08-14-2015, 01:45 PM | #41 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: Starting a truggy...
Some more pics... |
08-14-2015, 01:47 PM | #42 |
I have a couple of videos too but need some time to do some basic editing first... How do u upload video ''directly'' instead of the link??? Last edited by noname0383; 08-29-2015 at 07:30 PM. |
08-16-2015, 03:27 AM | #43 |
| Re: Starting a truggy... |
08-16-2015, 11:00 PM | #44 |
08-16-2015, 11:02 PM | #45 |
08-29-2015, 07:29 PM | #46 |
NO comments, really!?! |
09-04-2015, 08:23 PM | #47 |
Pebble Pounder Join Date: Jul 2012 Location: Saint Louis
Nice looking truck. How well did the growlers fit before the pinch? Sent from my iPhone using Tapatalk |
09-08-2015, 11:02 AM | #48 | |
| Re: Starting a truggy... Quote:
You would have to used wraith like wide axles to fit them properly... With my .600 vp hub and the pinch cab, they rub a bit at full flex but the rig perform very well | |
09-08-2015, 05:50 PM | #49 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I like it. Well done |
09-08-2015, 06:04 PM | #50 |
Last weekend s ride... Still love this rig so much... Survive so many differents terrains and sooooo many impossible fall/crash... nothing broken, only lost a wiper and a light cover |
09-08-2015, 06:05 PM | #51 | |
Don't worry... So many great rigs on this forum u will find what u looking for, no doubt | |
09-08-2015, 06:56 PM | #52 | |
Thanks for the info! Gonna try rock beast and see how much rubbing I have before pinching. Sent from my iPhone using Tapatalk | |
09-08-2015, 07:07 PM | #53 |
I also really like your black on black paint scheme. Subtle but very well done. Sent from my iPhone using Tapatalk |
09-08-2015, 07:19 PM | #54 |
09-08-2015, 07:44 PM | #55 |
The cutting it up I am comfortable with but what glue do you use and what do you use to fill any imperfections? Sent from my iPhone using Tapatalk |
09-08-2015, 11:20 PM | #56 |
will try to explain as good as i can (as u can see english is not my primary language!) -First i cut the cab... -Then i heated the cab with a heat gun to be able to pinch it easily and hold it like that for about 10-15 minute to let it cool down... -I used 2 little pieces of styrene and glue them with Shoegoo to the interior -Once dry, i used car reapair putty to fill the gap, let it dry, sand it, put some more putty, let it dry again, sand it... did this 2-3 times to be sure everything looks perfect -Primer (couple of coat, sand between) -Paint... Hope its clear enought... If not, here the build thread i used to do it... (it in french but check the pics in the middle of the thread!) J'aimerais bien me monter un truggy - Page 14 Last edited by noname0383; 10-07-2015 at 07:09 AM. |
09-09-2015, 09:19 AM | #57 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
That was good thinking on the paint work really a sleeper look at first just basic truggy tell you start to really look at it nice build my RC friend |
09-09-2015, 09:34 AM | #58 | |
Thanks for the info. Much appreciated! Sent from my iPhone using Tapatalk | |
09-09-2015, 06:34 PM | #59 |
10-07-2015, 07:19 AM | #60 |
Ok found for a reason, my front suspension was almost inexistant... All the flex came from the rear suspension... To try to isolate the problem, i put the softest spring a could found... Same problem... So it didn't came from the shocks but somewhere else... After looking and playing with the front axles, i saw the shocks cap rubbing really hard on a screw of the shocks relocalisation part... The shocks was almost bending at mid flex... So i move the kit 1 hole down and no more problem... Now i go FULL flex and a better handling rig... Pics for now, video later... |
Starting a truggy... - Similar Threads | ||||
Blackfoot Truggy (Ford F-150 Truggy) | saltinemadness | Axial SCX-10 | 11 | 10-14-2015 09:51 PM |
My Little Truggy: Fourwheelin is Magic? F350 truggy for my daughter | Joe$ | 1.9 Scale Rigs | 44 | 08-27-2013 07:29 AM |
Hilux Scaler Towing Hilux Truggy (douggy truggy) by heinie_21 | heinie_21 | Videos! | 10 | 02-18-2013 02:15 AM |
so im starting a truggy | redneck909 | General Scale Talk | 17 | 02-23-2008 08:34 AM |
