Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: DLUX 2.2 AND 1.9 wheels
Old 03-30-2014, 07:05 AM   #121
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Re: DLUX 2.2 AND 1.9 wheels
6-32
Erik D_lux is offline   Reply With Quote
Old 03-30-2014, 07:02 PM   #122
Originally Posted by Erik D_lux View Post
6-32
Thanks for the super quick response. I just placed my order for a set of carbon fiber 2.2s.
Omega-Tron is offline   Reply With Quote
Old 04-10-2014, 08:26 AM   #123
Glue on G10 2.2 wheels starting at just $23/pair
Glue on G10 Super wheels starting at just $44/pair
Has the prices listed above changed? Appears they are 29$ a pair on the site...unless I'm doing something wrong - I'm choosing G10 using short plastic spacers.
redsawacs is offline   Reply With Quote
Old 04-10-2014, 09:02 AM   #124
Erik D_lux's Avatar
Yeah, prices changed a bit. G10 up a tad, Carbon down A LOT.
Old 01-28-2015, 09:34 AM   #125
Erik D_lux's Avatar
New styles have been cut for awhile. I updated the first post with some pictures.
Old 02-08-2015, 08:07 AM   #126
how wide wheels do I need to buy from you if I am using a set off narrowed voodoos witch is remowed 14.6mm from,,,
I am planning to use them on youre wheels with the loaded dize weights...
They are as narrow as the voodoos in youre first post,,
FLOKI-81 is offline   Reply With Quote
Old 02-09-2015, 06:00 AM   #127
Erik D_lux's Avatar
The loaded dice wheels and my "standard" wheels are not the same.
The loaded dice only come in one width. All the information you need is in this thread
Loaded Dice Knuckle weight add ons
Old 03-23-2015, 06:59 AM   #128
Order placed for:
Fronts:
Carbon fiber D cut
.780
Screw type: Aluminun
Beadlocks: Yes - Black
Rears:
Carbon fiber D cut
1.030
Screw type: Aluminum
Thanks
captainmorgan is offline   Reply With Quote
Old 03-23-2015, 08:15 AM   #129
Originally Posted by captainmorgan View Post
Order placed for:
Fronts:
Carbon fiber D cut
.780
Rears:
Carbon fiber D cut
1.030
Thanks
are you using narrowed tires on the front since you want narrorwer wheels up front??
Old 10-09-2015, 12:43 PM   #130
just placed my order, had to buy something while i wait to purchase axles!
thanks for making an awesome product!
Delbert is offline   Reply With Quote
Old 10-09-2015, 12:50 PM   #131
Erik D_lux's Avatar
Perfect! Thanks! Got them shipped so you should see them Monday or so.
Old 10-13-2015, 01:57 PM   #132
ultra fast shipping and awesome wheels!! if i want to go beadlock in the future i just need to purchase the rings and maybe longer bolts? thanks again for an awesome product!
Old 10-14-2015, 08:34 AM   #133
Erik D_lux's Avatar
All you would need are the beadlocks themselves. Screws will work with both setups!
Thanks!
Old 12-01-2015, 12:30 PM   #134
Hey Erik, what size are those blue screws for your 2.2 CF wheels that screw the wheels into the hub? I have your hub spacers also. Thanks
Digital is offline   Reply With Quote
Old 12-02-2015, 07:37 AM   #135
Erik D_lux's Avatar
I dont supply the screws, I am not sure what hubs youre using and I dont know the hub spacer thickness.
If youre using a VP SLW hub, its a 4-40 screw. Shift hubs can use either a 4-40 or 3mm.
If you can give more information I would love to help. Either way, it should be a 3mm or 4-40 screw.
Old 12-02-2015, 08:18 AM   #136
I snapped some pics real quick, thanks for the reply Erik!
Screws = 13mm long:
Hub Spacers = 7mm thick:
Old 12-02-2015, 08:24 AM   #137
Erik D_lux's Avatar
Some 4-40 x 1/2" long screws should be what you need.
DLUX 2.2 AND 1.9 wheels - Similar Threads
**New** DLUX Wheels Erik D_lux Tires and Wheels 625 10-06-2015 06:59 PM
~~ Stormin's Test Set of 2.2 Dlux Wheels ~~ Stormin2u Tires and Wheels 27 12-21-2011 08:19 PM
** NEW** 1.9 Dlux Delrin Wheels Jslick Tires and Wheels 30 12-18-2011 07:42 PM
DLUX T-Shirts Erik D_lux Vendors Miscellaneous 0 02-08-2011 11:26 PM
You may edit your posts
