03-12-2014, 10:24 AM | #21 |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
| Re: Honcho with XR10 steering?? |
03-12-2014, 11:48 AM | #22 | |
Newbie Join Date: Sep 2011 Location: Australia
| Re: Honcho with XR10 steering?? Quote:
I've already upgraded to metal Junfac drive shafts so adding an ESC to the order when I get a BEC should probably be a no brainer... may as well do it all in one hit while I have the chance huh!!! This way I have the choice of 2s or 3s lipo's. Any particular lipos to buy... or stay away from??? As for setting the voltage on the BEC.. if I buy thru HH and get him to set the voltage, do I just get it set to the maximum that the servo will take, ie 7.4v?? | |
03-12-2014, 01:10 PM | #23 |
Pebble Pounder Join Date: Jan 2009 Location: Parkesburg
If you are buying into Lipos, remember that you will need a lipo capable charger and balancer. The Onyx 245 is a great starter charger that can charge/balance up to 2 lipos at the same time and is fairly user friendly.
03-12-2014, 06:52 PM | #24 | |
My 2s batteries consists of ROC 5000mah, C K R C 5200 mah Punch Pack, Turnigy nano Tech 4200 man. All of them seen to do well. My 3s batteries are Thunder Power G6 and Turnigy nano tech. Both seen to be fine. I would set the BEC at 6 volts, maybe 6.5 and not max out, but that's me. | |
Honcho with XR10 steering?? - Similar Threads | ||||
NEW take on XR10 steering | mfawv | Axial XR10 | 46 | 08-22-2013 05:08 PM |
xr10 steering help! | bustamantealdo | Axial XR10 | 9 | 01-09-2013 02:58 PM |
Honcho steering linkages | rod.d | Axial SCX-10 | 17 | 01-08-2011 08:39 PM |
Honcho steering bind? | wantAsummit | Axial SCX-10 | 4 | 06-20-2010 03:04 PM |
