to get as low as I could too. |
08-21-2020, 07:05 AM | #758 |
Late notice for a local night run with the guys, so slapped some lights on, one of those cheap online light kits I had left over from the Bronco and a night crawler light bar someone gave me. Hot glue gun, tape and cable ties quick install! Got the old blacked out bonnet on (hood for u guys) and cut out the roof of the old cab body, hot glue and taped it on like a sun visor and bolted light bar to it. Everything held up fine for my first night run! First aid by Rc car head lights |
08-23-2020, 06:39 AM | #759 |
Great night shots. Truck must be doing well if the drivers now the weak point! I thought my housings and frame rails were well worn in, but you've certainly got me beat. |
Yeti.Stealths Ascenders - Similar Threads | ||||
Life of one YETI - Tom Frajer's Axial Yeti build log | TomFrajer | Axial Yeti | 320 | 05-22-2017 09:01 PM |
Comp classes for ascenders? | Biomedchad | Vaterra Ascender | 15 | 04-15-2016 02:19 PM |
