06-01-2014, 06:19 PM | #161 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Billj"s G6 Build
Quick question...are you able to complete these comps with one battery, or do you change out batteries during the run?
06-02-2014, 06:00 PM | #162 |
Newbie Join Date: Nov 2008 Location: Post Falls
I can attest to this. Crawler Dad (Marc) is really cool to deal with, his lights are bright as all get out, and very reasonably priced. They're not for RTR type guys, as you have to figure out your own mount, but I don't think that'll be a problem for you. |
06-02-2014, 06:10 PM | #163 |
Hey Bill, if you don't mind me asking, where did you get that toggle switch? I'm running the same light setup as you and wanted to do something like that. Thanks!
06-02-2014, 10:19 PM | #164 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
| Re: Billj"s G6 Build |
06-03-2014, 09:42 AM | #165 |
RCC Addict Join Date: May 2008 Location: Southern,WV
06-03-2014, 10:39 AM | #166 |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
| Re: Billj"s G6 Build I wanted to do the same install, but decided on a different approach. I placed my switch behind the driver's seat because I wanted to be able to easily reach inside. If I run sand ladders on top of the cage they might be in the way. And since I'm using a three position switch, I thought it would work better for me. So far it's easy to reach the switch from the side. I do like that setup though.
06-03-2014, 04:32 PM | #167 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
06-03-2014, 04:37 PM | #168 |
| Re: Billj"s G6 Build I run my lights on a separate 850 3s Velcroed to the underside of my drivers seat. Ran the lights for over an hour with no problem. I run my 3300 3s for 111 gates, about 1 hour, with no problems. I think i could do another 75 with it |
06-03-2014, 04:48 PM | #169 |
| Re: Billj"s G6 Build Maybe this is where i saw it done. I dont remember where it was. This is my first scaler, and i was looking at every thread i could to get info |
06-08-2014, 03:01 PM | #170 |
Got in a little practice today at RRW, with my son Tyler (Rocky666). Got front end into a little bind and twisted a driveshaft Thanks to John at RRW for giving me a new driveshaft. Heres Rocky666's freshly painted G6 Last edited by billj; 06-09-2014 at 04:09 PM. |
06-14-2014, 09:41 PM | #171 |
What MIP kit do i buy for my G6? Tired of these twisting driveshafts |
06-14-2014, 10:32 PM | #172 |
06-15-2014, 06:23 AM | #173 |
| Re: Billj"s G6 Build Thanks Trump I just ordered the MIP #13360 kit. Ill be glad to get rid of the plastic stuff. The wildboars seemed to hold up well in the beginning. But in the last week i have gone through two fronts, and now the rear is a little twisted too. I knew it was just a matter of time before i went to MIP's.
06-15-2014, 09:58 AM | #174 |
I've discovered that an M6 bolt is a nice press fit into the drive shaft. Tap it in lightly, worked well.
06-20-2014, 09:00 PM | #175 |
06-20-2014, 09:16 PM | #176 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
If you have BIG POWER you will.
06-20-2014, 10:03 PM | #177 |
06-21-2014, 09:25 PM | #178 |
Rock Crawler Join Date: Mar 2011 Location: USA
Billj'' Great thread ,I really like your post's ,get to the point and show the fun side of it ,,Have you done the over/under gear's yet ,,I did mine today ,,It goes where I point it ,,, I installed the new axial 3 piece drive shafts and so far very good ,,,Robert
06-21-2014, 10:28 PM | #179 | |
| Re: Billj"s G6 Build Quote:
And yes i have the ud/od gears in since the beginning. It climbs and turns a 1000% better with them. I really want to get one of your winches for my G6. They look like a great piece. As far as the driveshafts go, I have always loved MIP's. Had them on my AX10 and my Sporty rigs. | |
06-22-2014, 04:05 PM | #180 |
Back in my nitro dirt Oval days ,I used MIP products ,,they where the best ,Just back yard bashing probably get away with stock for awhile , RPP hobby or Blue Monkey RC stocks my winches ,,Remember to use a fairlead & Heyok 4amp relay winch controller,, Thank you ,,Robert |
Billj"s G6 Build - Similar Threads | ||||
Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thread | cormier33 | Axial XR10 | 132 | 10-26-2014 11:04 PM |
"DIABLO" Ottsix Post Season Build Off! offical build thread | silver falcon | 2.2 Scale Rigs | 21 | 09-06-2014 06:08 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 2 "The Mod Build" | JAM MaxAmps.com | Axial AX-10 Scorpion | 42 | 06-06-2008 10:00 PM |
