02-21-2014, 02:57 PM | #41 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: DrDiff952"s O.P.A.A.T. Wraith |
02-24-2014, 03:07 AM | #42 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Well more work done. Shocks built. Though I am not happy with them. Flipped the shock mounting brackets. Started on the cage. The drive shaft is on but the pin still is not locking it in place. I will get more pictures later today.
02-24-2014, 09:06 AM | #43 |
definately need to see the issue...what is wrong with the shocks?
02-24-2014, 09:23 AM | #44 |
I have built a number of Associated, Delta, Kyosho, Losi, HPI, Traxxas shocks before. I am not a fan of "Cartridge" shocks. These feel thin, almost as if the pistons are causing the body to bulge. They will do for now.... Still waiting on the servo, should be there today. Got a nice orange servo arm to go with the Savöx servo. Leaning towards orange as a color scheme. Last edited by DrDiff952; 02-24-2014 at 09:40 AM. |
02-24-2014, 10:04 AM | #45 |
cool...I am really liking the gmade Zero 104mm aluminum body shocks I got for my Wraith, so much in fact that I bought a 94mm set for my scx10 Rubicon the ones on the wraith went together easy and so far there are no leaks. I used teflon tape on the plastic lower housing nuts. on your wraith shocks, did the pistons go in easily when dry fit to the housing? some of them need to be lightly sanded to true them up so they will slide in easily. |
02-24-2014, 07:35 PM | #46 |
Got called into work today. And the servo came I will work on pictures and electronics tonight
02-25-2014, 09:59 AM | #47 |
Last night I started on electronics installation. Savöx servo installed, I have to solder the deans plug on the motor leads, and get power to the BEC. I have to get the BEC adjusted to 6.0 volts. The cage is not done yet. I hope to test the electronics later today.
02-25-2014, 11:56 AM | #48 |
02-25-2014, 06:05 PM | #49 |
nice work so far |
02-25-2014, 09:05 PM | #50 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
Well if you're around laporte I can adjust the bec for ya. Sent from my SGH-T889 using Tapatalk |
02-26-2014, 01:27 AM | #51 |
OK. I came home from work and sat down to cage work. It is lacking the interior and skins, but I got it assembled. Side View Last edited by DrDiff952; 02-26-2014 at 01:52 AM. |
02-26-2014, 02:21 AM | #52 |
What motor u end up using?
02-26-2014, 08:04 AM | #53 |
Went with the Titan 550. Holmes Hobbies was out of those 5 pole motors. I want to eventually get one. But, this is it for now.
02-26-2014, 09:05 AM | #54 |
Rock Stacker Join Date: Oct 2013 Location: Ocala
The shaft should slide all the way to the bearing and actually touch, that looks like what you need to align the pin. Give it a little tap and she will go!
02-27-2014, 09:39 PM | #55 |
Well I bought an orange double clamping servo horn to go with the orange on the Savöx servo. Then I took it apart and found I had one sTeering servo mount ans one DIG servo mount (mount included in the kit). Here is a pix of the blingy bling. If I can't get this ESC figured out, I will go for a Holms Hobbies Brushed ESC Last edited by DrDiff952; 02-27-2014 at 10:45 PM. |
02-27-2014, 11:27 PM | #56 |
I am thinking of some front and rear interior trays. Under the hood / inner fender wells. I just don't know the names or where to buy them from.
02-28-2014, 07:47 AM | #57 |
I believe that you will find what you are looking for on dinky rc under the vendors section or Google it. Hope this helps Sent from my SGH-T889 using Tapatalk |
02-28-2014, 09:15 PM | #58 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
| TheCrawlSpace sells something for the front called "Da Box" , I believe that's it's name....drops into the front and Is very well made. I had one on my last wraith and think I'm getting one for my new one as well.. and dinky rc makes a rear drop bed for the wraith..that's also pretty nice and useful
03-02-2014, 01:05 PM | #59 |
Well I was going over the rig and noticed that my servo arm was hitting on the chassis. I took a look at the servo mpunts and went with the smaller ones. Now my steering arm doesn't hit on the chassis.
03-02-2014, 01:09 PM | #60 |
thats cool...i am changing my fastback links to traxxas revo shafts, the same ones that I used for my lower links..I just couldnt get used to the idea of the spare up there adding weight up high. I got the Da Cover on the back now so it will look much nicer and clean..
DrDiff952"s O.P.A.A.T. Wraith - Similar Threads | ||||
Wraith "Time Killer" | OORRACING | Axial Wraith | 0 | 11-08-2013 11:20 PM |
one piece at a time | foproy | Tamiya Clod Buster | 58 | 06-07-2010 01:36 PM |
