02-11-2013, 09:48 PM | #1 |
| Harley's Twin Hammers My truck arrived today! After I finally got home I started tearing this thing down. I wanted to swap out the stock electronics and get a closer look at all the in's and out's of the new rig. So the first part of this thread is almost completely a de-build thread. I plan to change quite a bit of this truck right away. |
02-11-2013, 09:54 PM | #2 |
| Re: Harley's Twin Hammers
I'll work backwards on the truck. First off, the feel of the rig is great. All the parts seem to fit well with very little if any play. The quality feels rigid where it should and flexy where it will help durability. The front A-arms have a nice high clearance design. The bottom of the A-arm is almost at the center of the knuckle. The stock battery is TINY However it does appear I can wedge my 2200 3s packs in there just barely. |
02-11-2013, 09:55 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Pics in the first post |
02-11-2013, 10:00 PM | #4 |
The stock electronics are coming out right away. I did not end up using the 9157 for shifting and instead relocated to stock steering servo with a simple bracket. More on that later. The inboard front suspension is killer. Feels nice and smooth too. Really looking forward to tweaking with this setup. With the quality of this car to this point, I was disappointed to see these crappy plastic hexes. Very cool trailing arms, however I wish they would have lowered the shock mounting point below the centerline of the rod ends like a real trailing arm so that it would keep the arms in place. Right now they rock back and forth which is just an annoying design trait to me. |
02-11-2013, 10:06 PM | #5 |
I ripped the cage off next and started taking the electronics out. First up I took out the stock radio gear and sold it off Then the steering servo. I am putting in a Futaba BLS152 brushless servo. Once I took the stock servo out I noticed this design on the stock servo horn. This may be common somewhere else but I have never seen it before. A metal insert goes into the horn with larger splines to increase engagement of the plastic. I will still swap this horn out at some point but right now I am going to see how this design holds up. The stock steering rack is not my favorite, it is a little sloppy, not terrible though. I honestly see this as a possible weak point down the road when we really start bashing these rigs and pushing way past the stock limits. Out of the box, I don't see any big issues with it though. |
02-11-2013, 10:09 PM | #6 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
I was looking at the spare tire and not really feeling it. Can the chassis be cut like my crappy hack pic or is the spare used to hide the battery? Thanks... |
02-11-2013, 10:12 PM | #7 |
Relocating the stock steering servo to the shift servo location wasn't too difficult. I made this simple bracket out of a stock Axial servo plate, I'm sure most of you have a bunch of these sitting around like I do! I drilled a few extra holes to mount the plate (I'll try and make a PDF template for people to do this unless someone comes out with one soon). I had to counter sink one screw so that when I screwed it into the existing transmission mount it didn't interfere with the servo. Then I just threw the servo up there and mounted it with the two lower hole of the mounts. If you have some Axial servo posts for a full size servo you could replace those too, I don't see a big need for that right away. |
02-11-2013, 10:13 PM | #8 | |
| Re: Harley's Twin Hammers Quote:
However, I do not see any easy modifications to do that. The tubes on this frame are MUCH slimmer than we see on the Axial stuff, adding a new hole is not going to be a good idea. For now I don't see many solid options. | |
02-11-2013, 10:30 PM | #9 |
I just gave Mr. Holmes' site a visit and picked up my Tekin ROC412 3100KV motor as well as a Castle Mamba Max Pro |
02-11-2013, 11:27 PM | #10 |
RCC Addict Join Date: May 2011 Location: Utah County
this thing is gonna be legit!!! subbed. great photos. great writeup so far harley!
02-11-2013, 11:32 PM | #11 |
| Re: Harley's Twin Hammers |
02-11-2013, 11:42 PM | #12 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
02-11-2013, 11:44 PM | #13 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
Truck is looking good already with the mods Josh! I think it will need some orange in it! |
02-11-2013, 11:46 PM | #14 |
bmuzz sell me the RX if you dont need it |
02-11-2013, 11:52 PM | #15 |
02-12-2013, 05:43 AM | #16 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
This is sure to be a sweet thread, subscribed. Sent from my iPhone using Tapatalk |
02-12-2013, 05:58 AM | #17 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
I shall be following this closely , Looks nice so far . Cheers , Jack |
02-12-2013, 06:56 AM | #18 |
Rock Crawler Join Date: Sep 2010 Location: Little Rock, AR
Good Idea going full size on the shift servo, glad to know there is enough room under the body. That will definetly be my first mod when I swap out the stock electronics about 5mins after it comes out of the box. You gonna lock the front or try the 500k oil? |
02-12-2013, 07:41 AM | #19 | |
I think I will go right for the locked front diff fairly soon. I need to order my clear panel set as well as the locker. | |
02-12-2013, 08:17 AM | #20 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
The goofy servo horn is the same as stock on the mrc pro.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/vaterra-twin-hammers/428328-harleys-twin-hammers.html | ||||
Show Posts - B | This thread | Refback | 02-15-2013 09:43 AM | |
Horizon Hobby? Rock Racer, link | This thread | Refback | 02-14-2013 09:10 PM | |
The maxbonv KoH Twin Hammers - Pagina 18 - Scalers & Crawlers | This thread | Refback | 02-12-2013 10:05 AM | |
horizon hobby: Vaterra - page 4 | This thread | Refback | 02-12-2013 07:05 AM |
Harley's Twin Hammers - Similar Threads | ||||
Vaterra Twin Hammers Picture Archive - No talking | Rock Concepts | Vaterra Twin Hammers | 345 | 03-11-2024 05:55 PM |
Twin Hammers are in!!! | tunnalram | North Dakota | 0 | 02-11-2013 04:08 PM |
Twin Hammers | Rock Concepts | Videos! | 4 | 01-31-2013 02:50 PM |
