02-18-2009, 03:30 AM | #121 |
Pebble Pounder Join Date: Feb 2009 Location: Stafford
Are there any disadvantages to using a different ratio between the front and rear axles that has been noticed yet? I know I read that several guys have been doing it with great success. But it hasn't been very long yet. I'm curious as to what kind of stress that puts on the driveline as well as tire wear and tear. Do you see this being a problem with a stock Axial Scorpion? Perhaps on some of your crawlers this isn't a big issue due to the upgraded parts you're using that might be able to handle the stress more-so than the stock Axial parts, aka the transmission and driveshafts. This is also assuming that the ring and pinion themselves are built tough enough to handle the stress, which I guess after only a month or so is going to be hard to tell, but have any of you that are using different ratios from front to back taken your axles apart after the initial install to inspect the ring and pinion gears or the lockers? Also if the tires are either spinning excessively or being dragged in comparison to the other axle (because two out of the four tires are going to have to give either way) has there been a noticeable difference in tire wear for you guys yet? Thanks for the heads up, I'd definitely love to hear some first hand input on these concerns of mine.
02-18-2009, 08:59 AM | #122 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
02-18-2009, 09:05 AM | #123 |
Moderator Join Date: Apr 2004 Location: In my head
Nice I'll be trying these in the future!!! Good job axial.
02-18-2009, 09:06 AM | #124 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
My thought is that on my MOA truck the Stall is only at low throttle, so when I blip hard it "fixes" the stall. I ended up running differing pinions to do exactly what you mention. The dual ratios would never equalize out in the Axial, which to me seems like a benefit and why I geared my MOA the way it is. I can't wait to get these in for my scaler. Also YGPM, I'm having issues with my SCX-10 axles...just need a quick answer. | |
02-18-2009, 09:20 AM | #125 |
| I hear what your saying. But, when you are trying to clear a tight technical set of gates at extremely low speed, gassing a Berg to get rid of stall would probably cause you to clip a gate. I've seen this happen a few times with guys running 3 channel radios on their Bergs.
02-28-2009, 09:44 AM | #126 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
Is their a release date yet? |
02-28-2009, 10:40 AM | #127 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
02-28-2009, 12:03 PM | #128 |
03-01-2009, 02:09 AM | #129 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
We ordered 3 sets of each from our 2 local stores,no word on the date yet.:-(
03-01-2009, 03:53 AM | #130 |
I think distributors should be getting them either this week or next, so not much longer for your LHS to have them if they were backordered for you...
03-05-2009, 12:16 AM | #131 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I want to gear down with the new lower gears. Can the 14t pinion be used with the 43 ring gear? I was thinking of using the 14/43 front and 13/43 rear. What do you think? Matt
03-05-2009, 12:29 AM | #132 |
| I think you'll never notice the gear ratio difference between one tooth on the pinion gear to be honest. That's probably too small of a change to really be able to recognize. I'm guessing the marginal difference in the size of the 14t vs. the 13t won't matter enough to make it not work with the 43t ring gear though, I would assume they would mesh properly, perhaps slightly tighter but I don't think it would be enough to make it bind. I could be wrong, perhaps someone has already tried it and will chime in with first hand experience.
03-05-2009, 09:42 AM | #133 | |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
Thanks, Axial | |
03-05-2009, 11:39 PM | #134 |
| Thanks thats what I thought. Are you guy's comming down To San Diego again for a Comp? Matt
03-06-2009, 12:42 AM | #135 |
Rock Crawler Join Date: Mar 2006 Location: Up North
I'm running a Novak Goat 18.5 system which already has decent wheel speed... should i run the lower ratio in rear or higher ratio in the front? i have minimal to no torque twist already....what do you recommend? |
03-06-2009, 01:01 AM | #136 |
Newbie Join Date: Jan 2009 Location: Port Coquitlam
My local shop in canada said March 12th release so here's crossing my fingers
03-06-2009, 06:06 AM | #137 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
Axial, is there a release date?
03-06-2009, 11:09 PM | #138 |
Remember that China just celebrated their "NEW YEAR"...i have noticed that alot of R/C parts are out of stock or back ordered..I think that might be a reason for the short supply!.... |
03-16-2009, 06:57 AM | #139 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Can we get an update on a release date.
03-16-2009, 06:51 PM | #140 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I am patiently waiting for the set I ordered form TCS! I hope I will be getting them soon. |
