12-08-2009, 04:52 PM | #161 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
Simply awe inspiring. |
12-08-2009, 05:51 PM | #162 |
Newbie Join Date: Feb 2008 Location: Forest Grove
The amount of time and skill you have put into this build is unreal. Way to go above and beyond. |
12-09-2009, 05:07 PM | #163 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
I trust you're keeping all those molds in good shape for when you pull all my parts? haha The anticipation must be killer to get this thing completed.
12-13-2009, 03:10 PM | #164 | |||
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
Shoo goo or goop. works really great. Quote:
I got a bit more done. started in the cab sides. I made another mold from bondo of just the corners. Then I carved out the shapes of the door jams and the back details then of course a test panel to see how it all worked out It needs a little tweaking but not to bad so far. More to come | |||
01-03-2010, 07:52 AM | #165 |
I got a little progress on something other than the body. I've had this idea for a long time and finally got the parts made to finish it. I wanted to use the Bruiser/Mountaineer axles but i also wanted to narrow them and add strength. sifting through my parts bin i grabbed a set of AX10 knuckles and started thinking. I did some drawings, had some axle C's made up by Chevellian and after BigSki came over and helped put some threaded inserts in, this is the result: Here is a close-up of the axle C. Rob did an amazing job on the machining! It came out real nice and not only are they super narrow at just under 6 3/4" knuckle to knuckle but they have more steering then stock. Here is is compared to a stock axle. and compared to a narrowed axle BigSki had on his scaler I may need to do some fine tuning with the stub shaft cups to help clear at full lock but otherwise i think they will work great. Thanks guys for you're help! Last edited by Metal Masher; 01-03-2010 at 12:32 PM. |
01-03-2010, 09:35 AM | #166 |
RCC Addict Join Date: Dec 2007 Location: Calgary
wow, killer job on the axles. Looking forward to watching everything come together |
01-03-2010, 09:41 AM | #167 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
| *UPDATES* ? |
01-03-2010, 10:40 AM | #168 |
Newbie Join Date: Oct 2009 Location: Bend
| yota
thats going to look so sweet
01-03-2010, 11:25 AM | #169 |
Newbie Join Date: Apr 2006 Location: Uk (Northumberland)
| I don't think tallent is really the applicable word here !!! This build is way way past that fella |
01-03-2010, 12:03 PM | #170 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
That is a great mod to the Bruiser/Mountaineer axles. This build is going to be amazing once it's completed. Keep up the great work.
01-03-2010, 01:59 PM | #171 |
Newbie Join Date: Dec 2008 Location: Cape cod
great thread. lovin the metal work
01-03-2010, 02:55 PM | #172 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
awesome work
01-07-2010, 11:01 PM | #173 |
Thanks again guys for the kind words! Got a little more done. The rear axle is not done yet as i am waiting for a 3MM die but i did start on the bed mounting brackets. In trying to keep this as authentic as possible i made some brackets as close to the real thing as i could by making a template and cutting them out of thin steel then forming them into shape then i placed them in position to fine tune the fit The rear bracket was done in the same procedure Because the metal was so thin i couldn't weld them so they were braised in place. I still need more practice braising. then i did a quick mock-up of the panels i have done to get a feel for the cab. when i did this i realized I miscalculated when bending the frame and the floor interferes with the frame at the base of the firewall. I'm haven't decided what to do yet. I don't want to make another chassis and i don't want to modify the mold either. This body is really just a test so i might just fudge it to make it work and build another frame later. oh and one last shot. This will be close to ride height i hope. a little taller will be ok but not too much. Night! |
01-07-2010, 11:07 PM | #174 |
unfreaking believeable. The box mounts are killer, well so is the whole build. I can't wait to see whats next. |
01-08-2010, 01:39 AM | #175 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
| WOW! can you guys see it??
I just took a glance at this pic and it just jumped out at me. Doesn't this pic look more like a diarama of a cool garage with a couple 1/4 Scale Racers on the shelfs in the back and a several recycling/storage bins stacked up behind the badass Hilux restoration project. have a look... or is it just late and insomnia is kicking my A$$? |
01-08-2010, 03:04 AM | #176 |
Quarry Creeper Join Date: Feb 2009 Location: Livermore, CA
The craftsmanship on the bed and the cab is downright amazing! I cant wait to see the finished product of your handiwork. |
01-08-2010, 05:17 AM | #177 |
How about a body lift, until you make another frame? I know it's not the look you're going for but it'll be easier.
01-08-2010, 06:53 AM | #178 |
Newbie Join Date: Jan 2010 Location: Elizabeth
You really are Good dude....I just threw all my trucks in the trash....Carry on..
01-08-2010, 06:53 AM | #179 |
Quarry Creeper Join Date: Jun 2009 Location: The Netherlands
Frigging great job!!
01-08-2010, 09:32 AM | #180 |
Newbie Join Date: Dec 2009 Location: Spokane Valley
I know everyone that has seen this build says it but WOW great job, cant wait for the next update. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/147988-project-true-scale-aluminum-toyota-body.html | ||||
Кузова,все о них и для них - Страница 5 | This thread | Refback | 10-05-2011 08:25 PM | |
Wow, Amazing Scale RC Toyota - Tacoma World Forums | This thread | Refback | 10-04-2011 06:14 PM |
