Go Back   RCCrawler Forums > Vendors > Vendors Market
Thread: Official VF/DNA/BWD Customer Service/Feedback Thread
Old 09-02-2008, 11:28 AM   #41
Default ??
hay guys
i was wanting a black DNA dig cast.
just the dig case nothing else.
are theses avable separately??
thanks the DmG
the DMG is offline   Reply With Quote
Old 09-02-2008, 04:03 PM   #42
Originally Posted by slip408 View Post
Hi...I just received my DNA Dig from RPP hobbies, thanks for the quick shipping RPP...but I'm having a problem with the horseshoe like slider, for some strange reason its not reaching all the way back to where the gear mesh against the back of the gear case to lock the gear...but if the sliding pin that holds the horseshoe like slider was threaded the other way around it would be flush against the rear inside casing causing the outdrive to lock...I'm not sure if its me but I need some help...will try to get some pictures in...:-(
Got mine in today from RPP with the exact same problem but also the dig case does not fit up to trans near the top where the notch is on the dig side. I am glad to see I am not the only person with this problem but I am needing this fixed ASAP as I was going to run it at Nationals this coming weekend in Moab. I did send an email to Don about this issue. Any help would be appreciated.
Thanks
Ryan
winkscrawler is offline   Reply With Quote
Old 09-02-2008, 04:47 PM   #43
Hey Don I sent you a email, I need help for Nationals.
Thanks
THAT1GUY is offline   Reply With Quote
Old 09-02-2008, 06:46 PM   #44
Thanks
Ryan
e-mail your address and and info I will get this resolved ASAP!! we need ALL of these running at Nat's...
210solomon007 is offline   Reply With Quote
Old 09-03-2008, 08:50 AM   #45
Email sent, I look forward to hearing from you.
Old 09-04-2008, 10:29 AM   #46
hey got my part today solomon thanks alot and the stickers rock
buster22 is offline   Reply With Quote
Old 09-05-2008, 09:04 AM   #47
Siggy's Avatar
Assembling the dig, and I can't thread the rod into the fork at the correct side. It threads in ok at the wrong side. It really does not make sense as it should be able to thread both sides. Need help here. Thanks.
Siggy is offline   Reply With Quote
Old 09-05-2008, 02:31 PM   #48
siggy, youll need a 6-32 tap($5) to thread it the rest of the way..... I read about this in another thread+mine came in yesterday(and yes I did tap it all the way thru with the 6-32 tap)..............but my dig unit isnt working like I think I should. Burned up a servo already, so, not sure what to do now.
even trying to shift by hand is kinda hard(probably binding), took it apart like 3 time now to check installation. The brass pin on the "cog" is true(to the eye), everything seems smooth till I put the cases together(dig case and tranny)+(tried tightening and keeping the screws(tranny to motor plate) loose)...........
also, having a hard time with the linkage.
Has anybody got this new batch to work perfectly?
its my first dig, so, maybe I just need to figure it out....
barbaricboye is offline   Reply With Quote
Old 09-05-2008, 03:15 PM   #49
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Even if it looks true to the eye, I'd go ahead and pull it apart and polish your brass pin all the way around and slightly round the end (so it will slide even if it's on an angle vs. cutting into the cogs).
Make sure there is NO grease on the nylon bushings either.
Once you can get it to slide easily by hand, put in the servo. Once you are there I suggest mounting the linkage to the back side of the servo horn so the link is parallel with the drivetrain.
Hopefully that all makes sense.
Locked Up is offline   Reply With Quote
Old 09-05-2008, 10:03 PM   #50
Colt Python/SR9c
TwistedCreations's Avatar
Yes. I followed the online manual and had it done and working flawless within 20 mins.. I have not had a single issue yet from it.
Although, I do not run a smaller servo.. I made a new mount and run a 645 on mine.
As far as grease on the nylon bushing, everything in mine is coated with a silicone grease.
TwistedCreations is offline   Reply With Quote
Old 09-05-2008, 10:17 PM   #51
Siggy's Avatar
DNA responded very quickly. Thanks Solomon!!! you guys are really cool.
Old 09-06-2008, 06:07 AM   #52
Hey guys Im out at Nationals and never got the rings for my thrashers so I cant run your rims, I had to stop my Eritex Inc on the way to Moab and have some custom rims made.
Old 09-06-2008, 09:13 AM   #53
Hey guys. I sent you an email regarding the dig. Solomon, you said you would forward it to Don. Still haven't got a response. It's been about a week.
rc4x4crawler is offline   Reply With Quote
Old 09-06-2008, 09:42 AM   #54
I apologize, it is completely my fault. I spent the last week and a half with family as my 33 year old sister has been in poor health and passed away early yesterday morning. It's going to be a few more days until I can give the attention needed to take care of some things. If possible, Solomon will do his best to take care of those of you who can't wait.
Don
billet works is offline   Reply With Quote
Old 09-06-2008, 10:09 AM   #55
Don
Oh sorry to hear that Don. I am not in any rush but I just am rebuilding my rig and wanted to get it all done during the rebuild.
Thanks
Old 09-06-2008, 10:18 AM   #56
Colt Python/SR9c
Don
Sorry to hear that Don as my condolences go to you and the rest of the family:-(
Old 09-06-2008, 06:43 PM   #57
Default Dig Install
Are You Supposed To Lube Any Of The Parts Inside The Dig Unit. Lmk Any Info..thanks
ROCKCAD is offline   Reply With Quote
Old 09-06-2008, 07:27 PM   #58
Colt Python/SR9c
Yes, your supposed to lube the internals..
http://www.visionaryfabrication.com/sales/digbuild.htm
Old 09-07-2008, 09:31 AM   #59
THANKS FOR THE LINK AND INFO
Old 09-07-2008, 10:19 AM   #60
I'm so sorry to hear about your loss Don. My condolences go out to you and your family.
Lankenstein is offline   Reply With Quote
You may edit your posts
