12-01-2014, 01:21 PM | #21 |
Rock Stacker Join Date: Feb 2006 Location: Williamstown
| Re: The northkona Erik Miller 4421 Ultra4
Awesome build, I saw the 1:1 rig up close a few times and it is awesome. I was wondering why Noone had made a build of this rig. I'm going to be watching this build
12-01-2014, 03:09 PM | #22 |
Newbie Join Date: Jan 2012 Location: Switzerland
That's an amazing rig, man. I like your work and will follow you... What's the wheelbase of this rig? Did you design this tuber upfront with detailed drawings and bending guides? |
12-02-2014, 05:48 AM | #23 | |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
| Re: The northkona Erik Miller 4421 Ultra4 Quote:
I have found that not all the tubework from the 1:1 rigs is needed on these models but I try to keep all the angles of the visible tubework as close as I can . I print out as many clear side-on photos as I can and get all my measurements scaled from there. There is a great build thread on pirate4x4 . A little less weight up high on the chassis is always a good thing so under the panels there are a few tubes missing. | |
12-02-2014, 12:24 PM | #24 |
Newbie Join Date: Dec 2011 Location: stafford
You gonna go newbright tj for the front? Sent from my iPhone using Tapatalk |
12-02-2014, 12:38 PM | #25 |
| Re: The northkona Erik Miller 4421 Ultra4 Funny you mention that ,I do have a tj body sitting here and was considering it but the 1:1 has a narrowed CJ grill. Im looking at getting a jet cut one made and making a hood out of alloy or steel sheet.
12-02-2014, 01:10 PM | #26 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
That definitely a sweet rig. He had it at morris mtn rbd ride last year and broke it trying to climb the punisher. That thing sounds sweet doing some southern rock Bouncin.
12-02-2014, 01:39 PM | #27 |
Yep its always cool to see Ultra4 rigs mixing it with the southern buggies and hearing this on the rev limiter is pretty sweet !
12-05-2014, 06:32 AM | #28 |
Small update , making a few bits out of .5mm titanium to add some bling ( yeah right, inside where they'll be out of view !) to this rig . ESC tray and battery tray, still need to attach some fasteners and tie-downs for the batteries. [IMG][/IMG] [IMG][/IMG] 2 X 2200 3S and an RX8 , a tight fit. [IMG][/IMG] |
12-05-2014, 07:58 AM | #29 |
Rock Stacker Join Date: Nov 2014 Location: On the internet, confused.
That is some great work! I've for a couple questions because I plan to do something similar. How do you line your tubes up and keep them in place while you attach them (brazing, or soldering, or whatever method you used)? Do you build a jig or clamp them or something completely different? Also, do the XR10 lockouts bolt right up to the AR60?
12-05-2014, 12:49 PM | #30 | |
12-05-2014, 11:28 PM | #31 | |
12-06-2014, 12:16 AM | #32 |
| Re: The northkona Erik Miller 4421 Ultra4 |
12-06-2014, 04:28 AM | #33 |
Its as simple as extending the flat section on the tang another 10mm or so ( I use a dremel) and trimming the end so the ends dont touch inside your locker.
12-06-2014, 11:38 AM | #34 |
12-08-2014, 02:14 AM | #35 |
I needed something to hide the ESC so I thought I'd add to the tray and use a bit of mesh from a fan I had lying around. I welded a couple of bits of titanium bicycle spoke on with a couple of tabs for mounting. [IMG][/IMG] [IMG][/IMG] Mounted up and ESC hidden. [IMG][/IMG] |
12-08-2014, 05:19 AM | #36 |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
12-08-2014, 06:26 AM | #37 | |
Pebble Pounder Join Date: Nov 2012 Location: Australia
12-08-2014, 01:03 PM | #38 | ||
ends a double shear anyway. | ||
12-10-2014, 08:47 AM | #39 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
Sick! What are you using to weld brackets etc.?
12-10-2014, 12:43 PM | #40 |
The northkona Erik Miller 4421 Ultra4 - Similar Threads | ||||
the northkona Shannon Campbell Ultra4 | northkona | 2.2 Scale Rigs | 128 | 10-31-2017 05:05 AM |
The Northkona over/under build | northkona | RC4WD Trail Finder 2 | 10 | 04-24-2013 07:14 AM |
Northkona with lights | northkona | Vaterra Twin Hammers | 2 | 03-17-2013 07:28 PM |
Northkona Twammer | northkona | Vaterra Twin Hammers | 8 | 02-15-2013 12:00 AM |
