02-09-2012, 06:48 AM | #261 |
| Re: eric113's honcho flatbed now with portals |
02-09-2012, 07:02 AM | #262 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Love the stance of that thing. Looks like you picked up the same rings I was going to send, yours are much nicer looking though. |
02-09-2012, 07:09 AM | #263 |
02-09-2012, 07:15 AM | #264 |
No sweat, glad they worked out for you. I was just thinking, the 1.9 Axial wheels have eight feaux hub bolts, VP hubs have six. If a Gear Head (RPP) UTE 1.9 hub was used the holes might just match up, they are an eight hole hub, 2mm to boot! I'm just thinking out loud. |
02-09-2012, 07:25 AM | #265 | |
| Re: eric113's honcho flatbed now with portals Quote:
02-09-2012, 07:29 AM | #266 |
02-09-2012, 07:29 AM | #267 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
02-09-2012, 08:39 PM | #268 |
I ordered hot racing spools and avid bearings. I have not touch the inners of axles since 2010! Figured with 2 years of runs they would look nasty and seized up bearings. None of the bearing were and the diff didn't look too bad. 2 year old Rocksmith gear jelly grease! |
02-09-2012, 09:31 PM | #269 |
Quarry Creeper Join Date: Jan 2011 Location: Australia
Hey eric, not sure if you posted this or not, but were did you get your portals from?
02-10-2012, 07:47 AM | #270 | |
02-10-2012, 10:37 AM | #271 |
02-10-2012, 12:06 PM | #272 |
02-10-2012, 10:49 PM | #273 |
I worked on the axle little bit tonight. Ran into a issue with one the lockers. Here the issue on left The flanged part isn't seating like the one on the right. |
02-27-2012, 08:59 PM | #274 |
While the axles are getting more work done. I took the time to do some small changes. I swapped to button heads on my ripsaw wheels and tires. Got some Yeah Racing 70mm shocks while back, finally built them. I used 3racing shock cap, Traxxas O-rings with green slim and 60wt oil. Used scx spring cup it very snug fit. |
03-08-2012, 11:11 PM | #275 |
Rock Crawler Join Date: Feb 2008 Location: Georgetown, TX
Great looking truck Eric, better every time I see it. Cant wait to see the next list of updates I shall call you "Captain Clearance"!
03-09-2012, 07:06 AM | #276 | |
I'm hoping to have a updates soon. Hopefully it warm up little bit. | |
03-09-2012, 07:17 AM | #277 |
nice bro. which traxxas o rings?
03-09-2012, 07:56 AM | #278 |
03-09-2012, 05:29 PM | #279 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
| Re: eric113's honcho flatbed now with portals Too bad you can't run a little longer shock,the Traxxas bigbores DON'T LEAK ! I've been running mine for over a year without any leaks. The ones I run are 3.750 eye to eye. 2.755 (70mm) is a pretty short shock....maybe you could do some custom shock hoops thru the bed for longer shocks?
03-09-2012, 07:04 PM | #280 | |
I could do a custom shock, but I like the look of the bed now. I also got use to driving it with short shocks. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/276351-eric113s-honcho-flatbed-now-portals.html | ||||
NEW project ----------- der es wird alles besser HILUX - Seite 4 - 4x4 Scaler auf Axial SCX10 Basis - rockcrawler.de | This thread | Refback | 12-12-2011 12:47 PM |
