Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Future Options from Vanquish
Old 01-29-2017, 04:24 AM   #1
Default Future Options from Vanquish
Not sure of any details or release dates, but it's nice to finally see some more options for the Ascender. I got these photos from Faceboook.
rc2000 is offline   Reply With Quote
Old 01-29-2017, 05:58 AM   #2
Default Re: Future Options from Vanquish
On the possibility of being stupid, I've not long had one Vaterra's own CVD's & New Aluminium diff covers?
Scaler Ascender is offline   Reply With Quote
Old 01-29-2017, 10:34 AM   #3
I had a 7 paragraph, prescription medication fueled, diatribe all typed up and then though better of it. So, I will just say this: I am very pleased that the big name vendors in the crawler world are finally supporting the Ascender and I will likely buy some of these new products but, what took so long?
Hobbezco is offline   Reply With Quote
Old 01-29-2017, 04:51 PM   #4
I am glad we r finally getting some. I will for sure have a set. I know wont be as good as the codyboy axles but they r just cool
LIFE IS GOOD
pete959 is offline   Reply With Quote
Old 01-30-2017, 09:48 AM   #5
Natedog's Avatar
Nice, good find! Yes, please and thank you Vanquish!
X2, very well said!
LIFE IS GOOD
x2, finally! I'll buy the VVDs!
Old 01-30-2017, 02:47 PM   #6
Natedog's Avatar
When's pre-order open?
Old 01-30-2017, 03:38 PM   #7
Is it just me or are the axle housings in the rendering NOT stock Ascender axles? The front cover is tilted back like the Curries and the C-hubs are not bolted on? Also the detail around the center section is much more realistic than the stock axles.
JDM74 is offline   Reply With Quote
Old 01-30-2017, 05:46 PM   #8
According to the Ripper Machine facebook page, they are a complete machined aluminum axle housing that uses Ascender internals.
Old 01-31-2017, 08:56 AM   #9
Moderator
JatoTheRipper's Avatar
I'll dare say the stock Ascender axles are better looking. I don't like the canted pumpkin cover on stock looking rigs. But I am interested to see if they made any improvements. I wonder if they moved the pinion up to combat torque twist. If they did these will be killer. If not I'll pass.
Old 01-31-2017, 01:49 PM   #10
Can't do that without a gear change. You can rotate it around the center line of the ring gear, but you can't just move it up. That requires a new tooth profile.
DrewHammer is offline   Reply With Quote
Old 01-31-2017, 02:45 PM   #11
Moderator
Right, but rotating the pinion location will change direction of the torque twist force. That would, effectively, reduce torque twist.
Old 01-31-2017, 04:33 PM   #12
I respectfully disagree. The torque isn't coming from the pinion, the pinion is being acted upon. You can rotate the pinion around all you want to and it won't affect torque twist. That's a function of the suspension geometry's ability to deal with it, and how much torque you make.
All you get with rotated pinions is more clearance from the rocks, worse driveshaft angles at full suspension compression and poor driveshaft joint velocity.
Old 01-31-2017, 04:55 PM   #13
Moderator
Rotating the location of the pinion around the ring gear will change the direction of the torque twist. It won't change the amount of torque twist. That's easy enough to test yourself.
After giving a quick thought about this I don't think it's feasible to move the pinion far enough to have any substantial effect on the direction of the torque twist though.
Old 01-31-2017, 09:15 PM   #14
That was one of the most civil discussions/debates I've readon this forum, while informative. Way to go guys, we need more of that around here.
LSXGMC is offline   Reply With Quote
Old 02-20-2017, 08:40 PM   #15
Natedog's Avatar
It's great to see options for Ascender axle housings, but I too prefer stock center section and cover style and seem to get caught on less stuff imo. Hope they move the upper link mounts up about 1/4" and back on the rear axle (forward on the front axle) to help geometry and TT.
Old 02-23-2017, 08:37 AM   #16
These look awesome!!! It would be nice if they made a Delrin option, or something super slick, but I'm not complaining.
rockhugger is offline   Reply With Quote
Old 02-23-2017, 03:44 PM   #17
I just got some ascender axles for a build myself knowing vp is coming out with some new stuff. I already got two sets of scx2 axles figured I'd give these a shot.
fr8cture is offline   Reply With Quote
Old 02-28-2017, 08:46 PM   #18
LIFE IS GOOD
Old 03-01-2017, 01:48 PM   #19
Another new Vanquish Ascender product: driveshaft adapters.
Vanquish Products Ascender Driveshaft Adapter
Not a revolutionary product but the Vanquish ones should be more widely available than other versions.
svt923 is offline   Reply With Quote
Old 03-01-2017, 02:15 PM   #20
In related Vanquish news: Ascender Currie prototypes now exist
Future Options from Vanquish - Similar Threads
Best wheel options beside vanquish? jwall046 Axial Wraith 19 11-27-2014 10:37 PM
The future of scale RC pardonmyn00b Scale Videos! 14 08-14-2012 06:49 PM
Future Crawler ChrisR40 Alabama 11 03-18-2010 02:43 PM
Future of USRCCA? rockwerks RC Rock Crawling Worlds 28 11-23-2006 12:28 PM
