05-27-2011, 05:27 PM | #101 | |||
RCC Addict Join Date: Mar 2007 Location: Penngrove
Got lots planned for this rig so keep you wallet in your pocket, you'll want it even more when I get some time to finish it up (think removable tube doors, roof panel, light bar, etc, etc, etc...) | |||
11-20-2011, 10:42 PM | #102 |
Haven't driven or worked on this truck for ages but recently got the idea to upgrade the lighting system a bit. Only made sense to install some MadDogRC - "chino63" Scale LED Rock Lights on this truck, was as easy as cutting a couple pockets and drilling some holes. I went the mini deans route for connectors so it's easy to the remove the floor / fender panels. Looks good installed with the expando mesh covering the wires: Nice little flush mount assembly: |
11-20-2011, 11:05 PM | #103 |
Donkey Punch Champion! Join Date: Oct 2006 Location: Minneapolis
Aren't you ready to sell me this FJ yet?? Love the rock lights. |
11-20-2011, 11:20 PM | #104 |
Can you get pic of them on ? Just want how much area they light up. They maybe a future upgrade for me.
11-20-2011, 11:31 PM | #105 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
ya when will the rock lights be available? Just wet thru the whole thread again this thing is awesome Erik, you have such a well rounded skill set its just amazing.
11-21-2011, 10:42 AM | #106 | ||
Thanks for the comment Dave, turns out I'm good at just about everything but driving! By the way, Dean is working on assembling the rock lights as we speak... | ||
01-02-2012, 01:10 AM | #107 |
| Re: Trail Tough FJ40
Got some time in the garage over the holiday break so I was able to get a few things marked "done" on this trucks to-do list. I started by brazing some threaded tabs to the top of the cage, a quick coat of black paint finished it off: Then some panel fab'age with .032" aluminum: And look what fits on the top... |
01-02-2012, 01:47 PM | #108 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
very very nice rig. looks great. how do the rock lights work? they seem like theyll light up the whole side from tire to tire. keep it up |
01-02-2012, 02:54 PM | #109 | |
| Re: Trail Tough FJ40 Quote:
The rock lights work great, the wide angle projection definitely lights up the whole side of the truck. Most people supplement them with a couple LED's in front of the front tires as well (I already have the small Axial buckets mounted there). I finally painted the door panels yesterday so more mods are coming to this rig soon. | |
01-04-2012, 10:37 AM | #110 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
| Re: Trail Tough FJ40 |
01-04-2012, 11:25 AM | #111 |
01-04-2012, 01:33 PM | #112 |
01-04-2012, 01:35 PM | #113 |
01-04-2012, 05:03 PM | #114 |
Send me a pm when it's done. I'm here. You know from Nats, I love it. Keep up the good work. Awesomest FJ build around. |
01-05-2012, 02:30 PM | #115 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
Very nice Land Cruiser love the attention to detail and wiring. Awesome work... |
01-09-2012, 05:32 PM | #116 |
RCC Addict Join Date: May 2010 Location: Midwest
Insanely Awesome! |
01-12-2012, 11:32 PM | #117 |
One of the other issues I've been trying to work out on this truck is related to the multi-function 3rd channel. Currently when I select the winch control the dig servo is off so sometimes the rear slips into free-wheel. FWD is not cool and especially when you are trying to winch out a tough spot. To solve this embarrassing fail I figured I should add a spring and larger dig servo to the mix. Theory is when the servo is not powered the spring keeps tension on the dig selector and the truck stays in 4WD. The larger servo is needed to overcome the spring tension when shifting into dig. I fab'd an aluminum plate as a servo mount and a place to anchor the static end of the spring. I turned down a screw to act as a spring guide and then counter bored the Stage 3R racing dig selector as a spring cup. A spacer, a nut and a stiff spring from a center punch complete the mech: Installed in truck: This set up works well but with the stiff spring keeping the EPA's trimmed is critical to keep the servo from loading while driving. Next I plan to fab a Styrene fuel cell to hide the dig servo, doors are also in the works... |
01-22-2012, 01:51 PM | #118 |
Last week I fab'd a fuel cell to cover the dig servo...ever seen a box made from styrene and painted red before??? I figured the fuel cell should be removable so I decided on hook and loop fasteners. On the back there are cut outs, bracing, and a shelf for velcro mount to bed. Yesterday I started on the doors. I'm using 3/16" black cable clamps and threaded fab tabs as hinges as well as 1/8" stainless rod stock for the frame. I used non-threaded fab tabs for the latch that I still need to make...yep these will open! Once I brazed the frame work I then added some small pieces of 22ga. steel so I can shoe-goo the door skin to it...yep these will be removable with a 2mm driver. |
01-22-2012, 03:54 PM | #119 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Slick, love the tube doors! The coolest 40 is getting even cooler! |
01-22-2012, 05:54 PM | #120 |
Pebble Pounder Join Date: May 2008 Location: El Monte
this is gunna be so sick!!! |
