06-25-2013, 07:05 AM | #41 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
| Re: Klampyz Wraithokee
LHS has some super fine Piano wire that im going to be assessing for brake cable suitability on friday. also, I ordered two of these for Hydraulic steering Stainless Steel 10mm Bore 35mm Stroke Single Rod Pneumatic Air Cylinder |
06-26-2013, 03:42 AM | #42 |
ok, so got my RC4wd discs today!! theyre awesome!! now that i have them, realising they are a tad larger than i was expecting, im likely to stick with the Venom brake kit i bought as it all fits inside the wheel much better than the 1/8 stuff. (so i might pull the rest of the EB4 to bits and keep it as spares) disc mounted to the rim (not the rim ill be using, but the same size) look at the wee lil bolts!! sits nice n deep inside the rim very happy with that (thats what she said! ! omg...) and the Venom caliper on the disc. just waiting for a pair of stock knuckles now. |
07-02-2013, 04:13 AM | #43 |
got my TR beadlocks today!! so happy with them even reduce the offset slightly. and by slightly im estimating approx 1mm-2mm lol 1.9> 2.2> so yea, happy all except one little issue. :( the brakes dont fit because of the way the beadlock system works... wraith v1 on left, Wraith poison spyder (TR) on the right. |
07-03-2013, 08:41 AM | #44 |
so tonight i decided to go ahead and grind out the screw mounts. unfortunately for me, i got lazy and thought i could do it without undoing the rim and treating the halves seperately and i made a right mess of it. so as im rather embarrassed of the mess, i wont show specifically what i did, but imagine a jagged hole saw being used as a grinding bit and youll see why im embarrassed to show it... lol. all that matters, its on the inside of the rim and you cant see it unless youre looking for it. :/ on a positive note, which is also another dilemma. (constant ey?) the calipers now fit inside and dont interfere, or wont interfere when i grind down the bolt heads that hold the pads on.. i think ill just give yall some pix to gawk at. |
07-07-2013, 04:08 AM | #45 |
| Re: Klampyz Wraithokee |
07-18-2013, 10:22 PM | #46 |
ok so since photobucket is being a PITA and apparently hiding my photos, im going to upload everything to Facebook from now on. so I appologise in advance for larger than previous pictures. but, heres a new picture. on facebook. that i took with my finger over the lens apparently... :/ |
07-18-2013, 10:23 PM | #47 |
hmm. thats too big. how to resize??
07-18-2013, 10:33 PM | #48 |
is this better? yep MUCH better. sweet. just one setting on my phone. and im thinking i might even leave it like that. still plenty of resolution. good good. happy happy btw, anyone notice im gonna use that radiator in my wraithokee?? not for coolant, but for running the fuel thru, with fans on, and to look good. :P having the fuel in there will help with keeping the engine cool while having a place to mount the fans. |
07-18-2013, 10:59 PM | #49 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
That's awesome! Where did you get that radiator? Sent from my ZTE V768 using Tapatalk 2 |
07-18-2013, 11:36 PM | #50 |
its from a watercooled computer kit. pretty sure i got that one from ebay
07-19-2013, 10:05 AM | #51 |
Rock Stacker Join Date: Jun 2013 Location: Murfreesboro
Always wanted to see a nitro crawler. It will definitely be different.
07-19-2013, 04:36 PM | #52 |
Rock Stacker Join Date: Jul 2013 Location: dixon
wow this is some serious engineering on this rig some cant wait to see it finished, I wana hear that nitro engine that's the only thing I miss about it
07-21-2013, 08:34 AM | #53 |
so i printed off a true 8th scale chassis blueprint. look pretty right or what? :P |
07-30-2013, 12:31 PM | #54 |
Newbie Join Date: Jun 2013 Location: Round lake
this thing is going to be wild
07-30-2013, 08:07 PM | #55 |
Rock Stacker Join Date: Sep 2012 Location: Ontario, Canada
This is a sick build. I can't wait to see where it goes. Those brakes are killer.
07-30-2013, 08:16 PM | #56 |
im just waiting on a few parts to arrive before i continue on this. ive ordered another cheap (HSP/Redcat/Exceed) "daily drive" truck so ill have something else to play with as well.. but im 99% guaranteeing that this rig will (one day) get completed. i had initially intended for it to go all out KoH styles, but the further in i get, the more i think it will end up closer to a "normal" 1:1 with a few choice mods. at some point, ill end up getting another shell for it, coz frankly, i regret chopping it up. but i do it to myself all the time... lol
07-30-2013, 08:19 PM | #57 |
| Re: Klampyz Wraithokee thankyou thankyou. im aiming at scale realism here. i dont think its going to be "perfect" but i want it to be a very realistic drive. hence the nitro, the hydro/pneumatic steering, and the fan forced radiator... im aiming for it to get a little heavy as well. |
08-22-2013, 02:22 PM | #58 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
You could add spacers between your wheel and brake disc hubs so your caliper would clear the inside of your wheel. I think gear head sells them on rpp.
08-22-2013, 04:39 PM | #59 |
k thanks for that. ill look into it. it only needs to be about 1mm.. bit of lexan drilled to suit would even work.
08-31-2013, 01:48 AM | #60 |
ya i use lexan as a washer for the wheels on my micro rs4 it works just fine this thing is epic man, my brother told me about a rig he saw that had a marine nitro engine in it and had the same radiator set up as you do are you worried about the motor getting hot? haven messed with nitro in years but my ol nitro rustler used to heat up like a mother and I had alot of holes drilled in the body cant wait to see the progress on this thread
Klampyz Wraithokee - Similar Threads | ||||
Klampyz HSP MOA 1/8 | klampykixx | Superclass Crawlers | 89 | 04-19-2013 09:02 AM |
Klampyz Wraith turned F350 | klampykixx | 2.2 Scale Rigs | 27 | 03-08-2013 12:54 AM |
Hydro's Wraithokee a 1.9 wraith | Hydro-Tank | Axial Wraith | 23 | 11-10-2012 11:01 PM |
Klampyz KOH thing... | klampykixx | 2.2 Scale Rigs | 3 | 07-29-2012 06:15 AM |
Klampyz little F truck RIP :( 11/5/12 | klampykixx | Micro Scale Rigs | 45 | 05-11-2012 04:27 AM |
