Thread: Szczerba's 2014 2.2 #744 Wraith
Old 02-09-2014, 03:05 PM   #21
Default Re: Szczerba's 2014 2.2 #744 Wraith
Cool thanks. I want to learn how to weld and looking for a good welding machine that won't break the bank.
TeamBosing is offline   Reply With Quote
Old 02-09-2014, 03:09 PM   #22
I bought a cheapo harbor freight flux wire welder (no gas) for $120 a few years ago. I spent more grinding and cleaning up slag/splatter than welding and working. I bought this Hobart a couple months after I was tired of fighting the flux wire welder. This hobart is 110v and was around $750 after taxes and a trip local auto parts store to get a MIG bottle. It is a light duty welder but works pretty good for rc stuff. I am self taught and Not that good but it gets me rigs built.
Search welding on RCC and you'll find some other information on what guys have used.
Szczerba is offline   Reply With Quote
Old 02-09-2014, 03:12 PM   #23
Perfect! Thanks for your input.
Old 02-09-2014, 05:56 PM   #24
Hey Shane are you using 3/16th solid rod or tubing? Just curious
M_ENERGY is offline   Reply With Quote
Old 02-09-2014, 06:01 PM   #25
Brandon used 3/16" rod and I have Added some 5/32" rod here and there. K&S sells the 5/32" "music wire". I have used it on several builds as it's lighter than 3/16" and still holds up when built correctly.
I usually build with 3/16" tube but I am out right now. I hope to get another 40-50' of 3/16" tube in the near future.
Old 02-09-2014, 08:21 PM   #26
Ran out of Carter Fab 90 deg tabs. Had to make some more. FML.
Old 02-10-2014, 07:14 AM   #27
Originally Posted by Chrisg81983 View Post
Looks great man
Thanks. I have about 10 more mount tabs to add, cut the panels out of 0.025 metal, add electronics, test drive and tune the shocks.
Old 02-10-2014, 10:09 AM   #28
~THE SCALE SHOP~
sweet to see this chassis finished. definatly adjustable.
STANG KILLA SS is offline   Reply With Quote
Old 02-10-2014, 09:14 PM   #29
Thanks Cory.
Some panel work tonight
Old 02-11-2014, 07:47 PM   #30
Hood and others.
Roller with trans, motor, esc and battery, spare, etc. so the whole rig should stay under 9lbs.
Old 02-12-2014, 09:42 PM   #31
Crawler Innovations Wild Deuce Single short foams, proline swampers and TSS Rockrawler wheels modded for SLW hubs. 225 hubs used.
I was running 5.25" Crawler Innovations Double Deuce Foams.
Finish welding, primed and blacked
Old 02-13-2014, 07:27 AM   #32
Yea buddy!
looking good!
cant wait to see it in action this weekend at..
ARCC Rally in the Valley G6
at Superlift Orvpark
ROLANDROCKSHOP is offline   Reply With Quote
Old 02-14-2014, 02:46 PM   #33
Thanks guys.
Getting there.
HolmesHobbies Trailmaster Brushless motor. Geared 12/54.
Bumpstopshock
Old 02-14-2014, 02:50 PM   #34
What's your opinion of the king shocks?
Cmarcan167 is offline   Reply With Quote
Old 02-14-2014, 03:31 PM   #35
Sweet lookin rig buddy!
mcrawlinslow is offline   Reply With Quote
Old 02-14-2014, 04:31 PM   #36
Default Szczerba's 2014 2.2 #744 Wraith
These are the RC4WD scaler shocks but can mistaken for the Kings.
Four dual spring shocks and two
Internally sprung scaler shocks. I have them setup with 45wt oil for now since i am running front and rear sway bars. I will run it hard tomorrow and find out. I replaced the orings,
Cut slits in the shock pistons and polished the shock shafts.
I will have the new Vanquish shock limiting straps on soon. These shocks are prone to breaking the small e-clips when over extended too hard. The looks are killer but the performance has to be worked on. These shock pistons are alot smaller in diameter than 1/10 shocks so they do not dampen the suspension like bigger diameter shocks do.
Thanks for starting the chassis out for me. Great design lines. I have about 35 hours in building since I got the starter chassis from ya.
My normal bare panels and stickers a plenty. Im too lazy for paint.
RTR
Old 02-14-2014, 04:43 PM   #37
Good lookin rig! Love the ultra4 stuff! I've been wanting to shed the weight of my seats in my wraith, what drivers do you have there? It looks like those would be a close fit in a wraith chassis.
Tgreer is offline   Reply With Quote
Old 02-14-2014, 04:46 PM   #38
Hpi Apache half interior. They may fit the wraith chassis. Not 100% sure. I have a spare new one if you wanna try it.
I am running front and rear sway bars with light shock oils. So far it handles great at speeds and still crawls decent. Ill carry a 2mm and 3mm hex tool with me incase i need to remove the front sway connects on the trail.
Old 02-14-2014, 05:54 PM   #39
Forgot to mention.
Axles:
Plastic Wraith Axle Housing out back
Vanquish AL front axle housing
HD Axial Gears
GripFab Stainless Steel Locker up front
Vanquish locker out back
Axial Lower Link Mounts
Vanquish Wraith Chubs C-Hub
Vanquish Wraith Steering Knuckles
Vanquish Titanium Tie Rods
Vanquish lower and upper links
BlueMonkey RC rear lowers
RC4WD ARB Diff Cover for Wraiths
Axial universal's
"Dinky Link" S-Type (Front)
Stock Wraith Rear 4-Link
Transmission:
Vanquish Aluminum Axial Transmission
Supershafty.com one piece motor mount
Axial Spur Cover
Crawler Innovations 4340 steel; 5mm - Axial Trans Output Pair
MIP Driveshafts. Cut, chopped, rebuilt.
32 pitch gears 54-60t
Robinson Racing gears
Old 02-14-2014, 08:18 PM   #40
Lil bro is ready too.
Szczerba's 2014 2.2 #744 Wraith - Similar Threads
Szczerba's F-Toy #744 Szczerba 1.9 Scale Rigs 240 02-17-2022 08:32 PM
Szczerba's Wraith Monster Truck Build #2 Szczerba Mega/Monster Trucks 30 02-13-2015 09:05 PM
Szczerba's #744 Twin Hammer Szczerba Vaterra Twin Hammers 104 03-21-2014 09:24 PM
Szczerba's IFS Wraith Build #2 Szczerba Axial Wraith 22 01-16-2014 11:59 AM
