02-22-2008, 02:41 PM | #181 | |
Rock Crawler Join Date: Aug 2007 Location: Nelson NewZealand Team RC4WD
I am considering making a new set of highlift axles, that only use the pumpkin part of the casing, with more brass bracing than the last lot. Current ones work fine so I'm in no rush to upgrade. Im definitely still working on it Thanks for the compliments guys, even though I havent updated anything | |
02-22-2008, 03:05 PM | #182 |
Rock Crawler Join Date: Sep 2005 Location: IDK
This build is the most scale rig ive seen in ages! Top Notch for sure Why is this in 2.2? its a 1,9 isn't it? |
02-22-2008, 09:48 PM | #183 |
well the wheels are a wee bit larger than 1.9, theyre about 2.0 or something... I just figured to put it in 2.2 cause its a pretty large rig for its wheel size. |
02-22-2008, 11:15 PM | #184 |
| Pretty decent update
My Crawlmaster and Mamba max turned up today, Thanks John! They fit pretty good in the rig and make it sound like a darn robot I found out my planetery reduction is about 55:1 so that combined with brushless means Im going to break a lot of sliders as I get used to the throttle Im not entirely impressed with the startup on sensorless brushless, but with my low gearing it wont exactly matter. The underbody work is far from finished, Ive just mocked up the battery location and driveshafts. Waiting on steel u-joints to arrive from tower.I think I may haveto use a maxx size slider to go from the motor to the transfer - I completely shattered a plastic traxxas slider u-join when I was testing out the throttle The steering servo is now axle mounted, woks much better than before. The servos have also all been upgraded so the winch works great. pics: Its should all come together in the next few weeks |
02-23-2008, 12:01 AM | #185 |
RCC Addict Join Date: May 2006 Location: Roseville
If you ever come to the US, stop by with your rig and your FJ and my Bruiser can do a nice trail run. (Just got it today, excited to work on it)
04-16-2008, 07:32 PM | #186 |
Rock Stacker Join Date: Oct 2007 Location: Bundaberg, QLD, Australia
Any updates?
04-25-2008, 06:14 AM | #187 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Unreal build.. In the 3 or 4 years I've been trawling this site, I have yet to see anything that can be mistaken for the real thing this easily. Well done. ;) I skipped along a bit and seem to have missed something new.. what are you using for a transfer case, and Whats that planitary reduction box you have in there now? |
04-25-2008, 08:01 AM | #188 |
Rock Stacker Join Date: Mar 2008 Location: Arvada
that rig looks awesome, you did a real good job on the body, i think you should also built the bed on left with the canvas top , that is a killer build |
04-28-2008, 04:06 AM | #189 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
First of all, from an FJ fan, this rig is amazing ! Its a small touch (but isn't that what these scalers is all about ?),what about adding the louvres on the bonnet and front quarters ? |
04-29-2008, 11:06 PM | #190 |
Newbie Join Date: Apr 2008 Location: FLA
you should build an fj 60 i always like thoes the best. also making that bed dump would be pretty cool too.
04-30-2008, 03:33 AM | #191 |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
| Wow very few threads have had my attention to the point that I read through it again and again. You deserve that gold star. I like showing people around the office this thread because nobody ever guests that it's an rc. Nice work, my jaw drops every time I look. Just so you know I am so speachless that it took me an hour just to write this. WoW |
10-29-2008, 03:45 PM | #192 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
WOW, I wish that I had found this earlier... A word on aluminum, it will work harden, if you want to continue to shape it then you must anneal it. This is done by setting up a sooty "carbonizing" flame with a torch and covering the aluminum with soot, then by setting up a neutral flame and using it to burn off the soot. Care must be taken to avoid overheating the aluminum, or you'll end up with a molten mess. Annealing can be done as many times as necessary. Heat-treated aluminum must often be annealed before shaping can be attempted, due to its hardness. One more thing, that old body can be finished with a product known as "Alumi-weld" which can be used with an LPG torch to join aluminum, not exactly sure where to find it though. I am in awe of your talents, and I hope this helps you. |
11-03-2008, 11:37 PM | #193 |
Newbie Join Date: Jan 2007 Location: Australia
11-04-2008, 06:10 AM | #194 |
RCC Addict Join Date: Apr 2008 Location: Georgia
That looks awesome, the pics on the shoreline had me thinking it was real for second.
11-04-2008, 06:32 AM | #195 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
Where Are You Fracture!!!!!!!!!!!! We Need A Conclusion!!!!!!!!!!!! .............................................and A Video!!!!!!!!!!!!!!!! |
11-04-2008, 01:48 PM | #196 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
i just saw this thread for the first time, and my jaw just dropped while viewing that last pic.... YOU... ARE... GOD... all joking aside, that is some excelent craftmanship keep it up |
11-04-2008, 02:44 PM | #197 |
11-04-2008, 03:05 PM | #198 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
| Fracture Taking a break |
11-04-2008, 04:27 PM | #199 |
I bet it's the work of a fem-fatal another one bites the dust. |
11-04-2008, 07:18 PM | #200 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
