01-18-2009, 09:32 AM | #61 | |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
Cheers. | |
01-18-2009, 10:23 AM | #62 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
On Towerhobbies they are 26.99 but not in stock yet. They have the stock ratio in HD (but they arent helical) for the same price. I think a set of each would be nice so you can test and tune with all combos.
01-18-2009, 03:33 PM | #63 |
Pebble Pounder Join Date: Oct 2008 Location: Indian Land/ Fort Mill
Question: someone mentioned that these will be competition for the new worm gears on the Losi and Kyosho trucks. Does the fact that the teeth are cut at an angle mean that the truck will no longer roll forward like with the regular gear and that you have to use more drag brakes?
01-18-2009, 04:54 PM | #64 |
I wanna be Dave Join Date: May 2006 Location: akron
01-18-2009, 06:12 PM | #65 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i bought your heavy duty gear sets not to long ago, what ratio are they compaired to these..............bob .... |
01-18-2009, 06:20 PM | #66 |
Pebble Pounder Join Date: May 2008 Location: Bellevue
01-18-2009, 06:21 PM | #67 |
Pebble Pounder Join Date: Dec 2006 Location: Earth
the normal HD gears are the same ratio as stock
01-18-2009, 07:33 PM | #68 | |
01-18-2009, 10:43 PM | #69 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
On a side note. I think what he ment buy competition is that with the capability of haveing an offset ratio that it will make the axial more competative. As Harley stated Helicoil gears just give more contact patch. Last edited by bigflex; 01-18-2009 at 10:46 PM. | |
01-18-2009, 11:02 PM | #70 | |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
The reason the worm gear driven axles have potential to eliminate torque twist is because majority of the gear reduction is happening in the axles, not on the chassis which is a major contributor to torque twist. If the worm gear isn't geared right you'll still see torque twist. Think drilling into metal and it catches...what turns if your drill bit stops and the motor is still trying to move. That being said there is no reason why axial wouldn't be able to make a gearset that has significantly more gear reduction. 2.92 stock is brutal, 3.30 is an improvement, and something in the 4.0's would be even better. IF they make a gear set that eliminates torque twist then it will compete with the worm gear axles. | |
01-19-2009, 02:59 AM | #71 |
Gotcha, thanks. Funny though, I don't have any torque twist. I have the boomarang rear 4 link with the staggered rod ends and its never been a problem.
01-19-2009, 03:48 AM | #72 |
| Yeah I have zero torque twist as well. Link geometry and shock(piston, oil,spring) setup makes a huge difference. |
01-19-2009, 09:54 AM | #73 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
More options is always really nice, great jobs guys |
01-19-2009, 03:57 PM | #74 |
Rock Stacker Join Date: Aug 2008 Location: BC Canada
| Yes, 3 Racing also makes them in a HD helical cut version. Once they are set up properly they run very well. I'm just hoping I can convince a buddy to buy two of the low sets so I can swap my rear 3 racing set for a low gear and that way we're both set up.
01-19-2009, 05:28 PM | #75 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
This even benfits us WK guys, too. Shweeeeeet.
01-19-2009, 08:46 PM | #76 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
01-19-2009, 08:59 PM | #77 | |
I'm sure alot of people would prefer a much lower gear ratio, but I think there is physical limitations to the ring/pinion gear setup. Only so many gear combinations wil work/ physically fit inside of case/ ensure proper gear mesh, etc. Maybe some intuitive designer will come out with a worm gear conversion. | |
01-19-2009, 10:14 PM | #78 | ||
01-20-2009, 09:15 AM | #79 |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
Hey guys. You can pre-order these gears from us now. $22.99/set http://www.tcscrawlers.com/Pre-Order...2-p-17254.html http://www.tcscrawlers.com/Pre-Order...1-p-17253.html Good job Axial! |
01-20-2009, 10:23 AM | #80 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
Any idea on release date?
